Es geht weiterhin auf die 6.0 zu, aber in gaaaanz kleinen Schritten. So ist also heute REAPER 5.982 erschienen.
v5.982 - August 17 2019
- + AIFF: support 8-bit uncompressed Amiga IFF files
- + AIFF: support reading FP files encoded with inconsistent bits/sample field
- + ARA: disable undo integration (should improve stability for Melodyne)
- + Actions: fix potential rounding error in actions to trim or remove selected area of selected items [t=223134]
- + Actions: faster screen updates when processing actions triggered by MIDI messages
- + Batch converter: fix command-line output filename generation [t=108947]
- + Batch converter: fix converter visibility being set by command line render
- + Batch converter: support OUTPATTERN in command-line configuration chunk
- + Command line: add -nosplash and -splashlog options
- + FX: avoid resetting FX from audio thread after undo/redo
- + FX: improve reliability of SetTrackStateChunk() API when setting FX state [t=217691]
- + JSFX: fix gfx_showmenu() coordinates on macOS retina displays
- + Jump to time: allow jumping to times relative to track/item by using tXiY prefix
- + Jump to time: mX and rX can be followed by whitespace and a time offset
- + MIDI: don't reset previous quantization for unselected notes when quantizing selected notes
- + macOS: automatically rescan MIDI hardware on device change notifications [t=222339]
- + macOS: fix GetUserFilenameForRead() [t=223825]
- + macOS: improve memory use calculation [p=1980539]
- + Marquee: fix drawing glitches after interrupted marquee selection
- + Media explorer: faster item navigation via arrow keys with large databases
- + Media items: add actions to force (persistent) offline of item media, inactive take media
- + Media items: add support for per-item beats ruler
- + Media items: if MIDI or click source has custom tempo/time signature set, use it for media item ruler
- + Media items: fix ruler color with certain themes [t=223758]
- + Navigator: improve behavior when continuous scrolling is enabled
- + Notation editor: fix rounding issue when auto-detecting triplets [p=2166957] [p=2159228]
- + Project load: warn of low TLS/FLS slots when plug-ins failed to load
- + ReaScript: fix two small IDE issues when attaching to already-running scripts
- + ReaScript: fix gfx_showmenu() coordinates on macOS retina displays
- + Ruler/Transport: allow choosing primary and secondary display units separately
- + Scrub: do not include (previously incorrectly-rendered) take FX when scrubbing
- + Windows: fix topmost pins with certain multimonitor arrangements [t=224062]
