REAPER v2.5 - 20. oder 21. Sep. 08
  • Ersteller Ersteller Cablebob
  • #202
REAPER v2.4 - July 9 2008
Download: http://www.reaper.fm/files/2.x/reaper24-install.exe
* Per-take volume/pan/mute envelopes
* Preliminary scrub/jog support (with lots of options in Preferences/Playback)
* Middle mouse button in arrange now defaults to jog/scrub
* You can now grab the top of the edit cursor to move (optionally jog/scrub)
* Per-item locking
* Parameter modulation: drive FX parameters from LFO or audio control signals (unlimited sidechaining!)
* Rendering: now shows rendered peaks preview
* Rendering: high quality native dither and noise shaping options
* Preferences: search function for finding relevant options
* Simple color theme element finder (launched from color theme pref window, or by action)
* JS effects now have pin/[g=190]channel[/g] routing controls, JS effects can now define input/output pins (in_pin:, out_pin:)
* ctrl+alt+drag items drops a rendered copy of items, hold shift to drag the source media
* ReaSamplomatic5000: convenient "import selected item from arrange" button
* Optional showing of cues for supported media files (view/show media cues in items)
* WAV reader: support for reading common WAV file cues and loops
* WAV writer: support for writing project markers and regions to cues and loops
* [g=32]MIDI[/g] editor: note naming (double-rightclick piano roll or use the action)
* [g=32]MIDI[/g] editor: can now override ESC key assignment
* [g=32]MIDI[/g] editor: option to enable autosave of [g=32]midi[/g] files on editor close
* [g=32]MIDI[/g] editor: now supports with multiple CC lanes, saves CC lane state, better CC centering behavior
* Action to convert media item cues to project markers and item loops to project regions
* Actions to convert [g=32]MIDI[/g] takes to/from file-based takes (name gets *), for ghost clip functionality
* Action to rename last touched track
* Actions to cut/copy selected items (without being focus dependent)
* Confirmation when deleting tracks with delete key (action for no prompt available)
* Safer winmm (waveOut/[g=32]MIDI[/g]) device closing behavior
* waveOut/KS/DS: if no input device found, output is still opened
* new automatic worker thread behavior on OSX
* made demo project use less CPU (changed resampling mode)
* tweaked mousewheel behavior when a window is captured
* made marquee in envelope mode that doesnt intersect active envelope unselect envelope and select items
* skinnable item buttons (skin images item_fx_off/item_fx_on/item_lock_off/item_lock_on can change size of buttons)
* more efficient bezier envelope interpolation (bugfix)
* if Shup is installed, a new "Shup file" button appears at the end of render
* track envelope window now updates with fx/send changes if set to keep open
* reatune,reaeq,virtual [g=32]midi[/g] keyboard: fixed octave display issues, fixed [g=32]MIDI[/g] output in reatune
* click of track/item FX buttons now closes FX chain window if already open
* envelope dialog now uses virtual windows for better support of more parameters
* better doubleclick handling on some parts of items (FX buttons, etc)
* plug-ins now report actual PDC required independent of buffer size, chain still shows total compensated latency
* display of grid/snap sizes now supports 1/4T instead of 1/6 etc
* Audio Unit: fixed loading of presets, improved PDC
* fixed bug when dragndrop of media+projects at the same time
* fixed updating source file/undo states when using looped sections of items
* better save-as with trim behavior for looped sections of items
* Docker: updated resize handling when docked
* ReaFIR: smoother FFT curve drawing, draw note name in tooltip
* [g=77]VST[/g]: support for parameter center extensions, improved ReaEQ and ReaXcomp
* updated TCP scrolling to better support more tracks when zoomed in
* project save-as dialog: now remembers save options (for both saving as new and re-saving existing)
* Drag and drop fix for Battery 3
* new preference for tooltip delay time
* optimized heap allocation granuarity to increase low latency performance
da isses
  • #203
REAPER Latest Version
Download: 3.3 MB installer
* Per-item locking
  • #205
Man beachte:
Zitat: Unless something dramatic happens, this should be the last update before REAPER 3.
Oh!
Hört, hört....
Bezieht sich das auf das manual oder die Software itself?
  • #206
ich denke auf das handbuch... ziemlich sicher sogar ;)
  • #208
vielleicht werd ich mir das hb auch mal bei lulu kaufen, das reamix ist so schick...wobei, zeit das zu lesen hab ich eh nicht (-8=
lG f
  • #209
@fas1piano:
Hab' ich auch gemacht, warte allerdings immer noch drauf.
Habe gerade nach nochmaliger Rückfrage die Zusage bekommen, dass die Lulus direkt in der Druckerei anfragen, warum das nicht funzt.
Bin jetzt zwar eine Woche weg, melde mich aber sobald ich Antwort und Netz wieder habe.
So long,
Solki
  • #210
Kupo schrieb:
sagt mal leute, is das nicht nervig wenn man jeden tag ein update installiert?
Ich mache maximal alle 1-2 Monate ein Update und das dauert ja nur eine halbe Minute.
  • #211
REAPER v2.41 - July 16 2008
Download: http://reaper.fm/files/2.x/reaper241-install.exe
New action and menu item "[g=84]Insert[/g] virtual instrument on new track"
Double-click in empty track list space to [g=84]insert[/g] new track at end
"Open with FX offline (recovery mode)" checkbox in open-project dialog
WAV read/write: support for more types of WAV file cues and loops
Wavpack read/write: support for importing and exporting cues and loops
Parameter modulation: added release speed slider to audio control signal
[g=32]MIDI[/g] note names: added menu option to clear names
FX chains and FX-add dialog now show item label in title
Save-as with copy/move/trim of source media updates take labels for accuracy
FX browser: fixed some issues with large numbers of folders
Browsing for replacement file on project load allows you to choose any supported type
ReaRoute: overhaul/tons of bugfixes, configurable I/O amounts (2-256 channels now supported)
EDL TXT: Support loading of PlayPitch, better PlayRate offsetting for Vegas EDLs
Internal work towards AMD64 OS support
  • #212
@kupo:
das update installiert sich in einer minute. geht problemlos von statten.
kein vergleich zu anderen sequencern.
3.3 mb sind auch in weniger als einer minute heruntergeladen.
  • #213
REAPER v2.42 - July 26 2008
* Wavpack writer: fixed rendering to wrong [g=395]bit[/g] depth bug
* Per item custom colors
* New actions window for finding actions, defining custom actions, assigning key and controller shortcuts
* Dedicated actions menu including recent actions list, optionally some custom actions
* Preliminary meta-actions for use within custom actions: prompt to continue, prompt to [g=415]loop[/g]
* Meta-actions for modifying [g=32]midi[/g] CCs/mousewheel/etc assignment velocities
* Mousewheel is now a mappable shortcut to actions for the main arrange view and [g=32]midi[/g] editor views
* [g=32]MIDI[/g] editor: avoid making duplicates when pasting notes
* [g=32]MIDI[/g] editor: show [g=415]loop[/g] markers, action to move edit cursor to mouse cursor
* [g=32]MIDI[/g] editor: select previous/next/all note(s) with same note value, paste preserving position in measure (ctrl-shift-V)
* [g=32]MIDI[/g] editor: actions to navigate/select previous/next note (walks through chords)
* [g=32]MIDI[/g] editor: actions to set [g=415]loop[/g] points, move edit cursor to selection or either end of [g=415]loop[/g]
* [g=32]MIDI[/g] editor: new navigate menu, lots of new actions to navigate, select notes, expand selection
* [g=32]MIDI[/g] editor: Actions window
* New actions: expand selected tracks, minimize all others (default shortcut !), minimize all tracks (@)
* New actions: halve/double [g=415]loop[/g] (in arrange or [g=32]MIDI[/g] editor view)
* New actions: mute/unmute (in addition to existing toggle) selected items
* New actions: select all items in time selection, or track and time selection
* New action: [g=84]insert[/g] 4 envelope points at time selection
* Fixed healing splits for items in multi-lane (FIPM) tracks
* Fixed [g=32]midi[/g] overdub recording with [g=415]loop[/g] selection autopunch issues
* ReWire: improvements (better PT compat), option for alternate configuration file for slave mode
* ReWire: fixed loading of [g=32]MIDI[/g] input 8-16 config
* ReWire: improved configuration, ReWire->REAPER [g=32]MIDI[/g] routing config
* JS: fixed mousewheel in certain JS sliders
* JS: new phase_adjust [g=8]plugin[/g]
* JS: moved more FX to old_unsupported
* [g=77]VST[/g]: [g=7]patch[/g] name box no longer accidentally editable, "rename FXP/FXB" added to [g=7]patch[/g] save/load menu
* API: added GetPeaksBitmap, ShowActionList functions
* ReaRoute: fixed some race condition issues, and enabled support for win64-Wow64 rearouting on x64 (expect an x64 rearoute.dll soon)
* Safer waveout/dsound shutdown sequencing (closer to 2.3x)
  • #214
mit dem neuen Update sind auch die feature highlights auf der Reaper Startseite geändert bzw- aktualisiert worden.
Feature highlights
Unlimited creativity with no track limit, free routing for sample-accurate [g=32]MIDI[/g] and audio alike, sidechain control of any [g=8]plugin[/g]
Incredibly flexible and powerful routing - functions as an entire virtual studio with patchbays, enabling all sorts of effects not possible anywhere else
Fast installation and execution - starts up in seconds, always ready to record
Streamlined, tool-less work flow with context menus and item handles for fades, volume, per-item effects, etc
Integrated network FX processing - use spare machines for additional processing power
Supports mixing sample rates and media formats on the fly - WAV, AIFF, [g=223]OGG[/g], FLAC, ACID, APE, WavPack, and more
Great editing features - auto-crossfades, takes and lanes, ripple editing, arbitrary item grouping and locking
Unlimited sound processing - tons of included FX, support for thousands of third party virtual instruments, sample players, audio and [g=32]MIDI[/g] processing plug-ins ([g=77]VST[/g], [g=89]VSTi[/g], DX, [g=110]DXi[/g], JS)
Design your own graphical interface and create your own executable action lists for total customizability
  • #215
REAPER v2.43 - July 30 2008
Download: http://reaper.fm/files/2.x/reaper243-install.exe
New actions: split item at media cues, shrink to first or last cue (or both)
New actions: mute/unmute, solo/unsolo (in addition to existing toggle) selected tracks
New meta-actions: wait 0.1, 0.5, 1.0 seconds before next action
Fixed bug in importing embedded loops when one end of the [g=415]loop[/g] is hidden
[g=32]MIDI[/g] editor: display project markers and regions
[g=32]MIDI[/g] editor: actions to shorten or lengthen selected notes by one pixel or one grid unit
[g=32]MIDI[/g] editor: updates timeline when moving item
[g=32]MIDI[/g] editor show play cursor regardless of full item visibility in project
Better shortcut matching (avoid load-time collisions between num+ and +, etc)
Item playrates are now clamped to 0.01x/100.0x
Added tcp_main_namebg and mcp_main_namebg theme elements
Fixed mousewheel in docked [g=32]midi[/g] editors
ReaFIR: smoother interpolation for EQ curve
ReaNinjam: added "Send" button to chat window for WINE users
JS: new smaller JS DLL (compiled with MSVC, internal cleanups)
JS: no more memcpy() page granularity issues
[g=89]VSTi[/g]: potential fix for faulty plug-ins that do not handle all-note-offs very sensibly
Better transport sizing when using large system fonts
Also available: v2.43 OS X BETA
http://reaper.fm/files/2.x/reaper243_BETA.dmg
(7.3MB - requires OS X 10.4 or 10.5, PPC or Intel [g=18]Mac[/g]).
Also available: v2.43 Windows x64 BETA http://reaper.fm/files/2.x/reaper243_x64-install.exe
(3.3MB - requires Windows XP x64 or Vista 64 [g=395]bit[/g] and 64-[g=395]bit[/g] drivers/plug-ins).
  • #216
Your Daily Update is ready :-D
v2.44 - July 31 2008
+ [g=32]MIDI[/g] editor: fixed markers/regions/time selection drawing when time signature changes
+ Key bindings: cleaner binding saving code
+ ReaFIR: bugfix when switching from precise to points mode
Gruß...
  • #217
Lacunaflow war schneller.
TROTZDEMPUSH
  • #218
Reaper als 64bit Sequenzer? Wusste gar nicht, dass es ihn gibt.
Bedeutet in meinem Fall, dass ich den [g=12]Asio[/g] Treiber endlich verwenden kann - war immer unbedingte Voraussetzung bei einem 64bit System (der 64bit Host).
  • #219
Hoffentlich läuft der Reaper dann mal etwas runder. Seit 2.4 hab ich das Gefühl, dass sich die Bugs häufen.
  • #220
mit den features kommen die bugs.
dann kommen wieder updates mit weniger neuen features,
aber mehr bugfixes.
der natürliche Lauf der Dinge.
