Modartt: Pianoteq overview
Pianoteq
Version 99.0.1 (15.10.2025)
- (iOS only) Dark mode support for the app icon.
- Note: iOS version is not yet available on the appstore, hopefully won't be long.
- New instrument: Triple Harp, added to the Harp instrument pack.
- Modern and historic grand pianos have been thoroughly updated.
- MKII and Vintage Reeds instruments updated.
- New 'Sombre' presets added to all grands.
- New 'Felt' presets added to historic grands (Kremsegg and Karsten packs).
- Improved pluck realism on Celtic and Concert harps.
- The CP-80 in KIViR.ptq has been seriously improved.
- Metronome sounds improved (4 choices).
- Native support for Windows on ARM.
- VST2 support removed.
- VST3 support now available on Linux (alongside Windows and macOS).
- Automatic migration of projects using an older major version of Pianoteq, when that version is not available. Requires host support: Cubase, Pro Tools, Logic Pro (except automation curves), DP, ...
- Full compatibility of Logic projects between iOS (using the AUv3) and macOS (using the AUv2), including automation curves.
- NKS2 support implemented.
- Up to 8 microphones can now be used in the updated Mics & Mix panel.
- Pianoteq STAGE users can now access the Mics & Mix panel and modify mixer settings.
- FX panel: equalizer now features 5 configurable bands.
- FX panel: ping-pong option added in delay effect.
- FX panel: low-cut parameter added to the reverb effect.
- Global Hammer Hardness parameter added.
- Hammer Tone control added (for STANDARD/PRO users, note-edit for PRO users).
- Velocity Offset control added (note-edit for STANDARD/PRO users).
- Thunder pedal added.
- Note FX panel: monophonic mode added, with legato and portamento options.
- The main windows can be freely resized by dragging its bottom right corner.
- New 'Tall' interface mode, in addition to the already existing 'Compact' mode.
- (iOS only) Added support for portrait orientation, and windowed mode.
