REAPER 4.33 ist draussen!
  • Ersteller Ersteller user01
U
user01
v4.33 - April 17 2012
+ API: added CountActionShortcuts, GetActionShortcutDesc, DeleteActionShortcut, DoActionShortcutDialo, SectionFromUniqueID, GetToggleCommandState2
+ API: added stub for old DuplicateMenu API, fixes csurf_automap support
+ AU: load factory default preset resets pin mapping to defaults [issueid=4364]
+ Actions window: fixed copy command ID to clipboard
+ Actions: insert click source/SMPTE generators makes items without fades
+ Batch converter: fixed rendering past end of source in media items [issueid=4690]
+ Batch converter: setting for FX tail size when applying FX
+ Batch converter: support for rendering media items that have take-fx, including tail [issueid=4689]
+ Control surfaces: improved AlphaTrack/FaderPort following track selection via context menu clicks etc [issueid=4642]
+ Control surfaces: improved support for jog wheels on MCU/01x
+ DDP: fix for CD-TEXT writing errors
+ DDP: fixed extra spaces being inserted into md5 file
+ Dynamic split: correctly detect take start offset/playrate changes
+ EDL: fixed pan reversal in .edl files
+ Editing behavior: default ctrl+C/ctrl+X behaviors now ignore time selection, use shift+ctrl+C/shift+ctrl+X to copy or cut respecting time selection
+ Envelope editing: alt-click to remove point no longer passes through alt-click to other mouse contexts
+ FX: build output routing reduces large lists of created tracks
+ FX: saving/renaming preset UI improved, show existing preset names and prompt to overwrite
+ File import: improved multiple file prompting
+ Freeze: basic support for position change in frozen items propagating back to frozen state
+ Freeze: save with media move/copy includes frozen media too
+ IO window: properly update send volume strings on mousewheel fader adjustment
+ IO window: sanity check pan/width values
+ Item snap offset: better behavior when in beats/position only mode
+ JS: Updated IX/MIDI_Tool II
+ JS: fixed platform-specific rounding issues, improved code generation on some platforms
+ JS: fixed some EOF issues when reading malformed text files
+ JS: improved detection of whether triggers are used by a given JS
+ JS: improved undo behavior on OSX
+ Joysticks: improved rounding consistency in scripts across platforms
+ MIDI: fixed excess noteons/noteoffs when starting overdub/replace recording to new item
+ MIDI: improved overdub/replace recording item creation behavior with loop and preroll
+ MIDI: fixed overdub/replace recording issues (full size loop option, time selection autopunch)
+ Media Explorer: inserting multiple items aligns them at the same time
+ Media import: when dragging media onto an existing media item, prompt to create a new media item or replace existing source media
+ Multiprocessing: improved anticipative FX with sends to tracks that use PDC [t=113560]
+ OSC: fixed FX parameter feedback for some ReaPlugs
+ OSC: fixed certain OSC action binding issues [issueid=4589]
+ OSX: Improved cursor behavior when mouseover on nonfocused windows
+ OSX: fix for possible crashes at shutdown
+ OSX: fixed ReaControlMIDI insertion action
+ OSX: fixed joystick support on i386
+ OSX: fixed main menu langpack support
+ OSX: fixed possible crash relating to accessibility and floating toolbars
+ OSX: improved behavior when drag and dropping large numbers of files from finder
+ OSX: improved peaks reading performance (fixed mmap file reads)
+ Project bay: added actions to insert or remove selected project bay items from project
+ Project bay: context menu action to insert media/FX into project
+ Project bay: support replacing source media with media of a different type (replace wav with mp3, etc)
+ Project bay: improved behavior when removing folders
+ Project bay: improved undo for numerous FX related actions
+ Project bay: fixed memory leak when using external bays
+ Project bay: fixed display of comment field when unretaining media
+ Project bay: reduced RAM use when loading bay state
+ ReWire: enabled ReWire options in preferences for 64-bit
+ ReaComp: fixed RMS/autorelease behavior when automated
+ ReaSurround: fixed cleared input channel names when increasing channel count [issueid=4743]
+ ReaSurround: fixed state loading on PPC
+ ReaNINJAM: OSX chat scroll fix
+ ReaNINJAM: prevent writing corrupt clipsort.log when others use quotes in names
+ ReaNINJAM: fixed possible crash [issueid=4746]
+ Recording: preserve PDC monitoring mode adjusts media start offset rather than item position
+ Recording: tape replace-mode using overdub/replace MIDI modes now properly matches input recording behavior
+ Region manager: updating region indices behaves more like region editor [issueid=4745]
+ Render: added action to render using most recent render settings, but a new target file name
+ Screensets: fixed saving screenset names with spaces in project [issueid=4498]
+ Sends: fixed issues with removing tracks that have send envelopes [issueid=4732]
+ Stem rendering: support output samplerate conversion for stem renders
+ Take pitch envelopes: fixed click on transition to 1.0 pitch
+ Time display: fixed length rounding bug in measures/beats when displaying lengths
+ Time signature markers: fixed refresh on removal via alt+click [issueid=4747]
+ VST: fixed shell-plugin scanning
+ Video: Added WEBM encoding/decoding, made default for encoding
+ Video: Added render option to keep the source aspect ratio
+ Video: Fix for incorrect framerate detection when using VLC decoding
+ Video: Fixed RGB colorspace when using VLC decoding on OSX
+ Video: Fixed YV12 colorspace encoding issue on OSX
+ Video: Fixed incorrect video colors on OSX with MJPEG codecs using VLC decoder
+ Video: Updated FFmpeg to latest available version (1.1.3)
+ Video: added latest LibAV (0.9.x) support
+ Video: faster loading of videos/images
+ Video: improved QuickTime audio decoding
+ Video: improved image item support, pooled fullsize images to limit RAM use, cached thumbnails
+ WALTER: fixed user font 5-8 support
+ WALTER: trans.bpm.tap.margin now can properly specify alignment
+ Waveforms: optionally fill waveform drawing to zero line
+ Windows: fixed duplicate jump list addition on saving project with subdirection creation
+ Windows: opening projects now adds them to Windows recent/jump lists
Reaktionen: DerGipfel und karumba
3 monate seit dem letzten update, ich dachte schon kurz reaper sei tot *lol*
der release trägt aber eh den passenden namen: A moment of silence :D
hehe. die jungs haben humor!
war einer der längsten pre-release cycles überhaupt.
Naja, das ging ja so lange wegen der Stretchmarkers, die es jetzt doch nicht geschafft haben....
gibt ja immer alpha releases im forum. daran sieht man gut, dass es voran geht.
ah, sehr schön. bisher musste ich mir das MD5 nochmal mit einem extra tool generieren.
Schade :( Das mit den stretchmarkers, mein ich.
ah, sehr schön. bisher musste ich mir das MD5 nochmal mit einem extra tool generieren.[/quote]
mit welchem hast du ds denn vorher gemacht?
justin (chefentwickler) hat dazu ein paar zeilen im forum geschrieben.
stretchmarkers werden in einem späteren update kommen. di ejungs wollen´s halt richtig machen anstatt halbgares zu releasen. gibt ja genug andere hersteller, die das machen. haha...
Großartig, daran hatte ich garnicht gedacht :)
muss der ehrlichkeit halber sagen dass ich da auch nicht von selbst draufgekommen wäre, hab's im englischen forum gelesen. :)
Reaktionen: sonnie
