SONAR heißt jetzt Cakewalk und kostet nix mehr
  • #181
Das Ganze wiederholt ( alles neu herunter geladen ) - DemoModus...
  • #182
  • Studio Instruments Suite
  • Drum Replacer
  • Melodyne
  • Theme Editor
das sind doch all die Dinge, die es eh schon gab in der alten letzten Version oder Demo in 2017.
Korrekt? also alles auf dem alten Stand jetzt wohl resettet. Das ist gut.
  • #183
Reaktionen: Gast92251
  • #184
Ich habe gerade das neue Cakewalk auf einem Notebook installiert. Dieses läuft unter Windows 7,
hat die gleichen Vorbedingungen ( Sonar X2 Prof. usw... ). Hier fällt der DemoModus aus!
  • #185
Zum Update gibt es nochmal eine volle Liste:
[4/28/2018 UPDATE]
Cakewalk 2018.04.01 Release Notes
We’re excited to bring you the official first release of Cakewalk by BandLab. There are many new features, fixes and stability improvements to Cakewalk as well as BandLab assistant. Migration from earlier SONAR products should be easier now and we’ve also updated the help and brought back multi-language support. We hope you enjoy this release!
BandLab Assistant
Use BandLab Assistant to customize your install of Cakewalk via new install choices. Also, drag and drop from a large library of loops and patterns directly into Cakewalk.
New features:
  • Notify when a Cakewalk update is available
  • Allows you to choose which components to download and install
  • Option to disable launch on startup
  • More streamlined and many fixes
  • Cakewalk installer is no longer silent, and has customization options for installation paths
New Cakewalk Features
Apply settings from a track template to an existing track
You can apply settings from a track template to an existing track, without affecting the existing track’s clip data or track automation. To do so, right-click in the Tracks pane and select Replace From Track Template > [track template name] or select More Track Templates on the context menu.
Dark Piano Roll view with Tungsten theme
The Tungsten theme uses a dark UI that was designed to prevent eye fatigue during long sessions. To match the Tungsten color scheme, the Piano Roll view now has a dark background, with fully customizable colors.
Multi-Language support
Full contextual help is also available from within the application by pressing F1.Cakewalk is now translated into the following languages:English, German, French, Spanish, Italian, Japanese, Chinese, Portuguese-Brazilian, and Russian.
The new Cakewalk online help can be found here. Also check out the new features in this version. Online help is available in English, with German and French coming soon for this version.
Theme Editor
The Cakewalk Theme Editor is back in this release allowing you to create, edit and fully customize themes for Cakewalk. This is new version is exclusively for use with Cakewalk by BandLab and won't replace the older SONAR Theme Editor.
What’s new:
  • Support for editing the new themed Piano Roll view
  • Setup wizard auto populates the Cakewalk install folder removing requirement to browse for the exe file
  • Fixed string formatting issues
  • Added 5 new themeable colors for use with the Piano Roll view and Control Bar Performance module.
Lens Manager usability update
The Cakewalk Lens Manager dialog now has an apply button to allow you to make changes while the dialog is still open.
Drum Replacer
Cakewalk's powerful ARA based drum replacement tool is now in Cakewalk by BandLab. Choose from a library of replacement hits to strengthen your drum grooves. If you already have this installed from a previous SONAR product you won’t need to install this.
Studio Instruments
This add on includes Cakewalk’s popular Studio instruments including Electric Piano, SI-Bass Guitar, SI-Drum Kit and SI-String Section. This add-on also includes 4 Cakewalk demo projects. If you already have this installed from a previous SONAR product you won’t need to install this.
Melodyne 4 Studio Trial
A 30-day trial of Celemony’s award winning Melodyne 4 Studio is included free as part of Cakewalk. This will allow you to explore all the functions of Melodyne 4 studio – free of charge and without obligation, but exactly as if you'd purchased it – for a period of 30 days.Melodyne fully integrates with Cakewalk via ARA and can be applied as a region effect on clips. If you already own Melodyne this installer it will update it to the latest version but won’t change your current Melodyne license.
POW-r dithering available again
We’ve added support for this back into the dither options
Bug Fixes and Enhancements
We’ve been busy making fixes and stability enhancements to Cakewalk for this release:
  • Improved WASAPI devices compatibility and fixed bugs in WASAPI mode. Most onboard audio devices including multi-channel audio devices are now supported in WASAPI shared mode.
  • Updates to code for compatibility with the latest Windows SDK
  • Many improvements and fixes to BandLab Assistant
  • Updated Audio Metronome to resolve a problem with the metronome not working on some systems after install
  • Changing Audio/MIDI settings from the onboarding dialog could cause a crash if the app was playing
  • If migration is chosen the VST inventory will be migrated from earlier versions of SONAR avoiding lengthy scan times on first run.
  • Plugin menu layouts from past versions are now migrated on installation of Cakewalk if chosen
  • Removed some confusing error messages referencing command center and strings referencing SONAR
  • Removed dependency on language from Command Center
  • Creating a Track from a track template was not working from selected track
  • Replace Track from Template could cause unexpected results for unsupported track template types
  • Replacing Multiple Tracks from Template could cause unexpected results
  • Replace Track From Template could not be done from the browser
  • Double-click track templates in browser did not insert the template
  • Themable Piano Roll view does not respond to custom color changes
  • Control Bar Performance module meter colors are not customizable/themeable.
  • Clean audio folder would crash Cakewalk when it encountered paths > 260 chars. This operation has also been optimized to run faster by skipping scanning system and program folders.
  • Lens Manager dialog usability improvements. Added Apply button.
Reaktionen: Neobiont
  • #186
Wenn man jetzt andere Pfade haben möchte so muss man die Beta "Cakewalk bei BandLab" zuerst komplett deinstallieren.
Gibt es da einen speziellen deinstaller bzw. Menüpunkt oder über windows software deinstallieren?
Der Deinstaller befindet sich im Apps Bereich des BandLab Fenster unterhalb des Bildes "cakewalk by BandLab" Wenn man mit der Maus auf den Pfeil neben "Open" klickt gelangt man an den Deinstaller mit dem man das Programm gemäss BandLab Support deinstallieren sollte. Ebenfalls dort kann man die Zusätze (Add ons) installieren. Wenn man an den neuen initialen Installer kommen will bei dem man die Installationspfade angeben kann, dann muss man gemäss BandLab Support zuerst hier mit "Uninstall" das Programm vom System entfernen. Danach erneut installieren, worauf sich das Fenster mit den Pfadeinstellungen öffnen sollte.
Die neue Programmversion kann auch wieder die deutschen Menu und integrierte deutsche Hilfe
  • #187
dieses Zwangsupdate gefällt mir nicht, sonst läuft das erstaunlich gut alles
  • #189
Kam letztens ein Update, und ich musste dies durchführen, um das Programm zu starten.
Kein Ding jetzt, wollte das Programm nur kurz starten, um ein Plug zu testen, dauerte halt was länger dadurch.
Also anmelden und so.
  • #190
Die wollen halt einfach dass Du up to date bist. Wenn schon für lau, dann sind die garantiert scharf auf Deine Daten. Einfach so bekommt man ja nichts umsonst. User-Daten sind heute und vor allem in der Zukunft viel mehr Wert als schnödes Geld, gerade wenn es um solch milliardenschwere Konzerne geht.
  • #191
Hab ich noch nie gehabt ,bei Sonar nicht und bei Cakewalk auch nicht,
das ich das Programm erst nach einem Update starten kann.
  • #192
Nicht zu vergessen ist dass diese milliardenschweren Konzerne scharf auf deine Kontonummer sowie den Pin dafür und den für deinen Safe usw. sind.
Google, Microsoft,Facebook und Twitter machen das auch so.
Am besten, man hält sich von diesen modernen Geräten wie Compjudern und von der
"Telekom"oder wie das heisst fern, ist Teufelswerk das Ganze.
Reaktionen: Gast92251, dhinda, richie und eine weitere Person
  • #193
Ich vermute dass der Bandlab Assistant, oder wie das Ding heißt, gemeint ist. Der meldet sich manchmal und will sich selbst updaten, danach muss man sich darin neu einloggen, wenn ich mich recht erinnere. Die Software Cakewalk selbst macht selbstständig keine Updates und man muss sie auch nie updaten um sie benutzen zu können.
Die Nachricht bon Bentone war halt bisl zusammenhangslos hingerotzt, was soll man mit sowas anfangen.
Reaktionen: Introsong
