Sammael
RØDE NT2
Features
• Large capsule with gold plated membranes
• Ultra low noise, transformer- less circuitry
• Omni and cardioids
polar patterns
• High pass filter switch
• -10dB pad switch
• Full frequency response
• Gold plated
output connector
• Gold plated internal
head pins
NT2
With tens of thousands in use around the world the NT2 is a modern legend! It is the industry standard.
With each component selected for its ability to provide the ultimate sound quality, the NT2 delivers full frequency response and exceptional sound.
The NT2 is quality tested at every manufacturing stage. Before dispatch, every NT2 is critically evaluated in a studio environment.
NT2 -when an outstanding, multi-purpose professional microphone is needed.
Accessories included
in full kit:
•Shock mount (SM-1)
•3/8"-5/8" Thread Adaptor
•Windscreen
•Custom aluminum flight case
Accessories included in Model NT2-NC:
•Shock mount (SM-1)
•Zip pouch
Specifications
Capsule: Externally polarised dual diaphragm 25mm (1") condenser
Active Electronics: JFET impedance converter with bipolar output buffer
Pickup Pattern: Switchable Omnidirectional / Cardioid
Frequency response: 20 Hz-20 kHz
High Pass Filter: Switchable; 6dB per octave (-3dB @ 100 Hz)
Output Impedance: 40
Sensitivity: -36dB re 1volt/pascal (16mV @ 94dB SPL) +/-2dB
Equivalent Noise: <14 dBA ("A"-weighted per IEC268-15)
M aximum Output: +2dBu (@ 1% THD into 1K)
Dynamic Range: > 116 dB (per IEC268-15)
Maximum SPL: 130 dB SPL (@ 1% THD into 1K)
Signal/Noise Ratio: > 80dB (per IEC268-15)
info@rodemicrophones.com
...hier geht es nach Australien:
www.rodemic.com
und hier zum Thread:
http://homerecording.de/modules/newbb/viewtopic.php?topic_id=9282&forum=1
mfg jack
