Kainer
http://reaper.fm/ bzw. http://reaper.fm/download.php
UserGuide ist auch schon aktualisiert:
http://www.cockos.com/reaper/userguide/ReaperUserGuide414C.pdf
v4.14 - December 18 2011
+ Audio Units: improved support for plug-ins that use unordered parameter IDs
+ Envelopes: added option to not show affected envelopes when moving items across tracks
+ Grid navigation: fixed for ts changes and larger grid divisions
+ JS: updated IX effects
+ Media buffering: option for lower buffer size when per-take FX open (to reduce visual lag)
+ Media explorer: option to go to next item at end of preview
+ Media item fades: optional handles for editing fades when the media item is small
+ MIDI: improved merging of multiple MIDI sources (glue, receives, record output)
+ MIDI: looped overdub recording fix for crash bug (issue ID 3807)
+ MIDI editor: actions to remove trailing (or all) notes of less than a certain length
+ MIDI editor: fixed odd behavior when option enabled to snap notes to the left
+ Mouse modifiers: adjust envelope bezier curvature for all selected points at once
+ Mouse modifiers: fix for painting a straight line of notes over an existing note
+ Mouse modifiers: select all MIDI notes touched while dragging (ctrl+alt+right-drag by default)
+ ReaScript/API: fix for getting track mute and selected state
+ ReaScript: overhaul, many internal changes
+ ReaScript: Perl support removed for now
+ ReaScript: Perl support will come back when/if http://gitorious.org/perl-ctypes is completed
+ ReaScript: see Help/HTML lists/ReaScript documentation for more information
+ ReaScript: better error reporting
+ ReaScript: more flexible Python support, should work with almost any version of Python on any platform
+ ReaScript: set current script directory as start of path (look for modules there first)
+ ReaScript: support for importing one ReaScript module into another
+ ReaScript: support for setting a custom external editor for .py files (Preferences/External Editors)
+ ReaTune: new instances on per-take FX will operate in item-space rather than in project-space
+ ReaTune: resizable user interface, many UI improvements
+ Regions: improved handling of envelopes when moving/copying regions
+ Ripple editing: improved handling of envelope points, MIDI items, tempo changes when removing time
+ Ruler: improved display relating to time signature markers and tempo ramps
+ Tempo maps: improved tempo map editing behavior
+ Theming: button overlay images now inherit scaling attributes from the underlying button image
+ Theming: WALTER added reaper_version (example: 414) and mcp_maxfolderdepth
+ Time maps: fixed snapping bugs with ramped tempos and varying time signatures
+ Video: improved video frame display speed when seeking
+ VST: allow loading of OSX GRM plug-ins version 3.1.1 or higher (earlier versions crash)
+ VST: fix for occasional blank UI for Celemony plugins
