Live 9.03 ist raus
  • Ersteller Ersteller megalon
megalon
Live 9 Release Notes
9.0.3 Versionshinweise
Improvements and feature changes:
Added a new skin: "Disco".
Added a new option to the "Record/Warp/Launch" preferences pane: "Start Transport with Record". If activated, the transport will start immediately when clicking on the Session- or Arrangement-Record buttons. If deactivated, it prepares for recording as in Live 8, so you have to launch a clip in Session View or click the 'Play' button. You can hold down the Shift modifier key when clicking on the record buttons to invert the behavior temporarily.
When recording automation on top of an existing automation envelope, and quickly clicking on different positions in parameters like sliders, X/Y pads, etc., Live now records a latching automation envelope instead of jumping back to the previous value.
The Compressor device does not clip input signals at +20 dB anymore.
Added control surface support for Novation Launchkey series.
Added control surface support for M-Audio Axiom Air Mini 32.
Added a user satisfaction survey. After several hours of usage, Live will ask you to rate the software on the next startup. You can submit a star rating or simply dismiss the survey.
Updated manual, lessons and translations.
Bugfixes:
The Trial version of Live 9.0.2 could hang on startup.
Live would not work as a ReWire slave on Windows.
The performance of the Ableton Index process has been improved, especially on OS X.
The Ableton Index process would sometimes not scan all folders after adding them to the sidebar.
The Ableton Index process could block the GUI during saving and exporting of Live sets, presets or clips.
Scanning folders containing a huge amount of files could take longer than necessary.
The Browser would not update its content pane after a change in the file system if the selection was somewhere outside of the Browser.
Expanding the Audio Unit folder in the browser's "Plug-ins" label could be slow for users which have a lot of library content installed.
Live would not save a clip self-contained after dragging it to the Browser and confirming the name of the new clip by clicking anywhere outside of the Browser.
The Session Record button would not turn off if the recording was aborted, e.g. by stopping or deleting the currently recording clip, disarming a track, etc.
Under certain conditions, MIDI notes would not get recorded into a clip slot after deleting a previous clip.
Overdubbing into MIDI clips could unnecessarily bloat the undo history file.
Fixed a graphical glitch which could occur in the representation of the filter curve in EQ Eight's Frequency Display.
Several MIDI control surfaces would not correctly shut down after quitting Live, e.g. motorfaders on the Mackie Control would not return to zero, Axiom Pro devices would not exit Hypercontrol mode, etc.
The "Project Mix IO" control surface would not work.
The channel strip buttons on the Mackie Control XT would not work.
Fixed a bug where the key navigation in track headers would not work properly when certain control surfaces are selected.
When using control surface scripts, the blue hand would sometimes not map to any device, e.g. after creating a device and then deleting it by using undo.
Live could sometimes crash on quit in case a faulty MIDI remote script throws an exception in the Python console.
Fixed a crash which could occur in Live Intro when right-clicking on a drum rack chain.
Changes for Push:
Using the touch strip to change banks in drum racks now requires to pick up the current value, to avoid changing banks accidentally while playing.
Fixed incorrect intervals in the Locrian scale.
The velocity curve setting would reset to the default value when opening a new Live set.
Changing the pad sensitivity settings could be slow if a drum rack was in focus.
Updating the LCD display could be slow when switching between Drum and Note mode.
The Push LCD could remain blank and no mode would be selected after holding the 'Browse' mode button.
Fixed a bug where 'Browse' mode would be exited after swapping a Max for Live instrument.
Tracks created by dragging an instrument would sometimes not be automatically armed if Push is connected.
The "Arm Exclusive" preference would not be respected when Push was connected.
Fixed a bug where recording wouldn't work properly if the default clip launch mode was set to 'Toggle' mode.
Fixed a crash which could occur when using the 'Quantize' function.
Fixed a crash which could occur when using Push to delete a device whilst recording automation for this device with the mouse.
feature changes:l
muss man des eig nur "drüber" installieren oder die ältere version erst deinstallieren?
Einfach drüber.
Warum zum Teufel wird mir das nicht auf meiner Softwareseite angezeigt?
Weil's nicht mehr da ist:
We've temporarily taken Live 9.0.3 down while we fix a final issue. It should be available again next week.
In the mean time, if you've already installed 9.0.3 and are experiencing issues with plug-ins, please see this article for how to fix things: https://www.ableton.com/en/articles/plugins-silent-903/
Ableton Forum • View topic - I don't see Live 9.0.3 in my account
Ich hab es gestern drübergezogen, deshalb war ich jetzt von Deiner Frage ein Bisschen überrascht. Bei mir scheint so weit alles zu funktionieren.
Hab es gerade in einem anderen Thread im Liveforum gesehen :)
Hm hab gestern den ganzen Abend und heute den ganzen Tag (und immer noch) mit ohne Probleme gearbeitet (außer mit meinem bekannten Kontaktproblem).
oh man, langsam fragt man sich wirklich ob da noch fähige leute am arbeiten sind oder alle zu Bitwig übergelaufen sind.
Was das für ein selten dämlicher Comment?
Sei doch froh, dass Ableton so schnell reagiert und das Update zurück gezogen hat bevor es sich noch weiter verbreitet. Ist ja nicht so, dass bei anderen Herstellern nix schief geht bei Updates.
Und Bitwig ... yo sieht man ja wie fähig und schnell die sind ;)
Also lass doch einfach dieses sinnlose Gemotze ... hilft nicht weiter und bringen tuts auch nichts.
Ist halt meine Meinung, mehr nicht.
Werd da auch nicht weiter drauf rumhacken, ist halt so das da im Moment einiges schief läuft, Punkt.
Ich finde es jedenfalls gut, dass überhaupt so schnell Updates kommen. Mein Logic verschimmelt schon, da kommt selten ein Update.
Kann man hier den dümmsten Kommentar der Woche voten? Megalon ist da ein guter Anwärter für Platz 1.
Aber gut, jeder kann seine Meinung haben, mache Glauben ja auch das Skrillex voll cooler Dubstep ist.
Das mit den Updates einer DAW ist wie ein kompliziertes Mastering eines Stückes. Kommt eine neue Microsoft Windows Version raus, dann kommen ja hinterher monatelang auch Updates heraus, damit das Betriebssystem auch auf "jeder" Plattform laufen kann. Hinzu die sicherheitsrelevanten Updates im Internet. Jeder Konsument hat eine andere Hardware und persönliche Ansprüche an einer DAW. Das geht nicht, daß mit einem Schlag alles bis ins Detail funzt.
