Studio One 4 – Version History and Release Notes
This document lists all Studio One 4 maintenance updates and their included fixes and improvements.
Version 4.1.2 Release Notes (January 15, 2019):
New features and Improvements:
- AAF export now compatible with Digital Performer 9 (legacy mode)
- AAF volume automation support for Pro Tools
- Alternative incremental workflow for Song Versions
- Quantize Macros now work without forced Auto-Quantize
- Safety query for resetting recent song list
- Tempo Warp in arrangement now updates the editor display
- Better error handling in case of product activation failure
The following issues have been fixed:
- Groove Quantize always affects velocity
- Sustain parameter is continuous for stock instruments
- Drawing Automation backwards doesn't work correctly
- Tempo ramp causes audio artifacts
- [AAF] Event gain not translating into Pro Tools clip gain
- Wrong English translation "Quintole" and "Septole"
- [Impact XT] Clear Bank and Pad do not clear parameters
- In certain cases, Melodyne won't sync to Song tempo
- [Tempo Track] 'Delete Range' inserts unwanted Time Signature change
- Relative movement of two adjacent notes no longer possible
- Inconsistency when using “Select Notes...> Select at interval” command
- Notes played in precount/preroll have incorrect length when recorded
- Timestretching kills transients when Tempo Track is used
- Notes recorded before active loop are shifted to left locator
- Redraw error in Pattern Editor controller lanes
- IR Maker help page text not legible
- [macOS] Remove "Release audio device in background" option (Windows-only feature)
- [macOS] Some keyboard shortcuts ignored when editing text in Track or Channel Name field
- [macOS] Holding cmd+w opens multiple dialogues, crashes on confirmation
- Splice license conflict w/ previous Artist activation on same account
- Crash on hitting "Return" key when assigned to Navigation > Enter
- Waveform graphics rendered with half-sample offset on bounce
- Track notes don't persist through transform operations
- “Delete external device” dialog lacks confirmation
- Mouse scrolling doesn't work on mixer inserts
- Crash when switching editor from melodic mode to drum mode at small window sizes
- Right-click mouse state not reset when loading a song version from recent list
- Freeze on zooming beat-linear audio parts in and out repeatedly
- Switching to another Song Version can break the Project < > Song connection
- When the editor is detached, deletion of selected notes will delete containing part
- [Scratch Pad] note length value jumps to unexpected value while modifying in Inspector
- Wrong Track order when duplicating Track with mouse
- Crash when opening "Tracks" node in file browser on certain songs
- MIDI Markers not embedded into MIDI files (when using “Save As”)
- Warp Marker editing causes glitches
- Exchange update button hard to read in light mode
- Unwanted scrolling in arrangement when editing Event in Folder Track
- Crash on 'Select from event till end'
- Crash when removing Splitter from fx chain
- Ripple Edit in Folder causes Track to shift
- “Split At Grid” broken when Event is located at a specific position
- [Project Page] Album / Artist text fields lacking contrast on edit when light theme is used
