Jo:
http://www.tokyodawn.net/tdr-limiter6-ge/
EDIT - Neuerungen:
# DSP heavilly modernized and extended. Much higher fidelity overall. All modules have been rebuilt from the ground up, including many new options.
# Variable module order, wet/dry and optinal stereo difference processing per module. Modules can be hidden if needed.
# EBU R128 compliant peak and loudness meter including the loudness range extension.
# "Equal loudness bypass" workflow.
# AAX support, greater stability, preset management, undo/redo, inline help, extensive manual and much more.
EDIT - Neuerungen:
