oschfreak
Von Apple habe ich komischer Weise noch nichts gefunden. Auf die Schnelle nur hier:
New in Logic Pro 10.4.7
Stability/Reliability
"Dear UAD User,
As you may know, Apple released macOS 10.15 Catalina today.
Please note — UAD and UA Audio Interface software cannot be installed on macOS Catalina.
We recommend that you wait until UAD software compatibility with Catalina is announced before updating to this new operating system.
Important: To prevent macOS from updating automatically, uncheck the “Install macOS updates” option in System Preferences > Software Update > Advanced options.
UAD compatibility with Catalina is being tested now and complete Catalina qualification will be released in a future UAD software update. For more information and the latest Catalina news, please read the article posted in our Knowledge Base.
Thanks for your consideration.
Sincerely,
The UA Support Team"
Apple is expected to release macOS 10.15 Catalina in October.
We strongly recommend waiting to upgrade to this OS until we've had a chance to fully qualify our software with this release and issue any necessary updates, which we will do as soon as possible.
PRO TIP: Turn-off automatic updates on your Mac to stay in control.
For more in-depth information on some of the major changes expected in macOS Catalina, check out this post from our friends at Create Digital Music.
Mix on,
Soundtoys"
- Resolves an issue where enabling an audio driver while another application is actively using the same driver could cause Logic Pro to unexpectedly quit.
- Resolves an issue when clicking the Edit button in EXS24 while running in Spanish would cause Logic Pro to quit unexpectedly.
- It is now possible to insert a plug-in before an existing plug-in using VoiceOver
- When assigning icons to tracks, VoiceOver now announces the name of the icon.
- VoiceOver now properly announces disclosure triangles in Inspectors.
- It is now possible to scroll to plug-in parameters outside the current view using VoiceOver.
- VoiceOver now announces the toggle state of hardware controls in channel strips.
- When multiple plug-ins are inserted consecutively using VoiceOver, they are now consistently inserted in the expected order and announced correctly.
- VoiceOver now announces quantization applied by key command.
- Interacting with a channel mode button using VoiceOver no longer shifts the focus away from the channel strip.
- It is now possible to navigate the pop-up menus for Outputs, Inputs, Groups and the Channel strip Settings menu using VoiceOver.
- VoiceOver now announces the state of buttons in the Control Bar.
- VoiceOver no longer announces an unnecessary “zero” when selecting items in the Track Header.
- Send values no longer jump by random amounts when adjusting them using VoiceOver.
- The untagged Loops browser is now accessible using VoiceOver.
- It is now possible to drag non-contiguous tracks into a Track Stack using VoiceOver.
- VoiceOver now announces the Gain Reduction Meter in channel strips.
- VoiceOver now announces the state of the Input Mode button on channel strips.
- Stereo width and panning can now be adjusted using the scroll wheel on a mouse.
- When you click and hold the Input Mode button on a newly created channel strip, the Input Mode menu now consistently appears.
- When the project setting "Only load plug-ins needed for project playback" is enabled, busses the patch sends to are now activated as expected.
- Flex Pitch notes now continue to display properly after Reset All is performed for Flex Pitch adjustments on a region that has been split.
- Splitting a note on Flex Pitch no longer causes Flex Pitch detection to disappear for the note to the right side of the split.
- Automation can now be written from Audio Units v.3 plug-ins.
- Resolves an issue in which it was not possible to automate certain 3rd party Audio Unit plug-in parameters.
- The Impulse Response Utility now creates useable IR files.
- Settings in the Track Inspector no longer unexpectedly affect Articulation Output switches.
- Clicking a Pad in Drum Machine Designer after clicking the Sends tab no longer causes unexpected global controls to appear in the Smart Control page.
- It is now possible to bounce a track in place in a project that has not yet been saved.
- The dialog for sharing to SoundCloud now allows the username and password to be successfully entered.
- SMPTE-locked audio regions now remain properly synced to video after the left border of the movie is changed.
- Logic Remote now reliably shows the solo state of a soloed channel in Logic Pro.
______________________________________________________________________________
"Dear UAD User,
Sincerely,
"Listen Up!
Mix on,
Soundtoys"
