Ich zitiere mich mal selber und die Info von Steinberg aus den ReRelease Notes zu 12.0.10:Ich sag mal Jein.
Auch wenn es bei mir mit C12 keine Probleme gibt, kann man dem Steinberg Forum schon entnehmen, dass es bei verschiedenen Systemen hakt. Steinberg ist aber sehr bemüht den Dingen konstruktiv auf den Grund zu gehen und in einem nächsten Update das ein oder andere zu fixen. Für die, die betroffen sind, natürlich aktuell mit der .0-Version unschön.
Sieht also schon wieder bedeutend besser aus!Performance and stability issues
We have received several reports about performance and stability issues in the initial release of Cubase 12.0.0 from different users. In the past weeks, we invested a lot of time in investigating why, on some systems, Cubase 12 leads to suboptimal performances. We want to thank all users that provided traces to us and collaborated with our team to help us find the right spots to look at. We are confident that we made significant headway with Cubase 12.0.10. After the update, a good share of the users who previously experienced performance and start-up issues will be satisfied. However, unfortunately, there are still reports that we cannot reproduce on our systems. Sometimes, the root cause results from a combination of different hardware components, plug-ins, and preferences. In this case, establishing the correct configuration to reproduce an issue is crucial to fixing it. Please reach out to our team via the Steinberg user forum and let us know if you are still experiencing performance issues with Cubase 12.0.10. We are taking these reports very seriously, and fixing these issues is currently our highest priority.
the 12.0.10 update improves the Midi device handling and solves performance issues in that area - which seems to make things better for @jazztom and hopefully many more users (Thanks for your feedback!).
The update does unfortunately not provide the solution for the decline in real time performance (hence, the crackles, dropouts, stop-and-go events when record-arming Midi/ VSTi tracks at low latency). The solution for these issues will be part of the next update (no release date specified yet, sorry).
Mache gleich ein paar Screenshots.Haste mal Beispiele, dann können andere Nutzer das ja mal querchecken.
Das dürfte an den acht QuickControls liegen, die man oben einblenden kann. Da gibt es auch schon einen Thread im Steinberg-Forum. Einfach mal die QC-Controls einblenden. Das sollte daher nur bei Plugins mit einer kleinen grafischen Oberfläche der Fall sein.
Genau dieses Problem habe ich auch, allerdings erst seit Gestern und zwar bei allen Plugins. Die Tage davor war alles ok. Ich dachte schon ich habe versehentlich irgendeine Tastenkombination gedrückt, die das ausgelöst hat.Arschlecken!
Bei anderen Herstellern konnte ich jetzt keine Fehler entdecken, die haben es aber in sich und man kann nicht von kleinen GUIs reden. Man kann damit arbeiten, so ist das nicht aber Kontakt und Massive laufen normal.
Checkt mal bitte!
VST3?Arschlecken!
Checkt mal bitte!
Ja, läuft stabil!habt ihr denn heute das Update drauf getan?
liest sich so, als wäre es ~Ostern noch alles i.O. gewesen
