wer Probleme mit NI-Plugins und der Cubase Blacklist hat und so wie ich minutenlang warten musste, damit Cubase startet (weil man die Plugins wieder reaktiviert hat) hier die Lösung von einem NI-Forum Mitglied.
Ich habe eine ältere Cubase Version 9.5.64..und es funktioniert
Hi
for the ones that are too lazy to go through the cubase post, The Muse was so kind to share (and also my approach is a little bit different)
this one helps me for every NI Product that is frequently thrown to the Blocklist (Kontakt, KK, Massive X, Battery 4, jarajaraja):
only tested on Cubase Pro 10.5.20 (Build May 05 2020) and Windows 10 (Versions 1909 & 2004)
1.) Open Cubase->(dont bother to open a session)-> Studio->Plugin-Manager->Blocklist->reactivate all NI dll->check the Tabs (all reactivated Plugins are red)->Close Cubase
2.) Go to C:\User\<yourname>\AppData\Roaming\Steinberg\Cubase 10.5_64 and only delete:
"Vst2xPlugin Whitelist Cubase"
3.) Then open Cubase again and all the Reds made Homerun (no Restart/Unistall or anykind of operations needed, takes really just 2 minuts of your time)
....until the next NI Update, than do this cycle again, and again, there are no problems in performance, gui, latency, load/save or otherwise notable that i encountered.
(if "Vst2xPlugin Whitelist Cubase" is not in the folder, relax, just rescan your Plugins in Cubase (Plugin-Manager, than refresh the Cubase 10.5_64 folder, but first quit Cubase before delete any files)
peace folks
Der User heißt fabosan
Sollte natürlich nicht so sein aber so geht es zumindest wieder
Hi
peace folks
