REAPER 5.941
5.941
  • API: fix ReaLearn crash
  • API: support GetSetMediaTrackInfo(P_PROJECT)
  • MIDI hardware: allow saving project/other limited UI actions while waiting for a hung MIDI device
Linux
  • add ALSA MIDI support, do not show MIDI-only devices in audio configuration
  • add system hidpi detection, can disable using ui_scale_auto=0 in reaper.ini, or override using ui_scale=
  • reuse existing REAPER instances when opening files from desktop environment (use -newinst command line parameter to override)
  • improve appearance, include libSwell.colortheme (copy to .config/REAPER/libSwell-user.colortheme to override)
  • rename main executable reaper (from reaper5)
  • fix control surface support
  • fix external editor support
  • fix file association icons
  • simplify desktop integration to only add a single item to applications list
MIDI devices
  • add retry button to audio/MIDI device error window
  • warn when a previously-enabled device is not connected (you may see new warnings about MIDI devices from your past)
  • show previously-connected devices in device list, allow forgetting those devices
  • allow changing the device ID of input/output devices to enable I/O consistency between multiple computers
  • rescan when opening MIDI device tab or resetting (may depend on specific driver/OS behavior)
FX
  • do not default to square envelope points on parameters that have a large number of steps defined
  • improve win32/mac plug-in filename parsing for projects saved on linux
JSFX
  • add rate control for spectrograph plug-in
  • gfx_getchar(65536) returns special window information flags
ReaScript
  • fix validation of PCM_source parameters
  • gfx.getchar(65536) or gfx_getchar(65536) return special window information flags
Video
  • add ffmpeg 4.0 support
  • add Colorize preset
  • gfx_procrect() can take mode=1 to apply Y values to U/V (colorization mode)
Control surfaces
  • send active-sensing messages for HUI mode
Glue
  • do not re-open MIDI editors for items whose editors were hidden
[Download]
...und die 5.95 geht die nächsten Tagen als RC online...
Schläft Justin eigentlich auch mal?
Krass. Mal sehen, was 6.0 so bringt. Da gibts aber noch keinen RC, oder?
Vielleicht ist dann Linux offiziell dabei. Das wär der Wahnsinn!
die linuxversion ist schon geil...
hab mal kurz angetestet und noch kein problem entdeckt...
