Rec0rder
hier klont einer den 1176 in Stereo / dual mono als 19“ gerät
https://highvoltageaudio.net/
Specifications
Specifications
- Compressor Type: Field-Effect Transistor (FET)
- Channels: Two (2) channel, dual mono
- Rack space: 19” 1RU
- Controls: INPUT, OUTPUT, ATTACK, RELEASE, RATIO (stepped), MIX
- Ratios (5 step rotary switch): 2:1, 4:1, 8:1, 12:1, 20:1
- Attack (potentiometer): SLOW - FAST
- Release (potentiometer): SLOW - FAST
- Pushbuttons: TUBE/SS, HPF (@ 100Hz), IN, SLAM, METER
- Inputs & Outputs: Balanced 3 pin XLR with relay bypass
- Output Stages: (Switchable) between solid state electronically balanced output and transformer balanced, tube gain stage using 2 x ECC88 tubes
- THD: 0.5% or better
- Noise Floor: -80dB or better
- Warranty: One Year Warranty
$2100.00 (AUD)
