Logic 9.1.4
clemenserwe
Moderator
Teammitglied
Dafür, dass manche schon auf eine neue Version warten, wurde noch mal ganz schön gefeilt:
About the Logic Pro 9.1.4 update
Compatibility
Logic can now open songs created by GarageBand for iPad.
Performance and Stability
Logic now provides more specific messaging when playback is stopped because of hard drive performance issues.
Resolves an issue in which Logic sometimes performed very slowly after a project that was saved without assets was consolidated.
Logic no longer quits unexpectedly when copying, pasting, or swapping voices between slots in Ultrabeat.
64-bit Mode
Resolves an issue in 64-bit mode in which a generic interface for some 32-bit plug-ins was displayed.
Automation
Resolves an issue in which moving a region to a different Arrange track assigned to the same channel strip could cause automation to be deleted.
Drag-copy of automation curves now works as expected on grouped tracks.
Moving an automation node that lies between two other nodes of the same value to the left or right no longer causes it to decrease by -0.1 db in value.
Resolves an issue introduced in Logic 9.1 in which performing Undo after using the "Move Visible Track Automation to Region" command would delete the automation.
Audio Editing
Resolves an issue in which performing Undo after creating an alias for a region would shorten the region in No Overlap mode.
Audio Regions that contain slashes in the name can now be successfully merged using the Glue Tool or Merge command.
Quantization of audio regions that have stretched or compressed and contain tempo information now works reliably.
Quantize and Q-Strength now work properly on regions created by exporting a Comp from a Take Folder.
Resolves an issue where lengthening an audio region could sometimes cause the audio to unexpectedly stretch.
Performing Undo after flattening Takes on a group of flexed tracks now works as expected.
Takes no longer sometimes display as soloed when their parent Take folder is disclosed but not selected.
Resolves an issue in which moving a take region with Quick Swipe Comping disabled sometimes did not move the corresponding take region(s) in tracks within the same Edit Group.
Fixes an issue in which dividing a take region that had been created by merging several take regions together could cause the area to the right of the edit to disappear.
Resolves an issue in which importing a Take folder into a project with a matching track could cause existing takes to be removed from Take folders in the original track.
Control Surface Support
Resolves an issue introduced in Logic 9.1.2 in which pickup mode for generic control surfaces did not work as expected.
General
Resolves an issue in which the key commands Next Screenset and Previous Screenset were reversed.
If the Startup Action preference is set to “Ask,” it is again possible to open a project by dragging it onto the Logic icon while the Startup window is open.
The default region quantize setting is now maintained after importing channel strips from another project.
Ich hab's noch nicht - wer hat schon Erfahrungen?
Clemens
Ich werde auch noch warten.
Wie ein "Kollege" von gearslutz schon richtig schreibt:
"I'm not going to fall into that trap.
I'll wait a few weeks, or maybe even a few months, it doesn't really matter to me. My setups are running pretty smoothly right now. I've been doing this for long enough to know that it's better to let other people be the guinea pigs."
Hab bei 9.1.3 auch ne gute Zeit gewartet und hab es offensichtlich nicht bereut ^^
Edit: Was ich sowieso machen werde, ist vorher 9.1.3. zu sichern, da logic mittlerweile ja immer die alte Version überschreibt. So kann ich beruhigter "schlafen" ;-)
Edit2: Wenn diese Aussetzer gefixt wären, wär natürlich super. Ist echt nervig....
Geil - klingt um Welten Besser als Vorher. :D:D:D:D:D:D:D:D:D
Edit: Im Gegensatz zu Steinberg Müssen Logic-User Updates Nicht erst. ausprobieren bis es funzt. . Ich Denke Das Update Kann gefahrlos Installiert Werden
Edit2: Es gibt wohl einige neue Audiofunktionen, die ich gerade ausprobiere - aber noch nicht durchgestiegen bin. ;)
Edit3: Ich meine die Fenster und Menüs schalten einen Tick schneller um.
Dann hast du wohl das Drama beim letzten Update nicht mitbekommen, als plötzlich die Hyper Threading geschichte nicht mehr richtig funktioniert hat. Da ging gerade bei den neuen Mac Pros anno 2010 nix mehr....
Demnach ist schon Vorsicht geboten.
Werds später wenn ich im Studio bin ma als "autarke" Version installieren, sprich 9.1.3. als Sicherheitskopie beibehalten. Dann ma sehn.
Welche neue Audiofunktionen gibts?
Dachte nur bug-fixes
Hier alles im grünen Bereich, macht bisher 'nen echt guten Eindruck
LG
Noizebreaker
kacke.... den Bug mit dem I/O-Plugin wird nicht gefixed? was'n scheiss... :(
Erzähl' mehr!
Clemens
Find das Update sehr gut gelungen. Logic läuft gefühlt flüssiger und schneller als vorher. Alle Projekte rennen wie sie sollen. Auch in anderen Foren kommt das Update sehr gut an.
Also ziehts euch:-D
diese Version suckt.
Bug Nr.1: Es2 LFO synct nicht mehr. (bekannt und bestaetigt).
Bug Nr.2: ich kann keine zwei Ordner mehr parallel packen. Ich hab hier ein Project mit ueber 40 Spuren! Wenn ich den zweiten Ordner packe, landen die Spuren im ersten Ordner und die ersten Spuren sind weg. Da hilft nur noch Undo.
Apple demontiert die eigene Software. Ein Bug wird durch ein anderes ersetzt. Super.
Hattest Du vielleicht aus versehen beim Packen des zweiten Ordners noch die erste Ordnerspur angewählt? (Dann flutschen die Spuren immer in den gewählten Ordner)
Ich habe es gerade getestet (nur mit Instrumentenspuren) und wenn ich eine der Spuren, die ich packen will angewählt habe, funktioniert es einwandfrei.
Clemens
Clemens
Hi Clemens,
ich weiss auch nicht. Diesen morgen hats geklappt. Der Fehler taucht nur unter bestimmten Umstaenden auf. Wenn ich lediglich was angeklickt haette, und die Spuren waeren in den ersten Ordner hinzugekommen (was ja richtig waere), warum sind die anderen dann weg ... Das deutet
fuer mich auf ein Fehlverhalten.
verleumderische, weil völlig unwahre Mutmassung, Kollege Bums! Die SX-Zeiten sind längst vorbei. ;-)
Cubase lief und läuft, im Gegensatz zu Logic, bereits nach Erst-Veröffentlichung saustabil und performant. Und dies schon mit 5.0 und aktuell mit 6.0 (wohlgemerkt Punkt-Null-Versionen!). Kennt man heutzutage kaum noch von anderen DAWs. Apple hat diesbezüglich neben Logic leider auch in den Non-Audio-Applikationen nachgelassen.
Sehr schade.
Zum Thema, 9.1.4 scheint hier stabiler zu laufen als meine 9.1.3., passt also.
EDIT: Multiprozessornutzung scheint auch um einiges besser zu sein. Schön!
