REAPER 5.961
semox
semox
v5.961 - October 19 2018
+ Linux: improve ALSA underrun handling
+ NINJAM: fix clipsort.log import
+ Notation: fix actions to insert note at nearest C, etc [p=2045279]
+ ReaEQ: fix phase calculation error, improve phase display range [t=193417]
+ ReaEQ: alt+click band to remove, ctrl+mousewheel to fine-adjust band width
+ ReaEQ: doubleclicking an empty area adds a new band/notch/shelf/hipass/lowpass
+ ReaEQ: hold ctrl+shift when adjusting point for fine adjustment of bandwidth
+ ReaEQ: notify parameter change when using mousewheel to adjust bandwidth
+ ReaEQ: options to increase band handle size, use 3dB or 4.5dB/octave slope on analyzer
+ ReaScript: fix incorrect playback following updating item state via GetSetMediaItemInfo() [t=209873]
+ ReaScript: fix double-character return from gfx.getchar() for some keys (e.g. F10) on Windows [t=212238]
+ ReaScript: fix ownership issues when using SetMediaItemTake_Source() from EEL/lua [t=212276]
+ ReaXcomp: fix UI glitch on macOS/linux
+ ReaXcomp: doubleclick band handle to bypass, shift+doubleclick to solo
+ ReaXcomp: improve band insertion behavior, insert band on doubleclick
+ ReaXcomp: options to increase band handle size, use 3dB or 4.5dB/octave slope on analyzer
+ VST3: fix color byte ordering for plug-ins that use IContextInfoHandler [t=211988]
+ VST3: revert to 5.95 behavior relating to latent VST3 parameter changes and state saving
Knutorius
MountainKing
MountainKing
mkzwoo
mkzwoo
mkzwoo
Can
Navar
N
