Reaper Pre-Versionen Thread! (v2.5rc2)
+ [removeme alpha3]: dynsplit updates
+ [removeme alpha3]: made shift+clicking mute/solo override groups
+ [removeme alpha3]: made automation mode grouping work correctly
+ [removeme alpha3]: track group settings will automatically create group if no tracks were grouped
+ [removeme alpha3]: track group settings prompts if multiple groups were selected
+ [removeme alpha3]: reverse-pan mode (can set per track), group settings is now shift+G
+ Render stem actions now render pre-fader signal, new actions for old post-fader stems behavior
+ Prefs/Keyboard is back, has link to actions window
+ Option to disable alt key opening menus in main, [g=32]midi[/g] editor, mixer windows
+ Added actions to set/adjust arrange view grid
+ Screenset window now updates shortcuts when using alternate recording section
+ Fixed touch automation on track mutes
Alpha4:
+ better ganged/grouped vol/pan fader behavior
+ relative levels on grouped faders when recording automation
+ [removeme alpha4]: fixed rex normalization
+ [removeme alpha4]: more dynsplit updates
+ [removeme alpha4]: inverse-voluem grouping mode
+ [removeme alpha4]: note: don't get too used to the track grouping system now, it will likely get an overhaul that won't be backwards compatible, before the release
Alpha5
+ [removeme alpha5 updated]: changed move by QN to move by grid, fixed
+ Fixed relative grid actions in [g=32]midi[/g] editor showing display
+ Fixed auto-add of envelope setting initial (t=0) value
+ Fixed crash on JS with only outputs and opening pin manager
+ added actions to move items left/right by QN
+ Improved threadsafeness of media creation and [g=357]peak[/g] cache system
+ [removeme alpha5]: dynsplit dialog is now modeless
+ [removeme alpha5]: dynsplit splitting updates
+ [removeme alpha5]: added dynamic split mode to apply minimum [g=35]slice[/g] length L->R
+ [removeme alpha5]: ensure dynamic splits are always at zero crossings
Alpha6
+ New vca_master and vca_slave JS fx
+ [g=32]MIDI[/g] media items no longer reset CCs at end, just pitch and notes
+ Fixes for tab to transient and zero crossing detection for heavily stretched items
+ [removeme alpha6]: dynsplit properly recalculates if items are moved or resized
+ Action: extend selection to next transient in selected items
+ Action: detect tempo, create measure from time selection (new or current time signature)
+ Shift+3/4,5/6 now map to item rate changes (10-cent, semitone), clearing preserve pitch
+ Actions to adjust item rate while clearing preserve pitch
+ Actions to set/clear item "preserve pitch" setting
+ Improved threadsafeness of media creation and [g=357]peak[/g] cache system...
Alpha 7
when slave" alpha7 update
+ [removeme alpha7]: grouping has "No Master When Slave" flag (meaning it prevents that group from being mastered when slaved from another group)
+ [removeme alpha7]: total grouping overhaul, now there are 32 groups with each having master/slave controls for many parameters
+ [removeme alpha7]: routing matrix can now show routing or grouping, modeless grouping properties window for mass editing track groups
+ [removeme alpha7]: added "restrict splits" checkbox, made multi-item split reduction show full split counts/etc,
much better edit behavior on editing this box, other potential fixes throughout (---------> fear the bool usage, !! is your friend :) <----------- )
+ [removeme alpha7]: fixed clear search box button
+ Prefs/editing behavior: slider for tab-to-transient sensitivity
+ [removeme]: Create measure from time selection now always starts a new measure
Alpha 8
+ [removeme alpha8]: fixed group ui bugs introduced in the "no master
Alpha9
+ [removeme alpha9]: Group renaming
+ [removeme alpha9]: Fixed media removed while offline coming back online with old metadata
+ Fixed GDI leak in ReaEQ added in 2.42 (nyquist line drawing)
+ [removeme alpha9]: loading missing effects now shows track numbers
Alpha10
+ [removeme alpha10]: Group window now remembers last position
+ [removeme alpha10]: Tracks grouped as master+slave now have solo/mute/polarity/recarm toggle (meaning all get toggled rather than set to the same value)
+ Routing/track matrix tooltip updates
+ [removeme alpha10]: Bugfix in create measure from selection (new time signature)
+ [removeme alpha10]: Fixed vol/pan trim when in write automation but no envelope and no envelope auto-add
Alpha11
+ Improved behavior of preference to not allow projects to override audio hardware sample rate
+ [removeme alpha11]: Groups now display a themeable color on the controls they affect
+ Saving a project with copy/move that has media loaded into ReaSamplomatic and ReaVerb now copies that media to project directory
+ New JS delay_sustain effect
+ Routing matrix: fixed some scrollbar bugs
+ Glue: glues items to project samplerate if project samplerate is set
2.47pre1
+ New action and default binding (Ctrl+Alt+G) for grouping matrix
+ [removeme pre1] track matrix: better headers, better click/right click on matrix header stuff, etc etc
+ [removeme pre1] groups can be disabled, and global group disabling is now separate from the item group disabling
+ [removeme pre1] restore [g=32]MIDI[/g] editor note row display state when reopening a project
+ [removeme pre1] fixed REX smooth style sample drawing
+ Fix for ReaNINJAM problems introduced in 2.45 ([g=223]ogg[/g] end of stream behavior)
+ Option in Prefs/Appearance to allow choosing group display modes (lines, ribbons, [g=337]none[/g])
+ Actions to select all tracks in groups 1-32
Mal abgesehen von den Bugfixes scheinen mir die Änderungen von Release zu Release nur marginal zu sein. Was mir noch fehlt (nicht ein must-have, aber ganz nett) ist Dolby Surround und ein Noteneditor. Aber das ist nicht so auf die schnelle zu implementieren. Ich hoffe, der Entwickler hängt nicht zu sehr an seinem 6 wöchigem Updaterythmus, denn das lässt keine Zeit für wirkliche Neuerungen.
das ist hier der pre- release thread - also alpha/betatesting versionen.
"Dolby Surround und ein Noteneditor"
da würde ich nicht die luft anhalten. wenn du das ernsthaft brauchst, solltest du dir sibelius und nuendo oä. anschauen.
wenn es nur darum geht, ein [g=32]midi[/g] file mal in noten-ansicht anzuschauen, gibt es diverse kleinere tools.
lG f
Das wird es zu99,9% nicht geben, warum?
Dolby Laboratories ist eine ganz normale Firma und keine Foundation, wenn der Codec bei Reaper dabei wäre dann müssten sie für jeden Download! (Nicht für jede verkaufte Lizenz!) eine Lizenzgebühr entrichten, das wäre bei der riesigen zahl der Downloads das Finanzielle aus für Cockos!
Das ist übrigens auch der grund warum kein mp3 encoder dabei ist, und man sich diesen Händisch nachinstallieren muss!
Gruss...
P.S. Nuendo ist übrigens gerade für 1749,- im angebot! (Nein kein Witz!)
v2.5rc1 - September 16 2008
BIG STUFF
+ Uber track control group support (shift+G defaults to show group settings, Ctrl+Alt+G shows new Track Grouping Matrix)
+ REX2 file support, imported slices keep beat location if project tempo changes (todo support moving items across tempo changes, currently slices must be re-imported)
+ Dynamic Split interactive beat slicing and quantization
NEW GOODIES
+ Action: detect tempo, create measure from time selection (new or current time signature, one bar or many)
+ Action: extend or swap selection to next transient in selected items
+ Action: move items left/right by grid
+ Action: set/adjust arrange view grid size
+ Action: move cursor to next/prior zero crossing (Z, shift+Z by default)
+ Action: split item at prior zero crossing (alt+Z by default)
+ Action: adjust item rate while clearing preserve pitch
+ Action: set/clear item "preserve pitch" setting
+ Action: select all tracks in groups 1..32
+ Action: create chromatic [g=32]MIDI[/g] notes from selected items
+ JS: [g=123]utility[/g]/volume_pan with parameter smoothing (for use with param modulation)
+ JS: [g=123]utility[/g]/phase_adjust now handles stereo (phase rotates each [g=190]channel[/g], not the stereo image)
+ JS: delay_sustain effect
+ JS: vca_master and vca_slave for emulating [g=208]VCA[/g]-style control using audio routing
+ New mute and solo button context menus with toggle/exclusive/clear options
+ Add-FX dialog: remembers recent searches in dropdown list
+ [g=32]MIDI[/g] editor: rename current [g=32]MIDI[/g] take from [g=32]MIDI[/g] editor menu
+ Routing matrix: fixed some scrollbar bugs, improved tooltips, added track grouping view
+ Option in Prefs/Appearance to allow choosing track group display modes (ribbons, lines, [g=337]none[/g])
SUBTLE IMPROVEMENTS
+ Better pooling of media file resources for better RAM use (especially with lots of splits)
+ Better automatic track naming, updating of UI on autoname
+ Better pooling of pitch shifter resources (track-pooled to avoid excess reinitializations)
+ Undo system: reduced memory use throughout (better granularity etc)
+ WavPack: updated to 4.50, fixed bug in metadata reading, BWF tag read/write
+ Recording volume/pan automation with ganged/grouped tracks is now supported
+ Better ganged/grouped vol/pan fader behavior (relative levels not lost at extremities)
+ ReaEQ: better deferred display updating, uses LICE bitmaps (todo: full LICE conversion)
FIXED SHIT
+ MCP: multiple track selection follows MCP track order and visibility
+ Shift+Click for time selection behaves better with snap and other options
+ Shift+Click for [g=415]loop[/g] selection in ruler now works correctly when time+[g=415]loop[/g] selections locked
+ Fixed GDI leak in skinned-scrollbar code
+ Restore [g=32]MIDI[/g] editor note row display state when reopening a project
+ AU: update generic UI on factory default preset loading
+ [removeme rc1] fixed a skinned scrollbar leak
+ [removeme rc1] made ribbon group display mode display master/slave, and made it default, updated lines mode too.
+ [removeme alpha8]: fixed group ui bugs introduced in the "no master when slave" alpha7 update
much better edit behavior on editing this box, other potential fixes throughout (---------> fear the bool usage, !! is your friend <----------- )
+ [removeme alpha4]: inverse-volume grouping mode
2.5 rc2
+ [removeme rc2] Track grouping ui updates for osx
+ [removeme rc2] Fixed hang when creating a new tempo marker >0.25 and <0.5 seconds from the prior marker
+ [removeme rc2] added action for nearest transient
+ [removeme rc2] optimized group indicator drawing
4K
12K
R
