Sonnox November Sale 2020
  • #61
I'm about to lose control and I think I like it.
  • #62
Na dann muss ich wohl auf Gearslutz gucken, die sind schlauer als Ihr. :p
https://www.gearslutz.com/board/music-computers/89255-sony-oxford-inflator-please-demistify.html
The Inflator is basically a kind of distortion generator that gives the impression of greater loudness by producing the harmonic cues we naturally associate with loud programme.
It isn't a conventional compressor or limiter, in the sense that it does NOT actually change gain in response to programme in a direct way. However with the effect set at maximum it will naturally prevent sample value overs due to the nature (or side effect) of the process. Lower effect settings can be useful if character harmonics (warmth and the like) are desired but peak level control isn't a priority (i.e. in single tracks etc.)..
Because it produces extra harmonics (more frequency content), the output programme actually has a higher average content. In other words, the average level does increase, but the peak level does not.
The Curve control varies the nature of the effect from minimum where the programme seems to be expanded (increased dynamic range) - through half way where the dynamic range seems least affected - to maximum where the programme is loudest and seems to have some degree of dynamic compression.
Alles klar? o_O
Die Frage, die man sich bei Audio-Bearbeitung immer stellen sollte, ist
Will ich das auch 40 Minuten lang hören?
Ok, heute ist mehr Single- als Album-Kultur, aber Ihr wisst, was ich meine?
  • #63
Naja, das Dingen ist ja so gedacht, dass es (schlicht) lauter wird. Dieser Regler "Curve" macht noch bissken Excitement.
Nee, die curve regelt eher die Klangfarbe des excitements. Excitement kommt mit dem process Regler rein. Nur die genaue Gewichtung der obertonstruktur wird dann per curve geregelt. Im oberen Bereich wird das in den Höhen betont, in den unteren in den Bässen.
  • #64
Auf GS findet man so einige Posts von Paul Frindle, der die Entwicklung des Inflator maßgeblich verantwortet hat. Alle sehr empfehlenswert.
Reaktionen: Graham und Schlumpfpeter
  • #65
Das ist schlichte obertongenerierung aka excitment, nur halt in ner bestimmten harmonischen Zusammensetzung.
  • #66
Ganz so trivial ist das nicht. :-) Ja nachdem wo Input, Output, Effect, Curve sowie v.a. die Gainstruktur des Materials stehen, kann man das Ding sogar als Expander einsetzen. Das ist mit handelsüblichem Excitement eher nicht zu bewerkstelligen. Band Split macht auch noch mal was Eigenes mit dem Signal.
Reaktionen: Schlumpfpeter
  • #67
Kann bitte einer der Mods/Admins meinen Account löschen?
Danke im Voraus!
  • #69
Ja, es teilt das Signal in 3 Bänder auf.
Ganz so trivial ist das nicht. :-) Mit aktiviertem Band Split werden z.B. keine Output Overs mehr verhindert, das müsste man dann händisch nachregeln. Außerdem verändert ein aktivierter Band Split die Signatur der Sätigung z.T. recht stark, d.h. das Ding macht nicht mehr einfach nur lauter, sondern macht untenrum dicker und obenrum präsenter.
  • #70
Ganz so trivial ist das nicht. :) Ja nachdem wo Input, Output, Effect, Curve sowie v.a. die Gainstruktur des Materials stehen, kann man das Ding sogar als Expander einsetzen. Das ist mit handelsüblichem Excitement eher nicht zu bewerkstelligen. Band Split macht auch noch mal was Eigenes mit dem Signal.
OK, schlichte, dynamische und vom signal abhängige, untriviale Obertongenerierung.
Also alles ganz simpel! :D
  • #71
Fürs lauter machen nehme ich einfach einen kostenlosen Gainleveler, gut ich habe dann kein Excitement.
Ich nehm dazu immer den Lautstärkeregler. Zugegebenermaßen ist das nicht wirklich exciting, kostet dafür aber nix extra.
Reaktionen: VogelT
  • #72
Danke im Voraus!
  • #73
So, hab den inflator gekauft. Der macht mit seinem algo aber auch den Pegel n ganzes Stück lauter, da weiß man dann nicht so recht, ob das wirklich besser bzw. weiter vorne im Mix, oder nur lauter ist.
Klar, den Output muss man wieder um ein paar db zurückdrehen. Trotzdem wird es präsenter.
