REAPER 5.972
  • Ersteller Grummelrocker
Grummelrocker
Grummelrocker
Moderator
Teammitglied
v5.972 - March 7 2019
  • + ARA: add FX menu action to align media to detected grid
  • + ARA: improve interaction of FX menu items to import notes, tempo, and time signatures
  • + ARA: remove menu actions to export tempo and notes and MIDI (instead, import to the project and then export if needed)
  • + ARA: set minimal undo state saving by default for Melodyne
  • + ARA: support linear tempo transitions
  • + Actions: fix action to create measure from time selection when there is an existing tempo marker at the end of the selection [t=52400]
  • + Free item positioning: create a blank lane if there are no existing overlapping media items when enabling free item positioning
  • + Free item positioning: more parsimonious vertical spacing with multiple overlapping items
  • + Media explorer: fix measure-aligned tempo sync dropouts
  • + Notation editor: fix PDF export when using percussion clef [t=217753]
  • + ReaScript: add get_config_var_string()
  • + Render: support rendering only selected regions in an existing region render matrix [t=193405]
  • + Routing/grouping/render matrix: hide children of compacted folder tracks
  • + Routing/grouping/render matrix: show track and region colors
  • + Theming: add [track|mcp]_recarm_[auto_]norec images
  • + Theming: add color blend/alpha for grid lines, MIDI editor grid lines
  • + Theming: add color configuration for CC lane add/remove buttons
  • + Theming: add color configuration item for MIDI piano pane background
  • + Theming: add theme items for MIDI editor CC horizontal lines
  • + Theming: improve text contrast colors
  • + Theming: support complex rules for mcp.size and mcp.master.size
  • + Theming: obey meter text colors alpha field (0-255) if theme version is 6 or higher
  • + Transport: auto-arrange rate label/field if less than 2:1 aspect ratio
Generated by X-Raym's REAPER ChangeLog to BBCode
Can
Navar
N
Knutorius
MountainKing
MountainKing
Lacunaflow
Lacunaflow
Lacunaflow
Introsong
Introsong
Introsong
Can
danam
