160dB
Da die Jungs von Bitwig ziemlich fleißig sind und immer wieder neue Updates raus bringen, hier der passende Thread um sich auszutauschen
Die aktuelle Version ist Bitwig 1.3.4.
Changes in Bitwig Studio 1.3.4
Released on 27.11.2015.
FIXED Crash when changing buffer size in preferences.
FIXED Possible to create a feedback loop in a project by copying a dynamics device receiving from a track group into one of the tracks in the group.
FIXED Duplicating multiple audio events across multiple clips with time selection only duplicates last audio events.
FIXED Hardware Instrument device is not letting the sound thru after you open the project until you see the device itself or trigger a note in this track.
FIXED Recorded notes were sometimes assigned the wrong pressure value if the controller never sent a poly pressure event on that key.
FIXED Quit commad gets disabled on OSX after invoking once and choosing cancel in project save dialog.
FIXED Arranger object snapping should be off by default.
FIXED Mouse cursor sometimes does not reappear after moving automation point on OSX.
