Pianoteq 9 erschienen
Neu in Version 9:
Pianoteq​
Version 9
9.0.1 (15.10.2025)
  • (iOS only) Dark mode support for the app icon.
  • Note: iOS version is not yet available on the appstore, hopefully won't be long.
9.0.0 (15.10.2025)
  • New instrument: Triple Harp, added to the Harp instrument pack.
  • Modern and historic grand pianos have been thoroughly updated.
  • MKII and Vintage Reeds instruments updated.
  • New 'Sombre' presets added to all grands.
  • New 'Felt' presets added to historic grands (Kremsegg and Karsten packs).
  • Improved pluck realism on Celtic and Concert harps.
  • The CP-80 in KIViR.ptq has been seriously improved.
  • Metronome sounds improved (4 choices).
  • Native support for Windows on ARM.
  • VST2 support removed.
  • VST3 support now available on Linux (alongside Windows and macOS).
  • Automatic migration of projects using an older major version of Pianoteq, when that version is not available. Requires host support: Cubase, Pro Tools, Logic Pro (except automation curves), DP, ...
  • Full compatibility of Logic projects between iOS (using the AUv3) and macOS (using the AUv2), including automation curves.
  • NKS2 support implemented.
  • Up to 8 microphones can now be used in the updated Mics & Mix panel.
  • Pianoteq STAGE users can now access the Mics & Mix panel and modify mixer settings.
  • FX panel: equalizer now features 5 configurable bands.
  • FX panel: ping-pong option added in delay effect.
  • FX panel: low-cut parameter added to the reverb effect.
  • Global Hammer Hardness parameter added.
  • Hammer Tone control added (for STANDARD/PRO users, note-edit for PRO users).
  • Velocity Offset control added (note-edit for STANDARD/PRO users).
  • Thunder pedal added.
  • Note FX panel: monophonic mode added, with legato and portamento options.
  • The main windows can be freely resized by dragging its bottom right corner.
  • New 'Tall' interface mode, in addition to the already existing 'Compact' mode.
  • (iOS only) Added support for portrait orientation, and windowed mode.
Reaktionen: gyn
Hört sich interessant an, muss ich mal testen, ob dieses statische, tote, das den Sound von denen immer ausgemacht hat, jetzt vielleicht verschwunden ist. Gesampelte Pianos klingen vielleicht nicht so facettenreich und dynamisch, aber meistens viel lebendiger. Das ist das Einzige, was ich bei Pianoteq noch vermisse.
Da bei der V9 auch einige V8-Presets dabei sind, z.B. vom Grand Steinway D, hat man einen direkten Vergleich.
Ich persönlich mag Pianoteq schon deswegen, weil man es so flexibel an jede Situation anpassen kann und nutze es deswegen auch live (mit der iPad-Version und einem 88-Tasten-MIDI-Keyboard)
Reaktionen: gyn
