größeres Free Update Cubase 10.5.20 ist raus (alle Versionen)
  • Ersteller Ersteller Gast92251
G
Gast92251
Guest
10.5.20 is one of the biggest Cubase maintenance updates of recent years.
It introduces many small but useful new features, such as additions to Range Editing, new customization options, helpful enhancements to its tools and capabilities as well as numerous fixes.
Our clear recommendation is for users of Cubase Pro, Artist and Elements on version 10.5 to read the Release Notes for a detailed description.
DOWNLOAD:
https://www.steinberg.net/en/support/downloads/cubase_105.html
The update is available for download in the Steinberg Download Assistant,
which should already be installed on your system. If not:
https://www.steinberg.net/en/suppor...966.466148266.1590489941-676577501.1580915867
NEW FEATURES
New Range and Event Editing functions [Pro/Artist]
We have added some new functions to the Range Editing menu: Range to Next Event/Range to Previous Event, Enlarge Range to Next Event/Enlarge Range to Previous Event, Cut Head/Cut Tail, and Set Spacer between Selected Events. Cut Head/Cut Tail can especially speed up your audio cleanup workflow. There are no default key commands assigned to these functions, so feel free to adjust them to your workflow.
Plug-in Report [Pro/Artist/Elements/LE/AI]
After the issues that some of you had with third party plug-ins following the latest OS updates, we have added the option to create an extensive plug-in report in the VST Plug-in manager, with detailed information about your system’s installed plug-ins,. The report can be used to help with troubleshooting or to create an overview of the plug-in installations on your system when not running Cubase.
Safe Start Mode after unexpected exit [Pro/Artist/Elements/LE/AI]
In the same vein, if Cubase quits unexpectedly, when you re-start the application the Safe Start window now shows automatically, which will help to point you to the source of the problem - whether Cubase, plug-ins or something different. Safe Start gives you a general first indication what went wrong and can help you to decide on further troubleshooting options. You can also easily locate the crash report from within this window.
Colorize Selected Channels [Pro/Artist/Elements/LE/AI]
Colorized mixer channels were a longtime feature request and we have received a lot of feedback about this feature since its introduction in Cubase 10.5. In Cubase 10.5.20 you will now find a new Show Color for Selected Channel option in the User Interface preferences, which allows you to highlight the selected channel by colorizing it.
Key commands added for Grid Types [Pro/Artist/Elements/LE/AI]
We have added new key command menu options for selecting specific grid types. This is very handy if you are creating your own macros which include switching grid types. Again, these commands are not assigned as defaults. You can find them in the Edit category. Use Quantize and Adapt to Zoom will also work with the same assigned key command in the MIDI Editors.
Use Video Follows Edit mode no longer shortens the Project Cursor [Pro/Artist/Elements/LE/AI]
The Project Cursor is now shown at its full size in Use Video Follows Edit mode.
Remove Multiple Busses [Pro/Artist/Elements/LE/AI]
You can now remove multiple input or output busses at the same time in the Audio Connections window. This is really useful if you are working with a lot of inputs and outputs.
Enhanced Direct Offline Processing [Pro/Artist/Elements/LE/AI]
The Direct Offline Processing window now allows you to reset audio processes to their default settings.
Adjustable Event Opacity [Pro/Artist/Elements/LE/AI]
The new Event Opacity preference allows you to customize the visibility of the event background.
Improved Editing for Level Meters [Pro]
You can now customize the appearance of level meters for all available scales.
THERE ARE ALSO SOME GENERAL CHANGES THAT YOU SHOULD BE AWARE OF
Preference 'Suspend VST3 plug-in processing when no audio signals are received' will be switched off by default [Pro/Artist/Elements/LE/AI]
In Cubase 10.5.20 this preference (in VST/Plug-ins) will be switched off by default. This eases some technical compatibility issues with third party plug-ins and can improve the general ASIO load. We recommend leaving it switched off for now.
Improved MIDI Clock Latency Compensation [Pro/Artist/Elements/LE/AI]
Sending MIDI Clock to external MIDI devices now works more reliably. Latency is now consistently compensated when using higher ASIO buffer sizes and also in situations where latency-inducing plug-ins are inserted within the audio signal path (important when working with external instruments). Furthermore, locating the project cursor at various positions and exporting or rendering audio from external instruments synced to MIDI Clock has been improved.
Frequency plug-in - compatibility note [Pro]
We have fixed two bugs which can slightly alter the sound of the plug-in:
If you have used a band set to Notch, it did not work correctly with Phase Linear mode enabled for this band. Also, setting a band from Peak to Notch updated the UI, but not always the internal processing. Please review instances of Frequency in case you notice audible differences.
WE HAVE CORRECTED THE FOLLOWING FEATURES AND FUNCTIONALITY
Editing
The Range Tool wasn't working as expected in Use Video Follows Edit mode.
Muted audio events in audio parts in the Project window would not show as muted.
Import and Export
Importing tracks via Track Archives lost their Expression Maps.
Importing multiple audio files with varying sample rates into a project at the same time was not working correctly.
File Type Settings in the Audio Export Mixdown were not remembered.
Importing Tempo Track data via an .smt file could create an invalid project after saving.
MIDI Effects
The Step Designer would not remember MIDI CC setups.
Automating the MIDI Gate bypass parameter was not working correctly.
MediaBay
MIDI files with the file extensions .mid or .midi were not displayed correctly.
The favorites list in the MediaBay was not sorted alphabetically.
MixConsole
The Pre/Post indicator line for insert effect slots was not retrieved correctly when loaded from a Track Preset.
Send slot assignments could disappear after opening a project and recalling a MixConsole snapshot.
Input routing was lost after undoing a recall of a MixConsole snapshot.
The MixConsole context menu could not be opened in the fader area.
Various MixConsole key commands were not available in Cubase AI/LE/Elements.
Plug-ins
Using automation for the Reset Delay parameter in the MultiTap Delay did not work as expected.
The waveform parameters in Chorus and Studio Chorus were not saved in projects.
Automation of linked parameters in the MultiTap Delay did not work correctly.
The Manual mode in Mod Machine did not work correctly.
Sidechain did not work in the Multiband Compressor when Live mode was enabled.
Audio procession was inconsistent between the Magneto plug-in and its Channel Strip version.
Sampler Track
The language of the Sampler Control tab differed from the language used in the application.
Sharing projects across different platforms and systems that contained Sampler Tracks could result in audible artifacts or no sound at all.
Using Solo mode in the Sampler Control Zone could result in no sound.
Score Editor
The Bars field in the Score Editor was working as expected when using "Split Multi-Rest".
Editing the page text could render the application unreliable.
Ornamentation appeared when editing several instruments.
User Interface
We resolved several contrast issues with black text on a dark background (e.g. when using the MacOS dark mode)
The Windows taskbar could hide parts of the application when the taskbar was placed at the top.
The color settings in Preferences/User Interface were not migrating correctly from previous versions or were not retrieved correctly via Preferences presets.
VST Instruments
Clicking the Output Bus selector for VST instruments loaded as Rack Instruments could render the application unreliable.
Removing the Reason Rack plug-in from a project could render the application unreliable.
The routing of disabled instrument return channels was incorrect after loading a project and enabling them again.
MIDI port routing was lost after enabling disabled MIDI tracks routed to VST Instruments that support multiple input ports.
Miscellaneous
Selected file types in Open File… windows were not remembered correctly.
Using Rewire could render the application unreliable.
Configured MIDI Clock destinations were not saved and retrieved correctly with the application.
Using [Shift]+[T] for Enter Tempo did not work.
The video export has been further stabilized
Die Version 10.5.20 ist kein gewöhnliches Wartungsupdate, es ist eines der größten Cubase-Wartungsupdates der letzten Jahre. Mit diesem Update bekommt Cubase viele kleine, aber sehr nützliche neue Funktionen, wie z.B. Ergänzungen für "Auswahlbereich bearbeiten", neue Anpassungsoptionen, hilfreiche Optimierungen von Tools und Funktionen sowie zahlreiche Korrekturen.
Wir empfehlen allen Usern von Cubase Pro, Artist und Elements die Release Notes zu lesen, um detaillierte Informationen zu erhalten
https://new.steinberg.net/cubase/re...348.466148266.1590489941-676577501.1580915867
Vieles aus Nuendo dabei, sehe ich gerade. Hoffe, dann folgt N´ Update bald.
Hört sich gut an. Weiter so Steinberg!
immer noch keine funktionierende Skalierung, ich kann nimmer...
...den Safe Start Mode finde ich gut, dass die das mit der Skalierung nicht hinbekommen, behindert leider immer noch meine Rückkehr zu Cubase...:(
...allerdings tendiere ich langsam wieder zurück zu 2x HD 24,5" oder 27", anstatt 1x 4k 40" !
...hat nochmal einer nen Tipp?....ich weiß, ich bin verrückt!:D
...ich kann den Wunsch nach getrennten Monitoren nachvollziehen, hast du schon mal an eine unsymmetrische Lösung gedacht? Da wird es bei mir wohl hingehen, ein TV Screen als Hauptmonitor und sowas kleines, zum rüberziehen von Tools oder Plugins, als Zweitmonitor, direkt auf dem Tisch:
https://www.ebay.de/itm/15-6-Zoll-I...-PC-HDMI-USB-Tape-C-Lautsprecher/383450326248
den grossen Monitor möchte ich nicht missen, aber was separates zum optischen "Auslagern" ist schon nicht schlecht...
nee, Danke!
Cubase ist entweder zu klein, oder zu groß und die Wellenform Darstellung unscharf... lange Geschichte.
Es geht im Moment nur HD vernüftig, und da suche ich mal Vorschläge was man da nimmt. Ich habe noch einen 32" wqhd, das probiere ich noch!
Mache doch deinen alten Thread auf :D
Ich kann mich mit meinem 38“ curved nicht beklagen, aber ich brauche auch noch nicht skalieren. Oder vermisse ich da was? Ich hatte vorher 27“ und 30“ nebeneinander, das will ich nie wieder haben.
Aber zum Update. Das Highlighting ist ja mal eine coole Idee, wundert mich nur, dass das nicht gleich mit eingeführt wurde. Sehr gut gefällt mir auch der Transparentmodus für die Events.
Ja, 32" und 27" nebeneinander wäre mir auch zu wuchtig.
Hast recht mit dem Thread, ich will diesen hier auch nicht zumüllen!;)
Gerade installiert und noch bevor ich einzelne neue Punkte ausprobieren kann:
Laden bei euch Projekte aus der Vorgängerversion auch so extrem langsam? Was´n da los?
Hier ein übersichtliches Video zum Update:
@koffein-junky
Schau mal im Video ab 12:05, wenn Du auf Win bist, muss für den Betrieb mit 10.5.20, die Visual C++ Library neueren Datums sein!
Ist dein 38" ein 16:9 oder 21:9 Monitor? Ich habe auch vor mir demnächst einen neuen zu kaufen. Ich schiele da auf einen UHD -Monitor 32". Mehr Platz habe ich leider nicht.
tue es nicht! ☝
Das lohnt absolut.
Habe ein 38 Zoll Curved TFT, ganz normale Cubase Einstellung, ohne den bescheuerten HD Schnickschnack - alles top & vor allem schön viel Desktop-Platz!
tu es!
(es sein denn...du sitzt wirklich weit weg vom Bildschirm...) ^^
Das lohnt absolut.
tu es!
Ja, 38" Widescreen ist gut, aber 16:9...vergiss' es!
ok! verstehe.
Wobei die Pixeldichte (nicht Pixel Anzahl) da ja mit entscheidend ist.
Was bei sehr grossen TFTs, hier dein genannter 16:9er, alles dann von vornerein kleiner darstellen lässt, weil eben die Pixel selber kleiner sind. So dass man, Apple "sei Dank" mit Einführung des "Retina Trends", in der Tat auf HD GUIs umschwenken muss, damit man überhaupt was sieht...
Pah, kein Bock auf den Stress. Du hast ja berichtet von deiner üblen Odyssee dbzgl. Alles halbgar.
Da nehm ich lieber einen etwas kleineren Bildschirm oder multiple TFTs. Und ganz normale DAW Darstellung. Damit ist man sicher.
Auch gerade wenn man > ältere nicht HD kompatible (!) Plugins hat.... Kennt man, auch ein sehr ärgerliches Thema.
Okay, ist separater Thread, stimmt.
21:9. Sicherlich sollte man sich über das Seitenverhältnis vorher einen Kopf machen, war auch meine Intension, dass da was fehlen könnte. Mir war die Breite wichtiger als die Höhe. Bei Foto, Video und natürlich DAW vermisse ich nach 8 Monaten nichts.
Ehm, wenn ich "Bereich zum nächsten Event" und die darunterliegenden Menüpunkte benutze passiert gar nix. Ist im Video bei 7:40. Ist das bei noch wem so?
