REAPER 4.58 released!
  • Ersteller reaper_user01
R
reaper_user01
ReaSamplomatic:
- multi-file support (adding a group of files via browse or drag and drop will divide velocity range by file)
- active voice count indicator
- added optional separate control for note-off release
- changed default settings for new instances
- graphical display of ADS envelope
- improved locking behavior to avoid audio interruption when loading samples
- improved parameter names for automation purposes
- reduced RAM use
- save-as with copy media now puts samples into samples/ subfolder
MIDI editor:
- fixed copy/cut within time selection not advancing the cursor or extending the MIDI item properly in certain situations
- fixed double-click note behavior with certain settings
- fixed step sequencer hang on recording during playback .
- fixes relating to note folding
- improved edit cursor mouse click behavior
Render:
- region render matrix window allows selecting which tracks are rendered under which regions
- better auto-increment numbering for duplicate render target filenames
- option to render selected items
- option to render tracks with only mono media to mono files
- more informative display for render queue
API:
- added file_in_project_ex2, so that plugins tracking media files can receive copy notifications in save-as-copy etc
- functions to get or set the region render matrix
FX:
- fixed chain focus issues when updating ReaSamplomatic plug-in name
- drag and drop cursor fixes relating to monitoring FX
- item FX chains can request higher channel counts for internal processing
MIDI:
- more precise export of linear tempo transition .
- optimizatons to arrange view drawing
- option to automatically scale notes to fit in arrange view
Project bay:
- avoid hang when zooming to selected items that are very far apart .
- improved sorting by take details column
ReaVerb:
- improved threading behavior when loading impulses
- save-as with copy media now puts samples into impulses/ subfolder
Save as with copy:
- better support for copying plug-in referenced media .
- move option will prefer to copy files not in known or fallback recording paths
VST:
- improved setSpeakerArrangement behavior
- optionally inform plugins when track channel count changes
JS:
- added midi_choke
MIDI export:
- warn before overwriting files
MIDI inline editor:
- zoom/autozoom fixes
OSC:
- fixed bug in /vkb_midi/note support
ReaStream:
- improved blocking behavior for network sends
ReaSurround:
- by default, adjusts channels to match track channel count, but can be disabled
Track channels:
- added 36 channels as an option
WAV:
- ignore nonsensical BEXT preferred position data
Windows:
- fixed x64 hang on certain tempo envelope and grid settings
Download
awesomeness galore! :)
Seit dem letzten REAPER-Update merkt sich der Voxengo Elephant in REAPER auch endlich wieder seine Einstellungen. Seit längerer Zeit waren die Routing-Einstellungen bei jedem Neustart von REAPER wieder kaputt.
Schöne Grüße,
Steffen
Gibt es eine Möglichkeit, automatisch in Reaper nur die Spur aufnzunehmen, die gerade selektiert ist?
klar...rechtsklick auf den record button und "automatic record-arm when track selected" anwählen.
kannste in den preferences auch als default für neue tracks festlegen.
habs grad probiert.
Es geht um folgendes: nicht dass eine Spur gearmed wird, wenn sie selektiert wird, sondern dass NUR die ausgewählte Spur aktiviert wird, und nur die.
Wenn ich alle Spuren selektiere und diese Option einschalte, dann hat man dieses Verhalten, oder? Habs grad mal getestet.
Wenn ich jetzt eine neue Instrumentenspur hinzufüge, dann ist diese Option eingeschaltet, aja.
Das ist wichtig fürs Midi-Volk. Nichts nerviger als neuen Synth einfügen, erste Aufnahme, und die alte Spur nimmt mit auf. ;)
mh wo ist jez dein problem?
mit der von mir beschriebenen methode wird genau das erreicht...es wird nur di egerade selektierte spur zum recorden scharfgeschaltet.
Can
Navar
N
Lacunaflow
Lacunaflow
Lacunaflow
Introsong
Introsong
Introsong
Knutorius
MountainKing
MountainKing
