Du kannst das Meter sogar auf ITU 1770-2 einstellen:
In left most position the meter acts as a classic VU meter with 300ms integration time. Above
this setting, 'K-weighting' loudness filtering is activated and the integration time continuously
increases up to 3 seconds. Given this design, two other important settings can easily be
obtained:
1. In one o'clock position which is the plug-ins default position in all presets (it slightly
snaps into this position and one could also simply use + mouse left click to get
there) the metering accords to the so-called momentary loudness using a window of
400ms as specified by the ITU-R BS.1770-2 standard1.
2. In the fully clockwise (right most) position the metering accords to the so called shortterm
loudness using a window of 3sec as specified by the ITU-R BS.1770-2 standard2.
