Reaper 5.24
Grummelrocker
Moderator
Ex-Rockstar
Teammitglied
Es gibt wieder eine Update mit vielen Bugfixes und neuen (wenn auch kleineren) Features:
+ API: add Envelope_GetParentTake() and Envelope_GetParentTrack()
+ API: allow SetCursorContext() to be called without envelope parameter
+ API: generate new GUIDs for items, takes, and FX on copy/paste, duplicate tracks [t=175672]
+ API: support up to 16 fields for GetUserInputs(), increasing GetUserInputs() text field width
+ Automation: fix multiple-point editing corner cases [t=180363]
+ Automation: separate preference for adding edge points when moving items vs moving multiple envelope points
+ Dynamic split: add support for generating transient guide markers
+ Dynamic split: fix snap offset for final grouped split items [t=178123]
+ Dynamic split: improve analysis speed, disable timestretch/pitchshift during analysis
+ FX: fix 'avoid loading undo state' context menu option in browser
+ FX: set browser item focus when selecting list via down arrow [p=1720400]
+ FX: auto-resize to VST/AU size on doubleclick in empty area of FX windows
+ FX: update bypass check image to have more contrast with dark themes
+ MIDI: fix potential pooled item overdub recording deadlock [t=180935]
+ MIDI: optionally export project tempo map and cues without any channel MIDI [p=1722360]
+ MIDI editor: do not automatically activate event filter on actions to set channel for new events [p=1721580]
+ MIDI editor: add filter checkbox next to channel dropdown [t=178256]
+ MIDI editor: do not deselect events unless piano roll left-click mouse modifier is set to deselect (which it is, by default) [t=177858]
+ MIDI editor: update channel usage indicator after any edit [t=180650]
+ MIDI editor: fix note-off filtering bug [t=180966]
+ Notation editor: assign user-created tuplets to a specific voice rather than MIDI channel [t=180150]
+ Notation editor: autoscroll horizontally during certain types of edits, marquee selection [t=180537]
+ Notation editor: display quantization dialog defaults to the active track
+ Notation editor: fix customized MIDI note double-click mouse modifier [p=1720711]
+ Notation editor: fix display offset for notes that span a measure boundary [t=180446]
+ Notation editor: preserve articulation/ornament information when editing notes via API [p=1721580]
+ Notation editor: support custom beaming actions for sets of notes on different staves (not cross-staff beaming) [t=180445]
+ Preferences: fix crash with very large user-entered recording update frequency [t=180747]
+ ReaSurround: improve 3D preview projection, resize field sizes according to distance
+ Render: better handle 'silently increment' option and render queue [p=1717901]
+ Render: default render path to blank (using default path)
+ Render: fix incorrect rendering with muted folder children and stem rendering [t=180359]
+ Render: make relative render paths override default relative paths
+ Stretch markers: add transient guides, optionally calculated handles which can be used to quickly add stretch markers
+ Stretch markers: fix potential duplicate stretch marker at item extents [p=1718511]
+ Take lanes: do not unselect other items when switching takes of selected item via lane
+ Take lanes: obey multiple selected items/item grouping when switching takes via lanes
+ Theme: draw overlay images for folder buttons in mixer
+ Undo: prevent adding cursor move undo point immediately after project save
+ VST: improve behavior when scanning VST3 shell plug-ins for first time [p=1722349]
+ VST: improve resize and UI behavior with various VST3 plug-ins (including MeldaProduction and Melodyne) [t=180334]
+ VST: improved UI creation logic
+ macOS: fix 'show full screen' menu item being added to Windows menu on macOS 10.11 [t=173120]
+ macOS: allow space to control transport when in routing window text fields
+ macOS: fix keyboard bug in FX chain window [t=180852]
+ macOS: fix VST UAD plug-in appearance
http://forum.cockos.com/showthread.php?t=181078
Reaktionen: Hyp, jet2 und Bassmacher
Reaktionen: jet2 und Grummelrocker
ich setz ja ne menge hoffnung die dynamic split änderungen.
hatte zwar ne lösung gefunden, wie man über gruppen hinweg audioquantisierung machen kann, aber das war teilweise etwas umständlich.
Wie stellt man denn in Reaper die Farben so ein wie in dem Video oben?
Bin erst vor kurzem auf Reaper umgestiegen.
Bisher kann ich nur die ganze Spur einfärben.
Wie macht man es denn, dass wie im Video nur die Wave farbig ist und der Hintergrund z.B. grau bleibt?
gesamte farbe setzt du, indem du über den track gehst - rechte maustaste - track color
wave-farbe, indem du über nen take gehst, rechte maustaste klickst, set item and take colors wählst und - zum take ne farbe aussuchst...
Reaktionen: fabtone
Danke für die schnelle Hilfe,
egal was ich mache es wird immer die ganze Spur eingefärbt.
Habe gerade alle Einstellungen Track, Take, Item auf Grundeinstellung (grau) gestellt und versucht mit "set item and take colors" den Take zu färben und wieder wird die ganze Spur eingefärbt. Der Take bzw. die Wellenform bleibt dabei dunkel. Wenn ich das item einfärbe passiert das Gleiche. :-(
Mir ist so als hätte ich mal irgendwann eine Einstellung angehakt, dass die Track-Farbe fürs Item übernommen wird, weiß aber nicht mehr wo und ob es daran liegt.
Jetzt funktionierts!
Es lag daran, dass die Einstellung in Visuelle Themen auf Default stand. Ich habe auf Default 4.0 umgestellt und jetzt kann ich die Takes wie beschrieben einfärben.
Super, danke!
ja, das ist so:
wenn du das default theme drin hast (sieht ein klein wenig anders aus, als das 4.0 theme), dann sind auch die auswahlmöglichkeiten unter preferences/appearance ausgegraut und nicht anklickbar.
dort kannst du ja zb. auch die wellenform unabhängig vom hintergrund einfärben...
Reaktionen: fabtone
