Studio One 7.2.3 Mini Update
  • Ersteller Ersteller statusquofan
statusquofan
statusquofan
Es gibt ein Mini Update auf 7.2.3.
Version 7.2.3 Release Notes (October 29, 2025):
New features and improvements:
● Improved loading times for track presets
● [Pipeline XT] Changing the audio device block size now re-pings all instances
● Replacing a looped event now keeps loop range of original event
The following issues have been fixed:
● [Drum Editor] Unwanted redrawing of notes in continuous centered/left autoscroll mode
● [Level Meter] Peak measurement not accurate
● [Level Meter] Tooltips wrong or missing
● [macOS] Certain AU plug-ins open in a misaligned window
● [macOS] Freeze when replacing all events via option + drag from Browser
● [macOS] Intermittent play cursor freeze in Note Editor
● [macOS] Mixtool invert buttons not initialized when loading Song
● [macOS] Tooltips appear in screen center when hovering over functions close to Dock
● [Note Editor] Last key in keyboard view looks wrong in mode "Pitch Visibility: Used"
● [Score Editor] Multi-measure rests broken at chords even when not showing chords
● [Score Editor] Time Signature not updated in certain cases
● [Windows] Graphical glitch in text field after resizing "Store Preset" dialog
● [Windows] Macro Toolbar: scrolling via mouse wheel not working when mouse cursor
hovers drop-down menu button
● Certain chords inside Instrument Parts not detected and separated correctly
● Crash on closing certain Songs
● Drag & Drop not working with certain 3rd party plug-ins
● Edit loop start does not edit the first loop
● Embedded ARA plug-in window receives all keystrokes despite Arrangement having focus
● Freeze when inserting certain Launcher playlist to Song
● Global “Delete Time” only affects the video's audio track if video folder is closed
● Graphical glitch when tooltips pop up in Note Editor
● ‘Insert Selected Instrument' will not insert into a folder group
● Instrument Library location disappears under certain conditions
● Lag when extending global range selection after “Create Ranges” on many tracks
● Linked Arrow/Range Tool behaves inconsistent in cell Audio Editor
● Multi Instrument child channels don't automatically move with bus channel
● Note Repeater records occasional double notes
● Plug-In Manager show/hide switch lags with large number of plug-ins
● Potential crash when removing certain automation lanes
● Ripple edit causes automation shift on unassociated tracks
● Selection with 'Loop Follows Selection' sometimes moves loop range to wrong position
● “Set Time Offset to Cursor” not displayed properly in ruler
● Surround Panner marks song edited directly after loading
● Track Inspector doesn't always show currently selected track
● Track lyrics removed when overdubbing or punching
Reaktionen: solokeyboarder
Anscheinend bekommen das Update auch 7er User deren Updateperiode bereits verlaufen ist, da dieses per se alle 7.2.X er updates beinhaltet.
Das ist fair.
