Tonminister_V2
5.941
[Download]
- API: fix ReaLearn crash
- API: support GetSetMediaTrackInfo(P_PROJECT)
- MIDI hardware: allow saving project/other limited UI actions while waiting for a hung MIDI device
- add ALSA MIDI support, do not show MIDI-only devices in audio configuration
- add system hidpi detection, can disable using ui_scale_auto=0 in reaper.ini, or override using ui_scale=
- reuse existing REAPER instances when opening files from desktop environment (use -newinst command line parameter to override)
- improve appearance, include libSwell.colortheme (copy to .config/REAPER/libSwell-user.colortheme to override)
- rename main executable reaper (from reaper5)
- fix control surface support
- fix external editor support
- fix file association icons
- simplify desktop integration to only add a single item to applications list
- add retry button to audio/MIDI device error window
- warn when a previously-enabled device is not connected (you may see new warnings about MIDI devices from your past)
- show previously-connected devices in device list, allow forgetting those devices
- allow changing the device ID of input/output devices to enable I/O consistency between multiple computers
- rescan when opening MIDI device tab or resetting (may depend on specific driver/OS behavior)
- do not default to square envelope points on parameters that have a large number of steps defined
- improve win32/mac plug-in filename parsing for projects saved on linux
- add rate control for spectrograph plug-in
- gfx_getchar(65536) returns special window information flags
- fix validation of PCM_source parameters
- gfx.getchar(65536) or gfx_getchar(65536) return special window information flags
- add ffmpeg 4.0 support
- add Colorize preset
- gfx_procrect() can take mode=1 to apply Y values to U/V (colorization mode)
- send active-sensing messages for HUI mode
- do not re-open MIDI editors for items whose editors were hidden
[Download]
