REAPER 5.18
MIDI
· fix explode item to channels when using tempo maps and project time offset
· fix peaks display with certain item channel settings
· improve split behavior for items with start offsets and non-1.0 playrate
· optimized handling of very long looping MIDI items
Automation
· add action to write current values to entirety of actively-writing envelopes
· improve descriptions for actions for writing envelopes (actively-writing rather than latched)
CD burning
· restore cdrecord.exe burn method for DAO writing on win32 (removed from 5.12)
· support writing CD-TEXT for cdrecord method on Windows
· use valid gracetime parameter for cdrecord on Windows
ReaScript
· add GetMousePosition()
· add gfx_clienttoscreen/gfx.clienttoscreen and screentoclient
· support gfx.getpixel() with Lua
Super8
· add per-channel Record Delay Compensation adjustment
· visual click support
· take click count / project time signature in to account when calculating BPM
Action window
· fix display glitch when removing key/MIDI assignment
Audio status
· properly display ampersand characters when showing record path
Click source
· fix non-automatic synchronization mode (broken in 4.78+)
Envelope window
· better alignment for non-armable envelopes
Metronome
· fix incorrect modification of tempo map when changing metronome pattern
Peaks
· fix possible incorrect peak display with reverse stereo enabled
Pitch shifting
· prevent hang when using extremely large pitch-up with E3
ReaTune
· fix manual mode display inaccuracies
ReaXcomp
· avoid generating infinite gain using expansion and feedback detector
Stretch markers
· fix stretch marker handle drawing and possible hang issue
VST
· fully unload win32 VSTs on exit, partial revert of 5.16 changes
API
· GetSetTrackSendInfo() support I_AUTOMODE
· add GetTrackEnvelopeByChunkName()
Download
ist ja interessant - der super8, zu dem ich letztens nen thread gepostet hatte, jetzt als integriertes reaper-feature...
hab ihn noch nicht richtig ausprobiert, aber lohnt sich bestimmt...
