Problem mit xoops/mysql installation
und wieder ein schritt weiter:
Warning: main(C:/homepage/xoops/class/logger.php) [function.main]: failed to open stream: No such file or directory in C:homepagexoopshtdocsinstallclassdbmanager.php on line 26
Warning: main() [function.include]: Failed opening 'C:/homepage/xoops/class/logger.php' for inclusion (include_path='.;C:php5pear') in C:homepagexoopshtdocsinstallclassdbmanager.php on line 26
Warning: main(C:/homepage/xoops/class/database/databasefactory.php) [function.main]: failed to open stream: No such file or directory in C:homepagexoopshtdocsinstallclassdbmanager.php on line 27
Warning: main() [function.include]: Failed opening 'C:/homepage/xoops/class/database/databasefactory.php' for inclusion (include_path='.;C:php5pear') in C:homepagexoopshtdocsinstallclassdbmanager.php on line 27
Warning: main(C:/homepage/xoops/class/database/mysqldatabase.php) [function.main]: failed to open stream: No such file or directory in C:homepagexoopshtdocsinstallclassdbmanager.php on line 28
Warning: main() [function.include]: Failed opening 'C:/homepage/xoops/class/database/mysqldatabase.php' for inclusion (include_path='.;C:php5pear') in C:homepagexoopshtdocsinstallclassdbmanager.php on line 28
Warning: main(C:/homepage/xoops/class/database/sqlutility.php) [function.main]: failed to open stream: No such file or directory in C:homepagexoopshtdocsinstallclassdbmanager.php on line 29
Warning: main() [function.include]: Failed opening 'C:/homepage/xoops/class/database/sqlutility.php' for inclusion (include_path='.;C:php5pear') in C:homepagexoopshtdocsinstallclassdbmanager.php on line 29
Fatal error: Class 'XoopsDatabaseFactory' not found in C:homepagexoopshtdocsinstallclassdbmanager.php on line 45
Hi
Der xoops_root_path is falsch gesetzt.
C:homepagexoopshtdocs == richtig
C:/homepage/xoops/ == falsch
EDIT: ICQ?
gruss
MK
und es geht weiter mit der lustigen Meldung:
Der prozedureinsprungspunkt "mysql_drop_db" wurde in der DLL "LIBMYSQL.dll" nicht gefunden
Hmmmmmm.....
Mittlerweile sind wir wieder bei PHP 4.4.2 angelangt, in der mysql angeblich direkt impementiert sein soll. kann ich bislang aber leider nicht feststellen :x
ES FUNKTIONIERT!!!
Danke an Birdseed der mich gestern Abend noch unterstützen konnte und mir somit geholfen hat, die ganze Geschichte endlich ans rennen zu bringen.
Jetzt hätt ich mal nur noch eine Frage und zwar: wie kann ich welche einbinden bzw. woher bekomm ich module?
Habe jetzt meine xoos Seite, aber die ist größtenteils leer. Über das Admin menü und die css Dateien hab ich zwar schon angefangen das etwas anzupassen, aber wie ich zum Beispiel die Menüs editiere bzw. ein Forum dahinter packe weiss ich jetzt auch nicht.
Gibts vielleicht darüber hinaus irgendwo so standard templates oder so, die schon einiges beinhalten?
Oder kann man sich (ausser die online doku auf xopps.org) irgendwo ein vernünftiges tut dafür runterladen???
grüße, Mitti
Hi
Du musst auf www.xoops.org gehen und dir dann Module runterladen. Die entpackst du dann in den modules Ordner und installierst die über das admin Menü Module >> Administration. Als Forum is CBB 3.04 aktuell.
Templates haben mit den Modulen nix zu tun. Templates sind ja nur die HTML Ausgabeseiten für Module, Themes und Systemelemente (Kommentare, Adminmenü etc.). Jeses Modul hat natürlich immer seine Templates dabei, die man aber fast immer anpassen muss.
gruss
MK
