inception
kennt jemand von euch das Teil?
Hört sich irgendwie gut an:
Steuerung von Cubase inklusive Expression und Dynamics zu selben Zeit. Bei den anderen geht doch entweder nur DAW-Control oder Midi Control aber nicht beides gleichzeitig?
https://www.musictech.net/reviews/controllers/studiologic-mixface/
oder ein Sweetwater Review:
Does A Great Job So Far...
I bought this unit to work with CuBase 10 and as an articulation fader for Orchestral Samples. Works great for that. Easy to set up in Cubase and use with Spitfire Audio sample libraries. Connects with supplied USB cable and that alone powers it up. My only complaint is that the fader part where you put your fingers is a bit hard to grab. Your fingers tend to slip off a bit which makes it a little hard to do this with fluid motion. I expect that the faders will loosen more over time. I might have to add some rubber or some type of grip on the top of the fader so fingers will stay. Otherwise It is a great unit that has many useful applications.
Meint ihr das wäre eine Alternative zu:
Icon Platform M+/ Nano
oder meine Überlegung mit dem Nektar Platform T6
Danke für die Tipps
Danke für die Tipps
