https://www.spectrasonics.net/news/news-content.php?id=121
Nicht schlecht für Umme.
Trilian 1.5 Features Overview
• Over 200 new Trilian patches!
• New Trilian Creative Library for Omnisphere users
• New redesigned Hi-res, Resizable Interface
• Expanded Synthesis Features
⁃ New Filter types
⁃ Polyphphonic Waveshaping
⁃ Ring Modulation
⁃ Enhanced FM
⁃ Doubled Harmonia Voices
⁃ Full FX Modulation
⁃ Doubled Mod Matrix
• Enhanced Browsing
⁃ New Mini-Browser available at all times
⁃ New Full Browser has a cleaner layout
⁃ Sound Match™ instantly locates any related sounds in the library
⁃ Sound Lock™ allows endless variations by locking sound aspects while you browse
• New Arpeggiator Features:
⁃ New Functions menu (Duplicate, Rotate, Reverse, Shuffle)
⁃ New Note Patterns (Join, Spread, Stairs Up, Stairs Down + 4 more)
⁃ New Play Modes (Loop, Chaos, Once)
⁃ New Step Modifiers (Transpose, Slide, Chords, Hi-Low & Step Dividers)
⁃ New Capture feature records the output of the Arpeggiator and exports it as a MIDI file
• New Sharing features for easily sharing and adding custom sounds
• Windows multi-touch support
• Redo/Undo functionality
• ...and much more!
• FREE for all Trilian users!
Full list of new features and improvements:
• Major Interface Update
⁃ New high-resolution GUI with support for HiDPI displays.
⁃ New interface design is easier to use
⁃ Up to 2X GUI Magnification options
⁃ Windows Multitouch Support
⁃ New Live Mode interface for touch screens
⁃ New Show Modulation pane opens modulation routings/sources on left side
⁃ New Layer Level Meters
⁃ New Stereo Part Level Meter
• New Synthesis Possibilities:
⁃ 11 new filter types:
⁃ State Variable Filter 12db and 24db
⁃ LPF Power 12db and 24db
⁃ HPF Power 12db and 24db
⁃ Bandpass Power 12db and 24db
⁃ Formant
⁃ Resonator-
⁃ Resonator+
⁃ Filter Variant control creates unique panning effects or changes the tone depending on Filter type.
⁃ Waveshaper with Crusher, Shaper and Reducer sections for versatile and musical polyphonic distortion.
⁃ Timbre Crush Mode for Polyphonic Bit-Crushing (Distortion) and filtering
⁃ Soundsource Reversing
⁃ Ring Modulation
⁃ Boost switch for deeper FM and RM capabilities and more aggressive timbres
⁃ Shape, Symmetry and Sync functions for FM and RM
⁃ Doubled Harmonia voices
⁃ New Mod Matrix All Layers capability: when enabled, modulation applies to the relevant parameter in all layers
⁃ New Modulation sources: Bias, 3-Step, 4-Step, Constant, Constant Bipolar, multiple Random and Unipolar
⁃ Expanded Glide range
⁃ Phase Invert button on sublayer mixer in Soundsource Zoom
• Enhanced Browsing Experience:
⁃ New Mini-Browser lets you browse and edit sounds without switching pages.
⁃ Sound Match™ feature instantly locates any related sounds in the library
⁃ Sound Lock™ allows endless useful variations by locking sound aspects while you browse
⁃ Remote control loading of patches and multis via MIDI Program Change, CCs or Notes
⁃ Fast Progressive Loading allows rapid auditioning
⁃ Boolean search options
⁃ New Audition Auto-Play feature enhancements
⁃ New Speed knob controls the offset to the host tempo
⁃ New Octave options
⁃ New Latch button
⁃ Arp Reset button can be modulated
• Flexible New FX Features:
⁃ New Aux FX rack per patch with Pre/Post fader sends
⁃ FX Parameters are Fully Modulatable
⁃ Bypass all effects by pressing the LED below FX button
⁃ Lock FX while browsing
⁃ Move effects within effects rack by dragging
⁃ New FX Unit Preset steppers
• New Sharing Options
⁃ Easy Sound/Project Sharing for collaborators and third party libraries
⁃ Publish Library feature allows users to easily export a library in a single .trilian package
• Improvements/Special Features:
⁃ Improved authorization process
⁃ Redo/Undo functionality
⁃ New Clear All Browser Learns action on Utility menu
⁃ Mode Stack Mode Note Regions option for Key Splits in Live Mode
⁃ Global Clock Speed (Halftime, Doubletime, etc)
⁃ Live Mode: New Single Sound option added to MIDI CC Mode and Key Select Mode menus
⁃ Use mouse wheel to scroll over menus items
⁃ Enable mouse-wheel scrolling on mod target Bias Point note menu
⁃ Show indication of when a control is waiting for MIDI learn to complete
⁃ Enter Parameter Value feature
⁃ MIDI CC learn and host automation can now be used for parameters controlled by menus and radio buttons
⁃ Improved resolution of Attack, Decay & Release sliders
⁃ Increased resolution when using Shift key to adjust knobs/sliders values
⁃ Enlarge clickable region for some steppers to be more user-friendly
⁃ Adds up/down stepper arrows to Filter preset menu on Layer Page
⁃ Support for foreign-languages in patch names, tags, search, etc.
⁃ Utilize different tunings, including historical, microtonal scales and user-created temperaments
⁃ New System Pitch Options allows saving master tuning and scale selections in multis or host sessions
⁃ New Startup Directory menu allows you to select the Patch directory that is loaded at startup
⁃ Auto Recall option remembers the last library/directory from which user loaded a patch
⁃ New indicator on patch name showing if patch needs to be saved (asterisk after name)
⁃ Support for high-resolution CC values
⁃ Display Master Filter Frequency in Hz
⁃ Streaming improvements
⁃ Note Stealing improvements
⁃ macOS Big Sur compatibility
⁃ 64 Bit Only
* NOTE: Patches saved in Trilian 1.5 are not compatible with earlier versions.
⁃ New Filter types
⁃ Ring Modulation
⁃ Enhanced FM
• Enhanced Browsing
• ...and much more!
⁃ Formant
⁃ Resonator-
⁃ Resonator+
⁃ Ring Modulation
⁃ New Latch button
⁃ 64 Bit Only
