Cubase 6.5.3 ist draussen!
  • Ersteller Ersteller Gast92251
G
Gast92251
Guest
August 8th, 2012
First fully supported maintenance update for Cubase 6.5 and Cubase Artist 6.5, which replaces the former 6.5.1 and 6.5.2 pre-releases.
Download:
Cubase 6.5.3 =
http://www.steinberg.net/en/support/downloads/downloads_cubase_65.html
Cubase Artist 6.5.3 =
http://www.steinberg.net/en/support/downloads/downloads_cubase_artist_65.html
The free 6.5.3 update sports the following improvements:
1) Tempo track: The user interface now remains responsive when the Tempo track is enabled.
2) MediaBay: Closing Cubase while a plug-in user interface or the video window is opened does no longer lead to a serious error.
3) Editing: Audio events no longer lose their “on top” status after being moved.
4) Editing: Hitpoint detection no longer results in different calculation results at 96 kHz.
5) Editing: Entering notes in the Key Editor with the info line displayed no longer renders Cubase Artist 6.5 unreliable.
6) Editing: Opening the Score Editor does no longer lead to an unexpected shutdown of Cubase Artist 6.5.
7) VST Expression: When using VST Dynamics events, no drop outs of other MIDI events on the track will occur.
8.) VST Dynamics: Placing different parts that contain VST Dynamics events on the same track now works as expected.
9) VST Dynamics: Under specific playback situations VST Dynamics events could translate to wrong velocities.
10) Surround: 5.0 surround audio files now import with a correct speaker configuration (LCRLfeLs).
11) Plug-in: When saving and loading Prologue presets, the fine-tune values are restored correctly now.
12) Plug-in: REVerence now shows the right location path to user-imported IR files.
13) MacBook Pro: When using a MacBook Pro with Retina display, the mouse-click behavior behaves correctly at all times.
* Please note that this list applies to Cubase 6.5 and not every entry may apply to Cubase Artist 6.5.
1) New HALion Sonic SE 1.6 version including the versatile MorphFilter effect, true multi-core support and a new key command window
2) RF64 file support allows for file sizes larger than 4GB
3) Nuendo Live project compatibility (Cubase 6.5 only)
Reaktionen: Beatback, BerrySchwarz und Saurus
Ah, danke!
Auch gerade drübergebügelt ...
Controller laufen, einstellungen wurden übernommen und sogar der installer hat gleich beide Versionen Cubase 32 und 64Bit und die neuen Halion Sonic SE in 32 und 64Bit in einem Rutsch installiert
Update leider fehlgeschlagen Error 1603 oder so ähnlich.
Ui, was´n dat? Bei mir hat´s auch ohne Probs geklappt.
Keine Ahnung. Aber die "alte" 6.5.1 läuft anstandslos weiter. Insofern bin ich ruhig.
Nicht aufgeben! Das muss irgendwie gehen.
