V-Stack
  • Ersteller Ersteller Nurmie
N
Nurmie
Hallo Zusammen,
brauche ich zum Betrieb von V-Stack zwingend die Soundkarte VSL 2020?
Danke für Eure Hilfe im voraus.
Im Handbuch steht:
Requirements
To use V-STACK, you need the following: • A PC with either Windows XP or Windows 2000 installed.
A USB Port is also required. For more details about the computer requirements, see below.
• A compatible audio hardware. By audio hardware we mean an audio interface capable of recording and playing back digital audio using your hard disk as a storage medium. For use with VST System Link, the audio interface must have an appropriate ASIO driver (see page 14) and digital in- puts and outputs. For using V-STACK without VST System Link, audio interfaces with Windows Multimedia or DirectX drivers can be used, although we strongly recommend ASIO drivers for best performance.
• To be able to play VST Instruments in V-STACK without using VST System Link, you will also need at least one MIDI interface.
ftp://ftp.steinberg.net/Download/VSTack/VSTack_Operation_Manual.pdf
Clemens
danke für die schnelle Antwort.
So wie ich das verstehe benötigt man nicht die Steinberg VSL 2020 dazu.
