Sounds von Freund verwenden??
Hier mal die Lizenzbestimmung von Rob Papens Software, leider ist mein Englisch jetzt nicht so das allerbeste :D
The software is provided to the user "as is". Rob Papen and RPCX makes no warranties, either express or implied, with respect to the software and associated materials provided to the user, including but not limited to any warranty of fitness for a particular purpose. Rob Papen and RPCX does not warrant that the functions contained in the software will meet your requirements, or that the operation of the software will be uninterrupted or error-free, or that defects in the software will be corrected.
Rob Papen and RPCX does not warrant or make any representations regarding the use or the results of the use of the software or any documentation provided therewith in terms of their correctness, accuracy, reliability, or otherwise. No information or advice given by Rob Papen and RPCX shall create a warranty or in any way increase the scope of this warranty.
Rob Papen and RPCX is not liable for any claims or damages whatsoever, including property damage, personal injury, intellectual property infringement, loss of profits, or interruption of business, or for any special, consequential or incidental damages, however caused.
The user is not allowed to distribute the program. Further, the user may not modify, the user may not decompile and the user may not debug the software.
Sounds provided within the Rob Papen and RPCX software are also licensed to the user "as is" with the same terms and the additional term that the user may not copy or sample sounds for distribution use.
Copyright Rob Papen ConcreteFX 2005
Wer weiß was? Der letzte Satz spricht ja die Sounds direkt an !
wenn ich schreibe:
"WENN nichts in der lizenzvereinbarung steht, dann kann ichs auch verwenden"
muß ich gar keine Lizenzvereinbarung kennen, sondern ich muß lediglich die Lizenz der Software die ich verwenden möchte LESEN.
und der satz :
"ich weiß nicht ob die antwort wirklich spekulativ ist"
ist eine sog. suggestivfrage bei der die antwort (in diesem fall "nein") bereits feststeht.
(ist auch nicht als gegenangriff gemeint)
Die Lizenz ist ein Recht, die Software zu benutzen.
Das, was du lesen kannst, IST die Lizenzvereinbarung.
@Arves
"the user may not copy or sample sounds for distribution use"
tja...sehr schwammig.
also die einzelnen sounds darfste nicht verteilen/verkaufen.
aber wie soll man die dann überhaupt in kommerzielle tunes einbringen?!
@thilo
"muß ich gar keine Lizenzvereinbarung kennen, sondern ich muß lediglich die Lizenz der Software die ich verwenden möchte LESEN."
das ist das selbe.
Ich würde -sofern keine Informationen der Demo beiliegen (sollte aber eigentlich der Fall sein)- beim Hersteller anfragen.
Ohne explizite Erlaubniss wird das denke ich erstmal illegal sein, da du mit einer Software, die dir nicht gehört ja nicht einfach machen kannst, was du willst.
Beim Kauf erhält man ja eine Lizenz, die einen berechtigt diese Software für dies und das zu verwenden (übrigens gibt's auch da teils ganz komische Einschränkungen .. ich meine mich da an irgendeine recht fragwürdige Klausel bei EW zu erinnern).
Naja ... am besten warten wir wirklich auf EarlGrey, der wird das wahrscheinlich sicher sagen können.
Ja das wäre super, wenn er da was weiß!
also bei Zebra2 steht ganz klar bei man darf die Demo nur dazu nutzen um sich von dem Produkt zu überzeugen, alles andere ist verboten. Jedoch sind derart klare Ansagen bei anderen [g=8]Plugin[/g] Demos zu vermissen!!
- Albino, Blue von Rob Papen
- Sylenth 1 von Lennard Digital
- Arturia Demos
- Vanguard von Refx
- Native Instruments Demos
von reFX darf ich zb nichtmal auszüge des manuals posten...schade. aber schaut mal rein; es ist von einer license agreement die rede, welche ich nirgends finden kann.
beim lexiconPSP42 [g=8]plugin[/g] steht zb:
"The DEMO VERSION of the SOFTWARE is NOT
LICENSED FOR COMMERCIAL USE."
was indirekt bedeutet, dass ich die hauptversion kommerziell nutzen darf? muss ja... aber drin stehen tuts nirgends.
aiaiai...
im endeffekt scheinen mir plugins wie "werkzeuge".
womit die zusammenarbeit mit einem bekannten, der seine 10000EURO vstis über meine [g=32]midi[/g]-patterns laufen lässt eigentlich kein problem wäre. wenn ers auf seinem PC tut.
aiaiai²...
