Live 7.0.7 erschienen!
  • Ersteller Ersteller adl
adl
Download hier:
http://www.ableton.com/pages/downloads/choose?product_key=U_00_70
Changes from Live 7.0.5 to Live 7.0.7
Improvements:
Updated manuals
Updated texts
Updated lesson package
Suppressing unnecessary question about "stop audio" on document close.
Bug fixes:
Running the “Analyze audio” command from the context menu of the File Browser would only create .asd files if the respective Preferences option was set to “On”. Now “Analyze audio” is independent of the preferences option.
On [g=18]Mac[/g] OS X, the date in Live's File Browser would not reflect daylight savings time.
Under certain conditions, the pad of a Drum [g=211]Rack[/g] would have a “sticky” hotswap button until mousing over that pad again.
The progress bar for consolidating could sometimes show values greater than 100%.
When switching the [g=32]MIDI[/g] input sources of a track, pitchbend values would not be reset.
[g=32]MIDI[/g] mapping the transpose parameter of an audio clip could lead to not quantized values.
Sending of [g=32]MIDI[/g] Song Position Pointer message beyond bar 1025 would lead to incorrect behavior and different behavior on [g=18]Mac[/g] OS X and Windows.
Under certain conditions, the Operator and Sampler envelopes could go out of sync. We provide a Options.txt entry called “_AdsrRepeatQuantizeTo16th” to restore the previous behavior.
http://www.ableton.com/forum/viewtopic.php?t=89422
Certain Live sets originally created on [g=18]Mac[/g] OS X and containing Audio Units within the chain of a [g=211]Rack[/g] would crash when opening on Windows.
The display of a Mackie Control-based surface controller would not be updated when several sections of the Simpler or Sampler instrument were switched off or on.
http://www.ableton.com/forum/viewtopic.php?t=74388
The display of a Mackie Control-based surface controller would not be updated after renaming a particular device.
http://www.ableton.com/forum/viewtopic.php?t=77676
The LFO sync rate parameter of the Sampler would not be available as a clip envelope.
The time range display of the render dialog would not reflect an Arranger selection with a time signature change.
Even if all external device tracks were frozen, rendering would still happen in real-time.
Deleting an audio file within Live's Browser which was currently being previewed was not possible.
