Ari
Gesperrter User
ein neues Update von Studio One 2 ist draußen mit vielen kleinen Bugfixes aber einer großen und wichtigen Änderung! Die Kommunikation zwischen Melodyne und Studio One wurde um- und neugeschrieben. Das hat zur Folge, dass ab jetzt ausschließlich die soeben erschienenden Updates miteinander arbeiten.
Studio One 2.0.6 und Melodyne 2.1
Andere Versionen werden nicht mehr funktionieren!
Ein drastischer aber notwendiger Schritt für eine extrem verbesserte Performance und Zusammenarbeit beider Produkte.
Hier die offiziellen Release Notes:
Viel Spaß
Ari
Studio One 2.0.6 Release Notes
Special Note:
We have changed the communication between Melodyne and Studio One significantly.
As a result, you must update Melodyne to version 2.1 in order to use the Melodyne integration!
The Studio One 2.0.6 update has the following enhancements:
- [OS X] Full-screen support
- [Control]/[Cmd]+Drag to reorder Macro Toolbar buttons/groups
- Add new bus from Folder track uses track color for bus
The Studio One 2.0.6 update fixes the following issues:
- Preview player resampling performance issue
- Merging audio parts does not crop events
- MIDI file export can be corrupt when negative times are used
- Tempo changes not applied to audio recording
- Song end not visible in arrangement after tempo change
- [IR Maker] IRs can have too much room sound
- [Open AIR] Restore length was incorrect when resampling was active; improved overall performance
- Splitting folder events cannot be undone
- Insert silence (via dialog) does not always move markers and signature changes
- Tuner calibration after loading preset
- Delay-compensation issue with ReWire
- Merge audio events that were already in a part
- Bypass buttons do not have enabled state after song reload
- Audio Loop recordings with tempo changes are not correctly stretched
- Edit with Melodyne bounced event, even though Melodyne had already been used
- [Project] Image export adds silence at end
- [Project] Spectrum meter only processes left channel
- [OS X] VSL Ensemble VST3 has no GUI
- [OS X] Video Offset issue
Viel Spaß
Ari
Special Note:
