Studio One 2.0.3 Neues Update!!!
Und ich hänge hier immer noch bei 1.6.5 :-(
Dankeee....:)
Für alle Interessierte, hier die Update Features:
Ist also ganz schön was passiert!
Hello Studio One users!
Studio One 2.0.3 is available now. We fixed a lot of issues and added some minor improvements.
Your feedback in the forum helped a lot to find these issues!
Download it from your user account, or use the update function in Studio One.
These are the changes since Studio One 2.0.2:
add: Drag Send from open channel to closed channel view
add: [Pro EQ] Band name highlight when mouse is over graphical EQ
add: Remove from recent files list command per entry on Start Page
add: Crossfade grouped editing
add: Remove track and instrument command in track controls context menu
add: Drag to Soundcloud node in browser
add: Quantize Panel has quantize on track or in event switch
add: Command for inserting bend markers (Alt+Insert)
add: Audio quantize and transient detection only applied to event range
fix: [Melodyne] Tracks can have timing offset when edited with Melodyne
fix: [Melodyne] Crash if audio files are missing
fix: Hang on songs with OpenAIR loaded
fix: Track list mixer Hide/Show not synced when mixer is closed
fix: Event transpose and velocity not changed after merge
fix: File name of bounced files gets truncated
fix: Input follow does not respect monitor follows record option
fix: Folder track bus selector not updated when bus is removed
fix: Remove track unhides hidden track
fix: Stem export can have mixed signal on stem
fix: Hidden outputs not usable when importing version 1 songs
fix: Automation value edit not working for 3rd party plugins
fix: Locate in empty space not enabled for note editor
fix: Crash with Copy Ranges to track
fix: Crash using bypass with some plugins
fix: Crash in Level Meter RMS length switch
fix: Crash after deleting note event
fix: Toggle snap with shift not working when inserting bend marker
fix: Audio quantize improved for too far away markers
fix: Opening editor suspends auto scroll
fix: Jumping bend markers while inserting
fix: Bend marker not immediately updated in editor
fix: Removed keyboard shortcuts are restored
fix: [Sample One] Resets parameters when using previous and next sample buttons
fix: [Ampire] Global FX LED not working for Tube Driver
fix: [Scope] Not retriggering when using time scale
fix: [Open AIR] Crash with multichannel wave files
fix: [Tuner] Displays wrong octave
fix: [Project] Image export cue file has better compatibility
fix: [Project] UPC/EAN code not written correctly
fix: [Project] DDP export can crash when CD limits reached
fix: [Project] Divider position not saved in project
fix: [Project] DDP export not compatible with WaveLab
fix: [Project] CD can have shifted audio
fix: [OSX] Mixer bank disabled track graphic bug
fix: [OSX] Redraw bug when zooming selected track
fix: [OSX] Save As dialog has empty file name box
fix: [Windows] Performance issue with RME USB interface at 48 Samples
fix: [Windows] MIDI recording not working with NI USB audio interfaces
fix: [Windows] ASIO lock with Steinberg USB driver
And some other minor fixes.
und?
kann schin jemand von den "betroffenen" sagen, ob es weniger crasht als die vorige version?
hatte bisher auch noch zuviele abstürze, sodaß ich mich bei kundenproduktionen noch nicht getraut habe mit S1 zu arbeiten, obwohl ich das progr. mit abstand am liebsten mag. wenn die neuste veriosn jetz besser läuft, würde ich mich gerne nochmal dran wagen...
Du siehst die Crashfixes....
Wenn man wüsste, was DEINE Crashes verursacht, könnte man dagegen auch was tun.
Also WO hast du crashes? Wenn du WAS machst? mit welchen externen Plugins?
Als "Kundenproduktions-DAW" läuft es bei mir zur Zeit aktuell auch. Und das dermaßen stabil.
Weltweit gibt es ähnliche Kunden bei denen es seit Release stabil läuft. Ebenso gibt es weltweit ähnliche Probleme, wie deine.
Diese gilt es also genau zu filtern.
Ari
"Meine" Bugs sind soweit ich das bis jetzt testen konnte wohl gefixed. Das Multi-Track-Comp-Editing (z.B. Schlagzeug Takes) funktioniert jetzt auch bei 13 Spuren so wie es soll. Das ist schon eine echte Zeitersparnis.
Auch Quantisierungen von Spurgruppen mit 13 Spuren sind jetzt stabiler - die hatten unter 2.0.2 noch zu gelegentlichen (aber reproduzierbaren) Abstürzen geführt.
Mit Melodyne hatte ich keine Probleme - ich hab auf Editor upgegradet und alles läuft so wie es soll.
Ich habe es aber nur "zuhause" laufen lassen - also nur editieren und rausbouncen - im Proberaum mit Interfaces und "Real"-Bedingungen muss ich'S noch testen.
habe gerade das Update gemacht und stelle mit Erschrecken fest, dass der Cursor dem Song nicht mehr folgt :-(
Das kann doch kein Bug sein, oder ?
Wo kann ich das ggf. wieder einstellen ("Automatischer Bildlauf" ist aktivert)
danke und Gruß
Franky
probier es mal mit Zeitstempel des audiogerätes ignorieren unter optionen/erweitert/audio.
herzlichen Dank ! Das wars !
Was bewirkt diese Funktion denn normalerweise ?
ich weiss nicht, hatte nur mal nach problemlösungen für N.I. interfaces im s1 presonus forum gesucht und das dabei gefunden.
E
Akasha
Akasha
NorthernDecay
7K
NorthernDecay
NorthernDecay
