NoisiaTHX
Bei den Propheads rappelts im Karton. Auf synthtopia.com erschein und verschwand eine Ankündigungen zu Reason 9. Trotzdem wurden schnell einige Infos zusammengetragen und im WWW verstreut. So soll nun endlich ein Audio to Midi Converter hinzu kommen. Ich bin gespannt.
Am 21. Juni soll es so weit sein.
https://www.kvraudio.com/forum/viewtopic.php?p=6462195
Here’s what’s new in Reason 9:
Reason 9 introduces three Player devices, designed to transform MIDI input:
Note Echo creates rhythmic, pitched MIDI delays for melodies, drum rolls, and more.
Scales & Chords turns simple melodies into beautiful harmonies and chords so you can stay focused on the music making. Transpose notes to a selected scale and automatically generate chords for your song, no music theory required.
Dual Arpeggio transforms chords into intricate and inspiring rhythms. From classic up-and-down to polyphonic and polyrhythmic, Dual Arpeggio breathes new life into any instrument in your Reason rack.
Reason’s new Pitch Edit mode helps you fix out-of-tune notes, add vibrato, change timing, create new melodies from your recording, change the dynamics and more.
Audio to MIDI lets you convert your vocals to MIDI notes for endless sound manipulation possibilities.
Reason 9 also comes with 1000 new sounds. The Reason Rack is also enhanced with key workflow improvements and darker theme options.
https://twitter.com/PropellerheadSW/status/731042349355270144
