REAPER 5.17
  • Ersteller Tonminister_V2
Tonminister_V2
Tonminister_V2
MIDI
fix explode item channels (via action and/or import) with tempo maps
fix potential deadlock when overdub recording .
fix split notes action on looped items .
improve tick position display rounding .
improve file-based MIDI editor undo
improve time selection autopunch in overdub/replace modes
prevent input quantizing past loop end/punch region
ReaScript
extend gfx.init/gfx.dock to support save/restore undocked window position
fix Python reentrancy issue .
gfx.dock() returns last docked state when docked windows are closed by user
improve support for swapped mouse buttons in gfx
Recording
add option for discard incomplete take threshold
improve behavior with loop recording and item autopunch
item autopunch falls back to normal recording per-track when recording does not intersect item
item autopunch respects discard partial take option
show MIDI peaks when using replace mode and item autopunch .
Video
add FFMPEG 3.0 support, remove support for FFMPEG 1.x
global option for disabling hi-res peaks, individual instances can override .
improve end of stream in AVFoundation video writing
update disk bandwidth stats when using ffmpeg/vlc/lcf/gif
improve project-relative filename support
Wave
fix cue timing issues above 2 billion samples
fixed slow parsing of large RF64 files
improve RF64 cue/region read/write
support Wave64 cue/region read/write
Automation
added actions for writing latched envelopes to time selection/start of project/end of project
avoid creating duplicate automation return envelope points
JSFX
allow pin connection edits via IO button context menu
Media import
detect and use identical files in project path
detect junctions when determining when to copy files
Navigator
fix play cursor update on OS X 10.11
use item/take colors if configured to do so in arrange
Project bay
auto-rename files to avoid collisions when copying to media path
detect junctions/identical files when copying to project path
Project save
detect and use identical files when using save-as with media copy
detect junctions when determining which files to copy to project path .
Project tabs
fix display issue when toggling always show project tabs .
switch samplerate when switching tabs if run background projects is not set .
ReaTune
default to Elastique3 Soloist for new instances
fix excessive noteoff sending .
Ripple editing
fix insert time/region copy issues .
improve behavior when adding media via drag and drop or insert file
Routing matrix
correct and improve tooltip for hardware outputs .
show F in parent send for items that are children of folder
show parent track destination in tooltips .
Subprojects
avoid rerendered deferred-render subprojects when activating application
improved plug-in compatibility with auto-render on OSX .
option to leave auto-opened projects open in tab after render .
Take FX
fix possibly incorrect samplerate used for automation purposes when rendering
improve synchronization of automation with delay compensated plug-ins, use old synchronization when loading existing take FX chains
Actions
more accurate naming of various nudge dialog actions .
AU
improve graphical issues with certain Apple AUs .
Item colors
fix cross-platform color issues .
Lock
marker/region lock obeyed during ripple edit all/insert time/delete time .
Pan
support -6.02dB pan law .
Preferences
fix search highlight on OS X 10.11
ReaEQ
improve appearance of gain labels in graph
ReWire
add extra step to initialization process to make Waves Tune not warn of error
Routing
show parent track destinations in track I/O panel .
Samplerate conversion
use render setting on glue/apply FX/render take .
Sends/hardware outputs
fix non-boost pan laws for newer pan modes .
Super8
add click output
Tempo map
fix errors introduced to tempo map when editing certain tempo markers (behavior changed in 5.16)
Themes
improve mixer display of tracks in folders with some themes .
VST
never unload bridged VST plug-ins
http://www.reaper.fm/download.php
ja, justin ist fleissig dran...
da sollte doch übrigens auch ein noteneditor demnächst anstehen.
scheint aber noch nicht dabei zu sein...
übrigens - geiles logo, herr tonminister... ;-)
Merci ;)
Jup, Notation wird kommen. Gibt´s derweil allerdings erstmal nur in der Beta zu bestaunen.
