Es gibt wieder eine Update mit vielen Bugfixes und neuen (wenn auch kleineren) Features:
http://forum.cockos.com/showthread.php?t=181078
+ API: add Envelope_GetParentTake() and Envelope_GetParentTrack()
+ API: allow SetCursorContext() to be called without envelope parameter
+ API: generate new GUIDs for items, takes, and FX on copy/paste, duplicate tracks [t=175672]
+ API: support up to 16 fields for GetUserInputs(), increasing GetUserInputs() text field width
+ Automation: fix multiple-point editing corner cases [t=180363]
+ Automation: separate preference for adding edge points when moving items vs moving multiple envelope points
+ Dynamic split: add support for generating transient guide markers
+ Dynamic split: fix snap offset for final grouped split items [t=178123]
+ Dynamic split: improve analysis speed, disable timestretch/pitchshift during analysis
+ FX: fix 'avoid loading undo state' context menu option in browser
+ FX: set browser item focus when selecting list via down arrow [p=1720400]
+ FX: auto-resize to VST/AU size on doubleclick in empty area of FX windows
+ FX: update bypass check image to have more contrast with dark themes
+ MIDI: fix potential pooled item overdub recording deadlock [t=180935]
+ MIDI: optionally export project tempo map and cues without any channel MIDI [p=1722360]
+ MIDI editor: do not automatically activate event filter on actions to set channel for new events [p=1721580]
+ MIDI editor: add filter checkbox next to channel dropdown [t=178256]
+ MIDI editor: do not deselect events unless piano roll left-click mouse modifier is set to deselect (which it is, by default) [t=177858]
+ MIDI editor: update channel usage indicator after any edit [t=180650]
+ MIDI editor: fix note-off filtering bug [t=180966]
+ Notation editor: assign user-created tuplets to a specific voice rather than MIDI channel [t=180150]
+ Notation editor: autoscroll horizontally during certain types of edits, marquee selection [t=180537]
+ Notation editor: display quantization dialog defaults to the active track
+ Notation editor: fix customized MIDI note double-click mouse modifier [p=1720711]
+ Notation editor: fix display offset for notes that span a measure boundary [t=180446]
+ Notation editor: preserve articulation/ornament information when editing notes via API [p=1721580]
+ Notation editor: support custom beaming actions for sets of notes on different staves (not cross-staff beaming) [t=180445]
+ Preferences: fix crash with very large user-entered recording update frequency [t=180747]
+ ReaSurround: improve 3D preview projection, resize field sizes according to distance
+ Render: better handle 'silently increment' option and render queue [p=1717901]
+ Render: default render path to blank (using default path)
+ Render: fix incorrect rendering with muted folder children and stem rendering [t=180359]
+ Render: make relative render paths override default relative paths
+ Stretch markers: add transient guides, optionally calculated handles which can be used to quickly add stretch markers
+ Stretch markers: fix potential duplicate stretch marker at item extents [p=1718511]
+ Take lanes: do not unselect other items when switching takes of selected item via lane
+ Take lanes: obey multiple selected items/item grouping when switching takes via lanes
+ Theme: draw overlay images for folder buttons in mixer
+ Undo: prevent adding cursor move undo point immediately after project save
+ VST: improve behavior when scanning VST3 shell plug-ins for first time [p=1722349]
+ VST: improve resize and UI behavior with various VST3 plug-ins (including MeldaProduction and Melodyne) [t=180334]
+ VST: improved UI creation logic
+ macOS: fix 'show full screen' menu item being added to Windows menu on macOS 10.11 [t=173120]
+ macOS: allow space to control transport when in routing window text fields
+ macOS: fix keyboard bug in FX chain window [t=180852]
+ macOS: fix VST UAD plug-in appearance
