Verschobene Mitte im Stereo Bild
  • Ersteller Ersteller daslicht
  • #41
No, panels are odorless. I feel as if there wasn’t enough air in the room. In addition to that, my eyes get a mildly irritated that I need to wash them. It is very frustrating as I purchased 8 packages of WGL 035 and 4 of WGL 040, and I can’t enjoy them. Did you do something before installing them in your room. ?
Do you mean the fealling of silence ? I think it is when the damping / absorbtion is to much.
I also have that here, but meanwhile I am used to it.
Probably i wil cover the walls some day with something to improve this but I don't have the resources yet.
my eyes are fine with the isobond. You are sure that you have isobond ?
I haven't threaten the panels in anyt special way, I just cut and mounted them.
  • #42
Let's say I stay in the living room with 1 panel uncovered for 1 hour, then I start feeling there is no air. Once this sensation of no air kicks in, it takes hours or 1 complete day to disappear.
Sure it is isobond, I've got it shipped from Germany, it takes from 20 to 30 days, but they arrive.
I'm thinking they probably mold spores or something. I'm thinking to vacuum clean one outside the apartment and then apply anti mold spray. If no results, then Im going to cover them.
Thanks for the information. I was thinking you applied something before placing them in your room which by the way looks very nice. I probably contact Caruso directly to see if I have further options.
thanks,
Francisco.
  • #43
Ich habe übrigens das gleiche problem.bin auch ständig am boxen drehen... wobei ich glaube, dass der fehler bei mir auch am interface liegt, da es sowohl bei den boxen und Kopfhörern auftritt, meine frau kann es ebenfalls hören, also nix mit meinen ohren. Manchmal verschiebe ich auch einfach den master pan um 2 bis 5 werteinheiten nach rechts
  • #44
Meist kann man ausschließen, dass es ein technischer Fehler ist, wenn man nicht selbst irgendwo was verändert hat.
Das wichtigste: Mit einem Laser-Entfernungsmesser den Abstand von z.B.: Brustmitte am Hörplatz zum Hochtöner messen und Lautsprecher genau ausrichten.
Bei Speaker mit Potis/Regelung:
Eine Mittenstellung (Rasterung) ist nicht immer wirklich der exakt gleiche Pegel von Box zu Box.
Ein Unterschied von z.B. 0,3dB reicht aus um eine schiefe Bühne zu hören. Ebenfalls werden bei kommerziellen Produkten keine Lautsprecher paarweise abgestimmt, was ebenfalls zu solchen Effekten führen kann.
Reaktionen: daslicht
  • #45
thanks,
Francisco.
I apologize that I cant help you here, please write to caruso and askthem regarding your assumptions. I hope that helps somehow. After writing them , you atleast know if they have treaten the panels with something chemical. I doubt tho. :/
  • #46
Hast du so nen Lautstärkekontroller in Verwendung ? Ich habe meinen TC Levelpilot mittlerweile verbannt, da er das Stereobild total verhunzt. So nen boxhenständer bei dem ich die boxen frei 3d bewegen könnte wäre toll :)
