Mixing Praxis Guide / mit CS4 … eine „subjektive“ Erfahrung
  • Ersteller verflixte13
Romanes eunt domus
:D
aus:
[Brian is writing graffiti on the palace wall. The Centurion catches him in the act]
Centurion: What's this, then? "Romanes eunt domus"? People called Romanes, they go, the house?
Brian: It says, "Romans go home. "
Centurion: No it doesn't ! What's the latin for "Roman"? Come on, come on !
Brian: Er, "Romanus" !
Centurion: Vocative plural of "Romanus" is?
Brian: Er, er, "Romani" !
Centurion: [Writes "Romani" over Brian's graffiti] "Eunt"? What is "eunt"? Conjugate the verb, "to go" !
Brian: Er, "Ire". Er, "eo", "is", "it", "imus", "itis", "eunt".
Centurion: So, "eunt" is...?
Brian: Third person plural present indicative, "they go".
Centurion: But, "Romans, go home" is an order. So you must use...?
[He twists Brian's ear]
Brian: Aaagh ! The imperative !
Centurion: Which is...?
Brian: Aaaagh ! Er, er, "i" !
Centurion: How many Romans?
Brian: Aaaaagh ! Plural, plural, er, "ite" !
Centurion: [Writes "ite"] "Domus"? Nominative? "Go home" is motion towards, isn't it?
Brian: Dative !
[the Centurion holds a sword to his throat]
Brian: Aaagh ! Not the dative, not the dative ! Er, er, accusative, "Domum" !
Centurion: But "Domus" takes the locative, which is...?
Brian: Er, "Domum" !
Centurion: [Writes "Domum"] Understand? Now, write it out a hundred times.
Brian: Yes sir. Thank you, sir. Hail Caesar, sir.
Centurion: Hail Caesar ! And if it's not done by sunrise, I'll cut your balls off.
bitte hört auf mit diesem latein
das is ja wirklich pseudo intellektuell
oder:
.Szene: Nacht, Palastmauer
Charaktere: Brian, Römer
-Was haben wir denn da? Romanes eunt domus? Menschen, genannt Romanes geh in
das Haus?
-Es soll heißen: "Römer geht nach Haus"
-Heißt es aber nicht. Was ist lateinisch für Römer? Na komm schon, komm schon.
-Romanus.
-Deklinieren.
-Anus...
-Vokativ Plural von anus ist?
-Ani.
-Ro ma ni. Eunt. Was heißt eunt?
-Geh.
-Konjugiere das Verb "gehen".
-Eo, is, it. Imus, ites, eunt.
-Also ist eunt?
-Dritte Person, plural, präsens, indikativ. Sie gehen.
-Aber "Römer geht nach Hause" ist ein Befehl. Also musst du was gebrauchen?
-Den Imperativ.
-Der lautet?
-I, i.
-Wieviel Römer?
-Plural. Ite. Ite.
-I t e domus. Nominativ. Geht nach Hause, dass ist eine Bewegung auf etwas zu,
nicht wahr Junge?
-Ja. Dativ, Herr. Ahhh. Ah... ah... Oh oh nein nein nein nein! Ah...Ahkkusativ.
Akkusativ! Ah...Domus, Herr. A domus.
-Und von A domus den...?
-Den Locativ, den Locativ.
-Welcher lautet?
-Domum. Ahh! Ahh!
-Dom mum. Hast du verstanden?
-Ja Herr!
-Du schreibst das jetzt hundert mal.
-Ja Herr. Vielen Dank Herr. Heil Cäsar.
-Heil Cäsar. Wenn du bis Sonnenaufgang nicht fertig bist, dann schneid ich dir
die Eier ab.
-Danke Herr. Danke sehr Herr. Heil Cäsar und alles andere. Ahh.
-Fertig!
-Gut. Und ich rate dir: Tu's nie wieder.
Ahh! Ihr verfluchten Besatzer!
Nö Latein LK, meine Rettung beim Abitur, ansonsten war ich mies ;D
wo du recht hast ... da hast du recht !
mir geht solch inszeniertes (zumeist) bildungsbürgerliches besser-/halbwissen
eigentlich auch auf den keks … was mich betrifft, da nehme ich deine „watschen“/hinweis
gerne an … und gelobe besserung ;-)
gruß
stephan
p.s.
obwohl ich zuerst ein einfaches mea culpa, mea maxima culpa
auf den lippen hatte :D … ( http://de.wikipedia.org/wiki/Mea_culpa )
Darauf einen Schluck:
A votre sanitär ( wie der Latriner so sagt )
interessant, in welche richtung sich so ein thread entwickeln kann...
:D
das sind doch nur Anregungen für den nächsten [g=534]Mixing Praxis Guide[/g]
:D
solange es jeder humorvoll nimmt und auch so versteht ;-)
HomeProducer schrieb:
hab mir den Guide jetzt auch bestellt ... nach dem Skript nenn ich mich Tontechniker :D
da du bis zum versand/erhalt, des skript, noch gar kein richtiger „tontechniker“ bist …
kannst du die „anregungen“ eigentlich auch noch gar nicht richtig würdigen :D
Paar fragen zum Verständnis, kann man an den 3 Songs selbst herum experimentieren? wenn ja , kann mann sie mit allen [g=539]Cubase[/g] Versionen landen? Auch mit LE?
Sind die [g=539]Cubase[/g] Projekte auf der DVD? Was beinhaltet die DVD außer den 3 Songs noch?
Lies dir am Besten mal alle Infos auf der eigenen Website durch, das klärt viele Fragen.
Natürlich kannst Du an den Songs arbeiten, es liegen alle als fertig gemischte [g=539]Cubase[/g]/[g=540]Logic[/g] Projekte vor. Bei diesen sind die internen Effekte benutzt worden und können nach Bedarf verändert werden, ist alles in Echtzeit, nichts in die Files eingerechnet.
Und ja, [g=539]Cubase[/g] LE geht auch.
Sonst ist nichts auf der DVD, reicht doch auch, sind immerhin mehr als 3 GB, da es drei komplette Songs sind und pro Song zwischen 22 und knapp 40 Spuren.
Videos gibt es keine, das macht keinen Sinn und ist nicht Konzept des Guides. Der Sinn ist selber machen, da ist der Lerneffekt am größten. Ist noch kein Mixing Basiswissen vorhanden, sollte vorher z.B. unser Mixing Skript durchgearbeitet werden oder auch das Mixing Weekend besucht werden.
Also ik kann nur sagen, dass Gled hat sich dafür gelohnt. Mein Skript ist heute angekommen und habe es die letzten Stunden gelesen und rumprobiert. Es wird sicher die nächsten Tage meine "holy bible" sein, die unterm Kopfkissen liegt.
Spaß bei Seite, es ist gut geschrieben und sehr verständlich, sogar für mich als Anfänger. Und es sorgt bei mir für Anreiz, denn ik werde dadurch denn hoffentlich weitaus bessere Resultate erreichen, als bei den Aufnahmen in der Vergangenheit. Würde es auch weiterempfehlen...man lernt was dazu.
Gruß der André
danke für die info
d.h es wrid mir im skript beschrieben worauf ich jetz beim [g=118]bass[/g] z.b achten muss und wie ich vorzugehen habe?
bekommt man den praxis guide nur beim audio fabrik oder gibt es den auch beim amptown zu kaufen?
Exakt das, wobei Du das Ergebnis immer hören oder sogar nach Deinen Wünschen anpassen kannst.
Der [g=534]Mixing Praxis Guide[/g] ist ein exklusives [g=537]audio-workshop[/g]/audio-fabrik-produkt und auch nur bei uns erhältlich.
Es steht z.B. drin wie du den [g=118]Bass[/g] mit Kompressor und EQ bearbeitest und ne Menge mehr. Und in den Projekten kannst Du die Einstellungen auch nochmal nachvollziehen, was mir sehr gut hilft, das visuell im Sequenzer zu sehen. Also ik habe heute beim lesen ne Menge gelernt.
Freut mich, dass es so gut gefällt!
Ich würd auch gern was lernen... aber das verdammte Ding kommt nicht an...
Sch...öne Post.
Edit: Habs geschrieben, DING-DONG, Post ist da. Melde mich ab zum lesen ;-)
mein Exemplar ist zwar kurz nach Weihnachten schon gekommen, aber ich hatte erst jetzt die Zeit, mich ausführlich damit zu befassen. Ich muß sagen: "Echt klasse gemacht und sehr hilfreich." Sehr verständlich geschrieben und sehr praxisorientiert. Ich habe den Dance-Titel mal anhand des Buches in [g=539]Cubase[/g] durchgearbeitet und war von dem Ergebnis und dem Lerneffekt begeistert. Obwohl ich kein Anfänger mehr bin, habe ich doch noch einiges lernen können. Ich werde dieses Skript sicherlich auch in Zukunft als "Marschrichtung" für meine zukünftigen Tracks verwenden.
Robertl
6K
DrunkenDunken
DrunkenDunken
twinnpeaks
14K
twinnpeaks
twinnpeaks
RefinedRough
jet2
jet2
Black_Bender
29K
RefinedRough
RefinedRough
22K
