REAPER v2.5 - 20. oder 21. Sep. 08
  • Ersteller Ersteller Cablebob
  • #182
ich hab es getan-....-und reaper gekauft ^^
man muss ja was für die underground-sequencerbewegung tun :D
32,50€ sind imho extrem günstig...
mfg drai
  • #183
REAPER Latest Version
REAPER v2.2 - April 6 2008
Download: 3.2 MB installer
* Now includes the fantastic new elastique 2.0!
* improved looped recording/playback precision
* better looping [g=32]midi[/g] item precision when item length is not a multiple of sample length
* [g=32]MIDI[/g] overdub/replace: auto-[g=84]insert[/g] of new items defaults to shorter items
* [g=32]MIDI[/g] [g=190]channel[/g] rewriting in sends/hw outs no longer corrupts system realtime/exclusive messages
* looped [g=32]midi[/g] input recording latency fix
* fixed bug resulting in excessive splits when recording using non-overdub/replace to in-project [g=32]midi[/g] items
* rewire slave mode: better samplerate detection/switching
* re-added an old fix for Drumatic3 giving invalid samples (requires extra mainschange cycle on load)
* control surfaces: better updating of mute state on csurf track mute change
* Better drag&drop support dragging files to some plug-ins (Battery3 for example)
* Floating FX windows now size themselves to current FX size (but remember their old positions)
* Option (prefs/buffering/advanced) to disable mmap'd peakfiles (to conserve address space)
* Changed default reginfo filenames for hopefully better Vista compatability
* CPU meter: can now show RT CPU+graph (to show CPU use used by main audio thread)
* [g=77]VST[/g]: performance fix for many plug-ins
* [g=77]VST[/g]: better mouse/keyboard activation for plugins like Kontakt 3
* [g=77]VST[/g]: better handling of resizing UIs when docked/undocked/floating
* dev: new APIs for getting/setting track and track send parameters
* dev: new APIs for manipulating track media items/takes/etc
* dev: API to query BWF info from .wav files
* dev: control surfaces can register themselves behind the scenes to get change notifications
* dev: cleanup of documentation and headers
* dev: easy lookup of command IDs via action list (doubleclick "[g=43]filter[/g]" label)
  • #185
REAPER v2.202 - April 22 2008
Download: http://www.reaper.fm/files/2.x/reaper2202-install.exe
Actions to set/move markers 1-10, mapped to Ctrl+0-9
Actions: Record: start new files during recording, add recorded media, remove recorded media
Actions: Stop recording saving all media, deleting all media
Recording mode where files are added at each [g=415]loop[/g] now does not gap playback
better playback behavior when editing/undoing edits of master playspeed envelope
ReaPitch: option to autocorrect master playrate pitch
ReaVocode: increased max bands, optimizations
made Transport: Apply play rate to current [g=45]BPM[/g] reset play rate to 1.0 by default (old version is deprecated for macro use)
Right click on playrate controls allows you to configure "preserve pitch on playrate change" for items, fader range
FX windows, routing, undo history now numpad 0-9, and F1-F12 through to main window when active
[g=77]VST[/g]: new nifty routing-matrix-ish plug-in I/O selector
[g=77]VST[/g]: better support for some plugins that send [g=32]MIDI[/g]
API fixes for track I_RECINPUT/P_NAME updates refreshing track panels
[g=357]peak[/g] files on network drives and removeable media will automatically not be memory mapped
disk read code now allows files to be written while open (to allow other apps to update opened media)
better support for files on network shares that become unavailable
fixed [g=357]peak[/g] display errors for mp3 files
project directory cleanup now shows path, explore button (to browse the project media directory)
  • #186
"Actions: Stop recording saving all media, deleting all media"
record
mal wieder gepatzt? die beiden actions in in ein mini makro und: auf ein neues. wie in [g=540]logic[/g]!
"Actions to set/move markers 1-10, mapped to Ctrl+0-9"
sehr cool: marker 5 soll zum cursor ? ctrl 5
"[g=77]VST[/g]: new nifty routing-matrix-ish plug-in I/O selector"
betrifft track channels, nicht routing zu anderen tracks. cool für sidechain experimente etc.
lG f
  • #187
REAPER v2.205 - May 6 2008
Download: http://www.reaper.fm/files/2.x/reaper2205-install.exe
Synchronous FX multiprocessing mode (even more) improvements/optimizations
FX add window has options for autoclearing search field
ReaMote: autosearch now updates open FX windows if slaves added
internal scrolling optimizations (T,MP!)
Navigator: fixed GDI release bug (T,MP!)
updating track names now updates any open FX windows
New optional automatic thread behavior mode in prefs/buffering, (less CPU and decent low latency perf)
Improved worker thread behavior for tracks that have no items/output/etc
Improved onscreen positioning of windows (T,MP!)
screensets can now remember focus of main edit window, track control panels
Big internal [g=18]mac[/g] updates (may affect windows version, needs testing!)
Option to use alternate keyboard bindings when recording
optimized some excess refreshes when scrolling in certain instances (T,MP!)
und:
UPDATED May 6 2008 -! v2.205/OSX0.89 [g=18]mac[/g] preview build...
www.reaper.fm/files/osx_early/reaper089.dmg
es nimmt form an.
der gute mann muss auf speed sein ;)
  • #188
REAPER v2.3 - June 2 2008
Download: http://reaper.fm/files/2.x/reaper23-install.exe
Automation: Preliminary send/hardware output volume/pan/mute automation recording, per-send automation modes
Automation: new pref for bezier interpolation of envelopes (project->defaults)
Automation: vastly improved recording behavior, configurable return-time
Peaks: in-memory conversion of ancient (pre-1.07) reapeaks files for faster peaks drawing overall
Peaks: new sample-level crosses-and-lines view option
Peaks: antialiased [g=357]peak[/g]/waveform view (preference defaults to on, not supported on OSX but OSX has native AA)
Peaks: fixed occasional bug where first [g=357]peak[/g] in a [g=190]channel[/g] is -1
Fixed rendering, glueing, apply fx, etc for extremely long items (more than 2^31 samples)
track routing dialog now shows the proper pan slider image
added option to center vertical zooms under mouse cursor
audio device status: more display precision on small latency values (T,MP!)
[g=77]VST[/g]: better preset handling for some older VSTs (digitalfishphones, etc)
[g=77]VST[/g]: safer [g=77]VST[/g] FXB/FXP loading
[g=77]VST[/g]: faster generic UI controls (T,MP!)
[g=77]VST[/g]: better timeinfo reporting, support for extended timeinfo reporting measure count
Virtwnd: better support for small updates of big virtual windows (used by new generic controls)
[g=32]MIDI[/g] items: better tracking/sending of CCs when seeking
FX add dialog: disabled renaming of ReWire devices (as it was never implemented)
FX window: reduced excess undo state changes due to comment field
Tooltips overhaul (T,MP!)
Pan laws: setting a pan law of +XdB now means that signal is boosted when panned
Track meters now have optional indication that they are clickable when record armed
Track meters can now optionally not show record input selected
Better menu for track record mode button
ReWire slave: better performance, fixed repeat button thrashing with some host apps
Main window has dead zone along track panel resize edge
ReaInsert: fixed playback issues when a non-existing input is set for return
[g=18]Mac[/g]: Preliminary AU support, support for AU with ReaMote too
[g=18]Mac[/g]: Vast improvements in AU and [g=77]VST[/g] gui display
mp3 seek/sync/EOF fixes (corrects vanishing peaks at the end of mp3 items)
Themes: possible fix for random system image in some themes bug
Control surfaces: included Deric's Yamaha 01X surface support
Control surfaces: updated MCU support from spacelabstudio:
MCU: Option for F1-F8 goto/set(ctrl) markers
MCU: Option for better touch handling for fader moves
MCU: Added user [g=94]feedback[/g] (via LEDs) for Save/Undo
MCU: REW/[g=38]FF[/g] buttons changed to Prev/Next marker.
MCU: Solo button (near transport) clears all solos
MCU: Double click track select/solo selects/solos single track exclusively
MCU: Automation LEDs follow track selection, buttons control selected tracks
Cockos += Schwa. HOT.
  • #189
auf www.landoleet.org kann man sich die pre versionen der als nächstes kommenden reaperversion schon mal vorab anschauen und evtl. vorhanden bugs melden. auch manche plugins können hier gesaugt werden.
diesmal dabei:
v2.302pre - June 19 2008
+ Parameter modulation support: drive FX parameters from LFO or audio control signals (unlimited sidechaining!)
+ [g=32]MIDI[/g] editor: now supports with multiple CC lanes, saves CC lane state
+ Added native dither and noise shaping options when rendering
+ ctrl+alt+drag items drops a rendered copy of items, hold shift to drag the source media
+ actions to convert [g=32]MIDI[/g] takes to/from file-based takes, for ghost clip functionality
+ ReaSamplomatic5000: convenient "import selected item from arrange" button
+ plug-ins now report actual PDC required independent of buffer size, chain still shows total compensated latency
+ display of grid/snap sizes now supports 1/4T instead of 1/6 etc
+ Audio Unit: fixed loading of presets, improved PDC
+ Fixed bug when dragndrop of media+projects at the same time
+ fixed updating source file/undo states when using looped sections of items
+ better save-as with trim behavior for looped sections of items
+ Docker: updated resize handling when docked
+ ReaFIR: smoother FFT curve drawing
+ [g=77]VST[/g]: support for parameter center extensions, improved ReaEQ and ReaXcomp
+ updated TCP scrolling to better support more tracks when zoomed in
+ project save-as dialog: now remembers save options (for both saving as new and re-saving existing)
+ Drag and drop fix for Battery 3
+ new preference for tooltip delay time
reaper macht wahnsinnige sprünge in den letzten 2 updates, man darf gespannt sein...
btw.:
sehr informative threads im reaper forum (für die user, die dort evtl. nicht reinschauen. es sei es ihnen hiermit ans herz gelegt)
über recording-optionen in reaper:
http://www.cockos.com/forum/showthread.php?t=11887
takes and free item positioning (!):
http://www.cockos.com/forum/showthread.php?t=22367&highlight=takes
takemixer:
http://www.cockos.com/forum/showthread.php?t=22431&highlight=takes
fand ich ganz interessant.
  • #190
Hm, ich finde es aber nicht wirklich optimal, dass hier nun auch Beta-Versionen aufgeführt werden. Gerade Einsteiger können aufgrund der evtl. auftretenden Instabilitäten und/oder Ungereimtheiten ein falsches Bild vom REAPER bekommen ;)
  • #191
haste eigentlich nicht unrecht al.
dachte es wäre evtl. für die user interessant, dies nicht wissen, reaper aber kennen und mögen.
(und natürlich um einen ausblick zu haben was kommt) ;)
  • #192
vielleicht sollten hier einfach zwei themen eröffnet werden.
- ein regulärer update thread
- und ein beta thread mit ausdrücklichem hinweis, dass es sich um betaversionen handelt
so hätte jeder etwas davon. oder?
  • #194
danke, ist verbessert!
  • #195
Ach, ich wusste gar nicht das es schon wieder eine Beta gibt :-o
Die Betas bei Reaper sind aber eher das was bei [g=539]Cubase[/g] die Releases nach dem 4. Wartungsupdate sind *duck*. Kann man sich also durchaus mal angucken ohne das einem gleich der Rechner in Flammen aufgeht :)
  • #196
jap, arbeite immer mit den landoleet-betaversionen und hatte noch nie auch nur einen absturz. allgemein in reaper nicht mehr seit ich das free [g=89]vsti[/g] "stringdingsbums" rausgeworfen hab ;)
ich halte reaper eh für eines der stabilsten audioprogramme. hatte schon abstürze mit logic8, [g=539]cubase[/g] le und flstudio... mit reaper noch nie.
(anfangs schon, aber nach deinem hinweis 4damind, dass es wohl an plugins liegt hab ich das eine free [g=89]vsti[/g] [g=8]plugin[/g] aussortieren können was für die abstürze verantwortlich war.)
  • #197
Reaper 2.4 Pre4 July 1st 2008
Download: 3.3 MB installer
v2.4pre4 - July 1 2008
+ scrub behavior fixes, better mcu/tranzport/alphatrack support
v2.4pre3 - July 1 2008
+ fixed marquee selection of item envelopes
+ made marquee in envelope mode that doesnt intersect active envelope unselect envelope and select items
+ scrub/jog updates
+ WT's new smaller buttons for items
v2.4pre2 - June 30 2008
+ improved item buttons (skin images item_fx_off/item_fx_on/item_lock_off/item_lock_on can change size of buttons)
+ system: mousewheel is now always sent to a captured window
+ click of middle mouse button now defaults to jog/scrub
+ hold ctrl when jogging to scrub (optional flippage of this behavior)
+ more efficient bezier envelope interpolation (bugfix)
v2.4pre1 - June 29 2008
+ new automatic worker thread behavior is now default (no longer experimental)
+ if Shup is installed, a new "Shup file" button appears at the end of render
+ preliminary per-take vol/pan/mute envelopes
+ optimized heap usage to increase low latency performance
+ search function for preferences windows
+ [g=32]midi[/g] editor: can now override ESC key assignment
+ [g=32]midi[/g] editor: option to enable autosave of [g=32]midi[/g] files on editor close
+ simple color theme element finder (launched from color theme pref window, or by action)
+ track envelope window now updates with fx/send changes if set to keep open
+ reatune,reaeq,virtual [g=32]midi[/g] keyboard: fixed octave display issues, fixed [g=32]MIDI[/g] output in reatune
+ optional showing of cues for supported media files (view/show media cues in items)
+ action to convert media item cues to project markers and item loops to project regions
+ Rendering dialog now shows rendered peaks
+ you can now grab the top of the edit cursor to move it (hold ctrl to disable snap)
+ super-preliminary scrub support
+ WAV reader: support for reading common WAV file cues and loops (todo W64)
+ WAV writer: support for writing project markers and regions to cues and loops (todo W64)
+ todo: wavpack read/write support of BWF and cues
+ click of track/item FX buttons now closes FX chain window if already open
+ JS effects now have pin/[g=190]channel[/g] routing controls, JS effects can now define input/output pins (in_pin:, out_pin:)
+ envelope dialog now uses virtual windows for better support of more parametsr
+ super-preliminary per-item locking (todo: behavior on diff actions, more actions to set/clear, per-track options as well?)
+ better doubleclick handling on some parts of items (FX buttons, etc)
+ [g=32]MIDI[/g] editor: now supports with multiple CC lanes, saves CC lane state, better CC centering behavior
+ Parameter modulation: drive FX parameters from LFO or audio control signals (unlimited sidechaining!)
+ actions to convert [g=32]MIDI[/g] takes to/from file-based takes (name gets *), for ghost clip functionality
+ ReaFIR: smoother FFT curve drawing, draw note name in tooltip
+ updated inbetween preview versions (remove for final release):
+ fixed reading of WAVs with corrupt cues
+ render dialog peaks display should no longer have any measurable impact on render times
+ improved scrub ballistics
+ parameter modulation now saves with track templates, FX chains
+ updates since first pre(remove for release):
+ fixed env dialog issues, better parm mod window state remembering, JS fix, noise shaping fix
+ more updates: fixed ctrl+alt dragndrop for items with multiple takes
+ more updates: fixed tcp reordering, fixed drag-drop to reasamplomatic child windows
+ more updates: ctrl+alt drag of selected areas of item copies just that portion
+ Parameter modulation: added random-wander LFO type,supports [g=46]bypass[/g] for modulation controls
+ convert to/from [g=32]midi[/g] file actions now modify the take name slightly (prefix * on files)
  • #198
Danke dir Cablebob, aber:
Dem schließe ich mich an, diesen Fred habe ich nämlich abonniert, den landoleet fred würde ich nicht abonnieren!
Gruß :-)
  • #199
+1
ich komm schon bei den regulären updates nicht hinterher, sondern überspringe da immer mal ein paar - prereleases sind mir da echt zuviel...
  • #200
Wie dem auch sei, die pre5 ist jetzt aufm landoleet server.
Der [g=32]Midi[/g] Editor hat jetzt die Möglichkeit, named notes zu benennen.
