Reaper 3.0 ist draußen
  • #61
Reaper 3.06
http://www.reaper.fm/download.php
Changes: Automation for the People
Automation: drag, copy and paste automation with items, within or across tracks
Automation: improvements when "add envelope points when moving items" enabled (right-click env toolbar button)
Automation: recording does not write redundant points (more efficient)
Automation: improvements when "reduce envelope point data when recording automation" enabled
Automation: FX envelope control panel buttons stay lit if parameter modulation or [g=32]MIDI[/g] learn is active
Automation: alt+click deletes an envelope point
Automation: fixed send automation control panel display when writing or overriding automation
Audio: audio device [g=190]channel[/g] remapping/aliasing support, separate configuration for each audio device
Recording: pre-roll monitors track media, action to toggle recording pre-roll
Render: rendering stems supports writing project markers as cues
Project: no prompt to save, or display project settings, when loading an existing project in a new tab
Project: track auto-naming no longer skips leading numbers
Preferences: more configurable track record parameters
Performance: better RAM/CPU behavior with accidental [g=94]feedback[/g] routing
FX: cache undo states for plugins with slow save/load operations
FX: fixed undo point creation when [g=8]plugin[/g] shown in FX chain window
FX: fixed memory leak when loading undo states for some VSTs
FX: fixed parameter modulation save/load/undo problems
FX: save parameter modulation with track templates/chains/paste
FX: show total track PDC in FX button tooltip
FX: performance meter shows PDC by track
FX: fixed track/mixer FX param knob rotation range
FX: fixed EastWest Play (and possibly other plugins) not showing GUI correctly
FX: all IK plugins blacklisted from precise [g=415]loop[/g] buffer handling (glitching at [g=415]loop[/g] end is preferable to crashing)
FX: [g=560]UAD[/g] plugins are set offline after render (fixes rendering at different block size)
ReaEQ: update settings on "reset band to +0 dB" context menu action
[g=32]MIDI[/g]: undo/redo no longer sends note-off to all tracks
[g=32]MIDI[/g]: fixed import of .mid files with trailing non-note events exactly on the beat
[g=32]MIDI[/g]: glue now supports text events
[g=32]MIDI[/g] inline editor: fixed inserting notes at mouse cursor, not advancing main edit cursor
[g=32]MIDI[/g] editor: action to invert current selection
[g=32]MIDI[/g] editor: fixed moving multiple notes in looped items via keyboard actions
[g=32]MIDI[/g] editor: fixed bug when adding sysex manually
[g=32]MIDI[/g] editor: text events are now pooled across items and copied with items
[g=32]MIDI[/g] editor: fixed initialization of lane combo boxes
JS: many optimizations for JS that do [g=32]MIDI[/g] only (no @sample code, or in_pin/out_pin:[g=337]none[/g])
JS: midi_transpose works on notes that are sustaining when you move the sliders
JS: support for longer line lengths for slider definitions
JS: better support for locales that use , instead of . for decimal
JS: update dropdown boxes on sliderchange call
JS: fixed gfx_drawchar/gfx_drawnumber() not forcing screen update
Actions: select any track 1-99 (ctrl: extend, shift: contiguous, alt: invert)
Actions: set [g=415]loop[/g] points to selected items
GUI: user preference for drawing pretty filled automation envelopes
GUI: optional/themeable editing guide lines when moving items
GUI: shift + middle mouse button does hand-scroll (and user preferences for it)
GUI: docker/project tabs show [g=94]feedback[/g] when clicking close-tab buttons
GUI: option to show solid edge on [g=415]loop[/g] selection and/or time selection
GUI: optimized screen drawing to reduce potential overdraws
GUI: separate user preferences for antialiased peaks/waveforms vs. antialiased fades/envelopes
GUI: fixed drawing crossfades when overlapping items are shown in lanes
GUI: track meters hold peaks as low as -150 dB
OSX: toolbar can be customized
OSX: [g=77]VST[/g]/AU with carbon views now hide properly when docked
  • #62
  • #63
Zum Glück jetzt mit der Bemerkung "Fix coming soon".
  • #64
Gibt es die nicht auch auf Deutsch oder nur Englisch?
  • #66
  • #67
Da isses.
Reaper 3.1: Better, stronger, faster,
http://www.cockos.com/reaper/download.php
v3.1 - August 13 2009
+ Actions: toggle show master tempo envelope
+ Actions: faster actions to explode audio by [g=190]channel[/g], much faster actions to explode [g=32]MIDI[/g] by [g=190]channel[/g] or pitch
+ Actions: separate actions to jump to previous/next beat/measure vs moving edit cursor only
+ Actions: fixed occasional disappearing key shortcut
+ Automation: fixed possible crash when deleting FX envelope
+ Automation: shift+ctrl+drag locks envelope point move to either horizontal or vertical (like in [g=32]MIDI[/g] editor)
+ Bounce: display in transport displays bounced length
+ Editing: fixed bug when moving items across hidden tracks
+ GUI: significant CPU optimizations when drawing time selection, antialiased peaks, fades, envelopes, filled envelopes
+ GUI: dim track I/O button when master/parent send disabled (themeable using track_io_dis and mcp_io_dis)
+ GUI: fixed bug in HSV blend mode
+ GUI: fixed edge line drawing for time/[g=415]loop[/g] selections when decoupled
+ GUI: fixed filled envelope [g=99]clipping[/g] bug
+ GUI: separate theme elements for fade quiet zone and fade area color fill
+ JS: updated Liteon FX
+ Media explorer: checkbox for starting media preview on the bar while project is playing back
+ Media explorer: fixed context menu on Vista/Win7
+ Media explorer: show preview graphics for [g=32]MIDI[/g] items
+ Metronome: fixed output selection menu
+ [g=32]MIDI[/g] editor: event [g=43]filter[/g] stays on top, can be toggled on/off
+ [g=32]MIDI[/g] editor: CC lane dropdowns show which message types are currently in use
+ [g=32]MIDI[/g] editor: inserting notes in drum modes uses smaller of grid size or 32nd notes
+ [g=32]MIDI[/g] editor: view preference to always display note [g=21]velocity[/g]
+ [g=32]MIDI[/g] editor: action to move edit cursor to play cursor
+ [g=32]MIDI[/g] editor: action to set selected note lengths to grid size
+ [g=32]MIDI[/g] editor: better paste-extends-source behavior when using unlooped items
+ [g=32]MIDI[/g] editor: no loop end marker for unlooped [g=32]MIDI[/g] items
+ [g=32]MIDI[/g] editor: fixed clipboard leak in certain paste actions
+ [g=32]MIDI[/g] editor: fixed screen redraws/flashes when selecting notes in list view
+ [g=32]MIDI[/g] editor: action to import lyric events from text file
+ [g=32]MIDI[/g] editor: better display of text/sysex event editing vs adding, better copy-drag behavior
+ [g=32]MIDI[/g] editor: clicking empty space in the lane deselects text/sysex events
+ [g=32]MIDI[/g] editor: fixed copy/paste of text/sysex events in list editor
+ [g=32]MIDI[/g] editor: fixed file-based [g=32]MIDI[/g] item text/sysex event undo/redo
+ [g=32]MIDI[/g] editor: fixed memory leak when deleting text/sysex events in list editor
+ [g=32]MIDI[/g] editor: fixed step [g=70]sequencer[/g] note entry when inline editor is open
+ [g=32]MIDI[/g] editor: fixed text event editing on OS X
+ [g=32]MIDI[/g] editor: fixed text event hit testing in certain instances
+ [g=32]MIDI[/g] inline editor: actions dialog can now run actions
+ [g=32]MIDI[/g]: don\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'t create a new [g=32]MIDI[/g] item when punch recording if there is already a suitable item to record into
+ [g=32]MIDI[/g]: fixed overdub recording when extending source and record pdc disabled
+ [g=32]MIDI[/g]: record overdub/replace modes with record PDC disabled now compensated for track PDC
+ OSX: default to Cocoa UI for AU plug-ins that support it
+ OSX: fixed manually editing JS parameter values
+ Peaks/waveforms: recording items are drawn more smoothly and consistently, update faster by default (configurable)
+ Playback: preserve PDC delayed monitoring now compensates for both track and master/parent PDC
+ Project: fixed project template being inserted when opening existing project in new tab
+ Project: setting maximum project length prevents zooming out much past that length
+ ReaEQ: more regular grid lines
+ ReaFIR: more regular grid lines
+ ReaVerb, ReaSamplomatic: now multi-project aware (for save-as with media)
+ ReaSamplomatic: fixed noise bug with zero release time
+ Recording: fixed recording pre-roll sample rounding problem
+ Render: fixed render dialog peaks display when certain stem options set
+ Render: more helpful error message if target directory does not exist
+ Render: saving project to RPP via render dialog now adds project to recent list
+ Render: Shup button sends to user default upload target
+ Screensets: better multiproject track view support
+ Screensets: screenset window now updates on save-project action
+ Shutdown: cancelling save while Windows is shutting down cancels system shutdown
+ Shutdown: more stable sequence with undo history open
+ Solo: fixed glitches when unsoloing with routing and PDC
+ Spaghetti cormorant
+ TCP/Mixer: create sends by dragging IO button to another track
+ TCP/Mixer: alt+click on IO button toggles master/parent send
+ TCP: bulk mute/solo by dragging mute/solo button to another track
+ Tempo envelope: snap points to grid when adding and snapping enabled
+ [g=77]VST[/g]: faster startup scan of plug-ins that have not changed
+ [g=77]VST[/g]: more efficient automation for new envelopes or envelopes with square point shape
+ [g=77]VST[/g]: correct return value for audioMasterAutomate
  • #68
Jo, sind gerade noch n paar fixes dazu gekommen.
REAPER 3.101:
# 3.101: Fixed high CPU use on zoomed-in recording items
# 3.101: Fixed grid line drawing of 1/3 beats
  • #69
Diese Versionsnummer weckt irgendwie nostalgische Flashbacks
aus alten MS-DOS-Zeiten :D
Was ist denn nun mit dem Spaghetti-Teil?
Ist das ein Feature oder ein Insiderwitz?
  • #71
hmmm...
ich glaube, ich werde mal einen Feature Request für
"toggle carbonara on/off" bei Cockos posten.
