T
talantej
I have the following problem:
I start the Stylus RMX [g=8]plugin[/g] in Cubase, I add for example 4 Loops on 4 Channels. After that I drag the loops in Cubase project window - 4 [g=32]MIDI[/g] Tracks are added automatically - the corresponding channels are added also automatically.
Now I start playing this 4 [g=32]MIDI[/g] Tracks - I see, that only Channel 1 is playing. I mute this channel and try to play for example [g=32]MIDI[/g] Track 2 (Channel 2) in Solo mode - there is no sound, it doesnt want to play. If I Change the channel number from 2 to 1 in this [g=32]Midi[/g] Track and start playing, so I hear now ALL MY LOOPS at the same time, plaing through [g=190]channel[/g] 1.
Resuming: My [g=539]Cubase[/g] doesn\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'t want to separate the Lopps / [g=32]Midi[/g] Tracks between different channels - only [g=190]channel[/g] 1 ist active, all other channels don't play (although I see the equalizer bar active, but no sound at all).
Maybe someone has got similar problem, I thank you in advance for the tipps, how could I solve this problem.
Genau dass pasiert mir.. kann mir jemand helfen? Bitte! :S
