[Erste] *** Cubase 13 Infos
Aus dem KVR-Forum. Ohne Gewähr aber ich denke die Infos sind schon sehr realistisch:
WHAT’S NEW IN 13?
CHANNEL TAB
Mix on the go
The new channel tab in the Project window gives you direct access to your mix, without leaving the arrangement.
The new design means you can intuitively find what you need, letting you mix on the go in a compact, per channel view.
(PRO-ARTIST-ELEMENTS)
MIXCONSOLE
Slick, streamlined, focused
The MixConsole has been given a fresh overhaul with a slick, streamlined design to help you focus on your mix.
RANGE TOOL
Increase your range
The Range tool is one of the most powerful tools in Cubase and it’s now available in the Key Editor as well as the Drum Editor.
EDITOR
A new editor experience
Edit multiple parts from within the Key Editor and Drum Editor, switch between tracks with the Visibility tab and maintain an overview with the new Track display
(PRO)
VOCAL PRODUCTION
The ultimate vocal chain
Vocal processing is an art of its own, taking a lot of expertise and experience to master the different processing steps. The VocalChain plug-in provides dedicated modules for each step, helping to turn your recordings into professional-sounding vocal tracks.
(PRO-ARTIST)
CHORD PADS
Progress your progressions
The new chord pads make it easy to find creative chord progressions. New presets give you excellent starting points and enhanced functions make it even simpler to create unique music.
ORCHESTRAL LIBRARΥ
Sketch out your scores
Iconica Sketch allows everyone from beginners to professional composers to create full orchestral scores of the highest quality with 140 articulations for 34 instruments in a compact 5GB library.
SAMPLER TRACK
Τweak it
The Sampler Track is even more creative, thanks to stunning new Spectral Warp modes for extreme manipulation and powerful envelope creation.
VOCODER
Τhe return of a legend
Create classic robotic vocals or add analog flavor to your instruments with the legendary Steinberg Vocoder. Use up to 24 filter bands, sidechain input, and enjoy in-depth control over the sound.
(PRO-ARTIST)
COMPRESSION
Compression with character
Black Valve is a classic tube compressor with lots of warmth and character. Its sonic detail makes this tribute to one of the most iconic studio processors really stand out
(PRO)
EQUALIZER
Add class with frequency
Two new equalizers, the EQ-P1A and the EQ-M5, add a classy sound to your productions.
(PRO-ARTIST)
COMPRESSION
Be a vocal specialist
The new VoxComp is a compressor specifically designed for vocals, gently taming your recordings without compromising clarity, transients, or expression.
(PRO)
SAMPLE PACKS
Creative starting points
Be inspired by five exclusive new sample packs by Grammy-winning producer Beat Butcha, creative mastermind Sharooz, and acclaimed sample boutiques 91Vocals and Touch Loops.
STEP & MIDI INPUT - The Step and MIDI Input features are now more even powerful. Modify note lengths on the fly and add voices on top with the new polyphonic note input feature.
KEY EDITOR - MIDI CCs can now be recorded in simplified ramps to make it quicker and easier for editing the controller events afterward
TRACK VERSIONS FOR VIDEO - Working with new video edits is now more convenient with new Track Versions for the VideoTrack.
START MODES - Do you want to start from the cycle marker, the last position or your selection? Configure where playback starts to precisely match your workflow.
TRANSPORT BAR - Easily adjust the project tempo to the beat with the new Tap Tempo feature in the Transport Bar.
CHANNEL CONFIGURATION - Change the channel type from mono to stereo or vice versa with just one click
VERTICAL ZOOM - Zoom in and out vertically with the mouse wheel and decide whether you want to zoom to transport or selection.
KEY COMMANDS - The new Key Command dialog makes managing your short cuts quick and easy. Find commands easier with the dynamic filter and try new macros on the fly.
IMPORT TRACKS FROM PROJECTS - There are several new options that give you more flexibility and control when importing tracks, events, and time ranges.
MIDI PLUG-INS - MIDI plug-ins have had a design overhaul with a fresh new look
MIDI 2.0 - With support for high resolution velocity, CC, aftertouch, pitch bend, and poly pressure data, Cubase 13 is ready for the widespread adoption of MIDI 2.0.
ROUTING - You can now set instrument tracks/racks/sampler return channels as inputs for audio tracks, as well as FX and group channels.
DEMO PROJECTS - Explore three new excellent showcase demo projects, including productions by Austin Hull and Azodi.
WINDOW MANAGEMENT - Cubase now features Windows-compliant multi-window handling.
VIDEO ENGINE - The Windows video engine has been improved, including GPU hardware decoding for H264 and better overall performance.
Und hier kann man ein paar Bildchen gucken:
Hört sich doch erstmal gut an. Freue mich darauf! Bin gespannt wann es soweit ist!
Liest sich alles schon mal sehr, sehr gut. Freue mich drauf!
Gerade eine Mail vom DVD Lernkurs bekommen. Am Mittwoch ist der nächste Cubase Anwendertreff. Könnte sein, daß am Mittwoch Release ist.
Neuer Sampler Track + Vocoder finde ich interessant. Polyphonic Input feature und das neue Routing auch.
Danke für die Infos
Dachte ich auch gerade, vielleicht kann der Holger ja ohne Verletzung der NDA einen Hinweis geben ;)
klingt komisch!?…ist aber so…vertikal zoomen mit dem Mausrad 👍🏻👍🏻👍🏻
…lange gewünscht
Reaktionen: CFR
Wenn die Liste vollzählig ist gibt es leider noch kein polyphones VariAudio. Das bleibt dann Melodyne vorbehalten.
Man poliert den Kotflügel? ... :)
Edit
Ist auch OK, wenn man sich einen ReFresh gönnt.
Es muss weitergehen.
Aber Ich selber erkenne manchmal die echten Moves auch immer eher später.
My bad.
Weshalb ich auch immer sehr lange warte bevor ich Update/Upgrade.
Wird wohl wieder die handelsübliche LM18-Wartepartie, bis jeder in's Lagerfeuer gehustet hat und ich dann irgendwann denke, dass die abklingende Aufregung mich Mein Steak dann auf die Glut legen lässt...
Das habe ich auch auf der Liste vermisst. Nicht so schnell aufgeben, vielleicht kommt es noch.
Es gab ja in der Vergangenheit schon einmal so einen Leak vor dem offiziellen Release. Ich glaub' es war vor C11.5.
Damals war es so, dass die geleakten Features es nicht einmal alle in die nächste Version geschafft haben, sondern erst in die übernächste...
Wie auch immer. Ich vermisse Ableton Link auf der obigen Liste. Menno!
Samplertrack bleibt sinnlos.
Egal, ich nutz eh fast nur Ableton
Eher noch in dem Monat oder Oktober. Wenn da die Infos raus sind dauert das nicht bis Weihnachten.
Vermute auch, dass es sich nur noch um Tage handeln kann.
Sogar auf der Steinberg-Seite gab es ja schon mal ein kurzes Aufflackern ...
Die Info wurde aber nach sehr kurzer Zeit wieder gelöscht.
Die für mich wichtige Features:
CHANNEL TAB
Mix on the go
Hört sich an wie eine automatische Konvertierung von Mono zu Stereo und umgekehrt 👍🏻
Das wäre super, wenn man zum beis. einen Mono Synthesizer mit Stereo Effekten bearbeiten möchte oder ein Stereo Plugin mit einem Hardware Mono Effekt.
Das einzige interessante für mich - hoffentlich ist da auch wirklich eine Verbesserung spürbar.
Ansonsten schön zu sehen, dass auf Plugin-Seite ausgebaut wird, interessiert mir nur ziemlich wenig (sowie wahrscheinlich 95% aller User), da man ja schon ca. 1 bazilliarde Plugins besitzt. Grundsätzlich aber keine verkehrte Entwicklung, wenn man auch ohne Drittanbieter-Stress gut arbeiten kann.
Finde ich nicht, der war für mich sogar ein schlagendes Argument, kaum noch in FL zu arbeiten. Obwohl der eigentlich gar nix kann... :D aber ohne wäre Cubase grad wieder amputiertes Bein.
