REAPER 4.15
U
user01
v4.15 - January 15 2012
+ API: added simple functions to safely access take and track audio
+ API: extensions and ReaScript can store/restore simple global state (GetExtState, SetExtState, etc)
+ API: extensions can add functions to ReaScript
+ AU: fixed wet/dry control on default pin mappings
+ Actions: relative item positions are preserved when moving item start or end
+ Auto recarm: faster changing of recarm state when operating on many tracks
+ Bridging: avoid unnecessary delays when bridge process failed to launch
+ Bridging: OSX support for bridging/firewalling 64 bit VST/AU
+ Config import/export: UI improvement, added sections for chanmaps, scripts, menusets
+ Control surfaces: don't create undo points when any surface has touch state set
+ Envelope editing: fixed envelope point selection following time selection when option disabled
+ Filters: support for NOT and OR keywords (upper case, ORs have lowest precedence, so a b OR c d NOT e means (a and b) or (c and d and not e)
+ Freeze: fixed actions to freeze through last selected FX
+ MIDI editor: fixed hang when entering grid size of zero
+ Media item properties: immediately update properties window on apply
+ Memory metering: improved Win32 memory meter accuracy
+ Memory metering: option (enabled by default on 32 bit) to warn when memory use is high
+ Mixer: action to show/hide children of selected folder tracks
+ Parameter modulation: fixed switching between tempo-synced and unsynced LFO
+ Parameter modulation: no minimum or maximum for typed-in LFO speed
+ Project bay: fixed action to force refresh
+ Project bay: list offline FX
+ Project bay: option to zoom/scroll to selected items when mirroring selection
+ Project bay: right-click header to show/hide columns
+ Project bay: usage menu selects and scrolls to media items
+ ReWire: updated to ReWire 2.6
+ ReWire: OSX and Win64 now install ReWire libraries if necessary
+ ReWire: support for loading 64 bit ReWire devices
+ ReWire: support for running 64 bit REAPER as ReWire slave (requires 64 bit host app, for now at least)
+ ReaScript: Python loading improvements
+ ReaScript: separate custom path preferences for 32-bit and 64-bit REAPER
+ ReaTune: clear/update analysis on demand in the manual correction tab
+ Region manager: delete key removes regions
+ Region manager: display time in project timeline format
+ Region manager: edit region/marker names in place
+ Region manager: optionally display project markers
+ Region manager: right-click header to show/hide columns
+ Region manager: seek when selecting a marker or region (optional)
+ Regions: improved timesignature handling when duplicating regions
+ Render dialog: remembers last window position
+ Render dialog: saves changes even if window closed without rendering
+ Screensets: update track manager when switching track views
+ Screensets: save/load TCP visibility with track views
+ TCP/Mixer: immediate feedback when sweep recarm/mute/solo controls across multiple tracks
+ TCP/Mixer: sweeping mute/solo/record-arm respects grouping (shift held overrides)
+ TCP/Mixer: sweeping record-arm buttons clears track auto-recarm state on mouseup
+ Take lanes: option to display empty lanes is now global, not per-project
+ Track manager: double-click track number to scroll track into view
+ Track manager: MIDI column (double-click to open all track MIDI in editor)
+ Track manager: action to delete selected tracks (via menu or delete key)
+ Track manager: changing record-arm state clears track auto-recarm
+ Track manager: doubleclick on toggle columns works properly
+ Track manager: drag tracks in manager to rearrange tracks in project (optional)
+ Track manager: fixed remembering previous window location on OSX
+ Track manager: if track MIDI is already open, double-click MIDI column to close
+ Track manager: mute/solo/record-arm changes respect grouping (shift held overrides)
+ Track manager: option for filter to hide child tracks only if the folder parent is hidden
+ Track manager: option to auto-scroll to selected track when mirroring selection
+ Track manager: right-click FX column to open individual track FX
+ Track manager: right-click header to show/hide columns
+ Track manager: set last touched track when selecting from the track manager
+ Track manager: set track colors
+ Track recording settings window: fixed potential crash under certain instances
+ Track templates: support for saving envelopes in templates
+ Track templates: option to offset imported template items (and envelopes) by edit cursor
+ VST: fix for saving presets for plugins with non-automatable parameters
+ Windows: 64-bit build now compiled with ICC
+ Windows: better ASIO device selection when running both 32-bit and 64-bit REAPER on the same machine
http://www.cockos.com/reaper/download.php
na haben sie den Bug gefixt, dass Midi mit Input Quantization auf dem MAC quasi nicht geht, weil es hinterher Hänger gibt?
Das macht nämlich die gesamte Software unbrauchbar.
Verdammt ... so eine fette Daw, aber im Bereich Midi isses einfach noch nicht soweit. Echt schade!
na haben sie den Bug gefixt, dass Midi mit Input Quantization auf dem MAC quasi nicht geht?
keine ahnung. besitze zum glück keinen mac.
8)
8)
Hast du ein Glück! Verdammt!
Selbst ohne Bug ist der Midi Editor behindert hoch drei.
Yeah, Track Colours im Track Manager war meine Idee :D
Reaper wird immer geiler, schade dass es so Bock hässlich ist.
Ich kenne es halt aus PT und daher fande ich Reaper auf einmal an der Stelle unübersichtlich.
Findest du Reaper hübsch oder gar gut nutzbar (durch den Look)?
Nicht unbedingt hübsch, aber aufgrund des Designs sehr übersichtlich und schnell in der Handhabung.
...und da gehen unsere Meinungen dann auch schon wieder auseinander. ;)
PS: ich bin auch PT-User. Hoffentlich sind wir uns wenigstens da einig :D
Ich denke, so ziemlich jeder PT User ist realativ glücklich, ausser mit der Preispolitik von Avid.
Aber das reicht hier zum Thema PT. Es geht ja schließlich um Reaper.
Schade das immernoch keine Möglichkeit existiert, mit dem Timecode etwas praktischer oder überhaupt in Reaper umzugehen. :(
Can
Navar
N
Lacunaflow
Lacunaflow
Lacunaflow
akStudio
Tronspike
T
Introsong
Introsong
Introsong
