Hier bitte mal alle relevanten Infos bzgl. Updates einpflegen. Danke!
Ich fange dann mal an:
Quelle: https://www.native-instruments.com/...-updates-of-maschine-komplete-kontrol.359227/
Zitat (Auszug):
Hey all,
In the coming days, we’ll release a maintenance update (MASCHINE 2.8.4 and KOMPLETE KONTROL 2.1.4).
MASCHINE 2.8.4
Further down the line
Apart from reducing the number of Bugs in MASCHINE and KOMPLETE KONTROL in the future, we are focussing on the following features and areas of development:
We don’t have a release date for this yet, it depends on our development time, and beta testing. We will let you know once we get closer to release. A beta for testing these features will be available on Centercode prior to release.
Please keep in mind that I am trying to provide some transparency and therefore share our “work in progress” plans with you. These plans might change and I need you all to be understanding if this happens, in order to maintain this openness and transparency.
Zitat (Auszug):
Hey all,
MASCHINE 2.8.4
- FIXED A problem where some AU plug-ins that have their own sequencer (i.e. Melodyne) were not responding to the transport control correctly
- FIXED A problem where some AU plug-ins did not process audio when hosted in MASCHINE
- FIXED The "Ignore All" Button in the preferences now works as expected
- FIXED MASCHINE JAM no longer crashes when using snapshots
- FIXED It is possible again to Cancel / Save / Discard from MASCHINE MK1 and MK2 hardware controllers
- FIXED All Aux channels in the Mixer are now visible (were visually cut off before)
- Cubase/Nuendo integration for A-Series and M32
- Midi assignment editor (Controller Editor) for MASCHINE MIKRO MK3 (after that starting on the same for A-Series and M32)
- Recording patterns in MASCHINE without pre-defining their length - You will be able to just play and record - the pattern length will automatically extend until you stop recording. (This will be an additional recording mode. The currently existing functionality and workflows will remain)
- Redesign of the MASCHINE MK3 settings page with new icons and more settings available directly from the controller
- macOS Catalina compatibility
