Trillian 1.5 free Update
  • Ersteller synthpark
synthpark
synthpark
https://www.spectrasonics.net/news/news-content.php?id=121
Nicht schlecht für Umme.
Trilian 1.5 Features Overview
• Over 200 new Trilian patches!
• New Trilian Creative Library for Omnisphere users
• New redesigned Hi-res, Resizable Interface
• Expanded Synthesis Features
⁃ New Filter types
⁃ Polyphphonic Waveshaping
⁃ Ring Modulation
⁃ Enhanced FM
⁃ Doubled Harmonia Voices
⁃ Full FX Modulation
⁃ Doubled Mod Matrix
• Enhanced Browsing
⁃ New Mini-Browser available at all times
⁃ New Full Browser has a cleaner layout
⁃ Sound Match™ instantly locates any related sounds in the library
⁃ Sound Lock™ allows endless variations by locking sound aspects while you browse
• New Arpeggiator Features:
⁃ New Functions menu (Duplicate, Rotate, Reverse, Shuffle)
⁃ New Note Patterns (Join, Spread, Stairs Up, Stairs Down + 4 more)
⁃ New Play Modes (Loop, Chaos, Once)
⁃ New Step Modifiers (Transpose, Slide, Chords, Hi-Low & Step Dividers)
⁃ New Capture feature records the output of the Arpeggiator and exports it as a MIDI file
• New Sharing features for easily sharing and adding custom sounds
• Windows multi-touch support
• Redo/Undo functionality
• ...and much more!
• FREE for all Trilian users!
Full list of new features and improvements:
• Major Interface Update
⁃ New high-resolution GUI with support for HiDPI displays.
⁃ New interface design is easier to use
⁃ Up to 2X GUI Magnification options
⁃ Windows Multitouch Support
⁃ New Live Mode interface for touch screens
⁃ New Show Modulation pane opens modulation routings/sources on left side
⁃ New Layer Level Meters
⁃ New Stereo Part Level Meter
• New Synthesis Possibilities:
⁃ 11 new filter types:
⁃ State Variable Filter 12db and 24db
⁃ LPF Power 12db and 24db
⁃ HPF Power 12db and 24db
⁃ Bandpass Power 12db and 24db
⁃ Formant
⁃ Resonator-
⁃ Resonator+
⁃ Filter Variant control creates unique panning effects or changes the tone depending on Filter type.
⁃ Waveshaper with Crusher, Shaper and Reducer sections for versatile and musical polyphonic distortion.
⁃ Timbre Crush Mode for Polyphonic Bit-Crushing (Distortion) and filtering
⁃ Soundsource Reversing
⁃ Ring Modulation
⁃ Boost switch for deeper FM and RM capabilities and more aggressive timbres
⁃ Shape, Symmetry and Sync functions for FM and RM
⁃ Doubled Harmonia voices
⁃ New Mod Matrix All Layers capability: when enabled, modulation applies to the relevant parameter in all layers
⁃ New Modulation sources: Bias, 3-Step, 4-Step, Constant, Constant Bipolar, multiple Random and Unipolar
⁃ Expanded Glide range
⁃ Phase Invert button on sublayer mixer in Soundsource Zoom
• Enhanced Browsing Experience:
⁃ New Mini-Browser lets you browse and edit sounds without switching pages.
⁃ Sound Match™ feature instantly locates any related sounds in the library
⁃ Sound Lock™ allows endless useful variations by locking sound aspects while you browse
⁃ Remote control loading of patches and multis via MIDI Program Change, CCs or Notes
⁃ Fast Progressive Loading allows rapid auditioning
⁃ Boolean search options
⁃ New Audition Auto-Play feature enhancements
⁃ New Speed knob controls the offset to the host tempo
⁃ New Octave options
⁃ New Latch button
⁃ Arp Reset button can be modulated
• Flexible New FX Features:
⁃ New Aux FX rack per patch with Pre/Post fader sends
⁃ FX Parameters are Fully Modulatable
⁃ Bypass all effects by pressing the LED below FX button
⁃ Lock FX while browsing
⁃ Move effects within effects rack by dragging
⁃ New FX Unit Preset steppers
• New Sharing Options
⁃ Easy Sound/Project Sharing for collaborators and third party libraries
⁃ Publish Library feature allows users to easily export a library in a single .trilian package
• Improvements/Special Features:
⁃ Improved authorization process
⁃ Redo/Undo functionality
⁃ New Clear All Browser Learns action on Utility menu
⁃ Mode Stack Mode Note Regions option for Key Splits in Live Mode
⁃ Global Clock Speed (Halftime, Doubletime, etc)
⁃ Live Mode: New Single Sound option added to MIDI CC Mode and Key Select Mode menus
⁃ Use mouse wheel to scroll over menus items
⁃ Enable mouse-wheel scrolling on mod target Bias Point note menu
⁃ Show indication of when a control is waiting for MIDI learn to complete
⁃ Enter Parameter Value feature
⁃ MIDI CC learn and host automation can now be used for parameters controlled by menus and radio buttons
⁃ Improved resolution of Attack, Decay & Release sliders
⁃ Increased resolution when using Shift key to adjust knobs/sliders values
⁃ Enlarge clickable region for some steppers to be more user-friendly
⁃ Adds up/down stepper arrows to Filter preset menu on Layer Page
⁃ Support for foreign-languages in patch names, tags, search, etc.
⁃ Utilize different tunings, including historical, microtonal scales and user-created temperaments
⁃ New System Pitch Options allows saving master tuning and scale selections in multis or host sessions
⁃ New Startup Directory menu allows you to select the Patch directory that is loaded at startup
⁃ Auto Recall option remembers the last library/directory from which user loaded a patch
⁃ New indicator on patch name showing if patch needs to be saved (asterisk after name)
⁃ Support for high-resolution CC values
⁃ Display Master Filter Frequency in Hz
⁃ Streaming improvements
⁃ Note Stealing improvements
⁃ macOS Big Sur compatibility
⁃ 64 Bit Only
* NOTE: Patches saved in Trilian 1.5 are not compatible with earlier versions.
Ich weiss ja nicht... Da hilft auch kein hübsches Jazz Fusion Video von Top Musikern.
Der Trilian verstaubt bei mir schon lange, ist ja ausch schon alt, das Teil.
Da gibt´s mittlerweile bessere Sample Lib Realo-Bässe.
Und auch Synthbässe können "richtige" VSTi Synths eh besser...
VST3?
Ergo: schwierig... aber gut, kostenlos.
ich nutze den Trilian sehr gerne, aber benötige nur einen einzigen Bass-Sound, der sitzt wie angegossen bei mir, danke für die Info :)
VST3?
Bei mir verstaubt es zwar auch, aber das liegt daran, daß alles irgendwie grad verstaubt, weil ich einfach zu busy bin. Aber Trillian hat vom Sound an sich nichts eingebüßt.
Die neuen Möglichkeiten erweitern doch das Soundspektrum enorm, da kann man auch schrauben ohne Ende. Ist doch keine reine Presetschleuder.
VST3 ist mir schnurzegal, weil Reaper mit VST2 VST3 gemischt bestens klarkommt. Ist ja nur ein Cubaseproblem. Ich finds cool, was die einfach so für free anbieten, wo andere SW Buden viel Geld für nehmen (naja, bzw Omnisphere 2 ist auch natürlich ein kostenintensives Update).
Nö. in Cubase läuft VST2 auch bestens...
Wird ja eh so kommen, mit den neuen Apple ARM Chips ist VST2 wohl dann eh in Rente und nur noch VST3, muss ja alles neu dafür geschrieben werden.
Das in erster Linie! Ist ne coole Firma die Spectrasonics. Wirklich umfangreiches Update.
Geil, so muss 'ne Produkt-Presentation aussehen. Superbe Musiker die einfach mal spielen, ohne sich in technischen Details zu verlieren.
Und das Update sieht auch massiv aus. Ein Grund mehr, Trillian wieder auf die Wunschliste zu setzen, wenn der Quatsch hier mal vorbei ist und es das Portemonnaie erlaubt.
